Old 06-11-2009, 11:21 AM
Eless Eless is offline
Default Partition Question
So I know that partitioning your system drive for use as an audio drive is bad news. But my question is this:
I am currently building a PC and considered and 80 GB system drive, and a 1 TB everything-else drive. I was going to partition this up, and have one about 120 GB for an audio drive (i don't need more, all inactive sessions get moved to external storage.) Is this going to cause a problem?
Is the problem just partitioning a system drive, or using any partition of any drive for an audio drive?
Cory
PS i hope this wasn't too confusing...
Old 06-11-2009, 11:22 AM
Default Re: Partition Question
to clear it up.. the partitions were in reference to the 1 TB drive. The 80 GB would stay fully intact and strictly a system drive.
Old 06-11-2009, 11:25 AM
TOM@METRO's Avatar
You can safely partition your non-system drive. You can also partition your system drive as long as it is not used for sessions and PT is installed on c:.
~ tom thomas
Formerly hobotom
Pro Tools Ultimate 2020.12 HDX
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 06-11-2009, 11:27 AM
you never fail to provide a quick, insightful response. thank you very much.
Old 06-11-2009, 11:29 AM
spkguitar's Avatar
To clarify; the problem does not come from partitioning.
The problem comes from accessing the same physical disk drive at the same time as you are trying to stream audio from it for Pro Tools. The operating system routinely accesses the hard drive for all kinds of tasks, and this is the problem of using a partition on your system drive for your Pro Tools sessions.
Likewise, if you partition that huge drive like you are saying, and something needs to access one of those partitions while you are streaming audio for Pro Tools, you may still/also have problems.
Old 06-11-2009, 11:37 AM
TOM@METRO's Avatar
All true... For example you wouldn't ideally want to stream samples from the same physical drive you are running sessions on, but for storage or things running only while PT is not up, you will be OK.
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
Socrates Socrates is offline
I normally try and keep the page dataset and system drive on one physical drive, and nothing else--windows requires a page dataset even if you have more ram than it can address. I created a small partititon for the page dataset because I don't want to back it up when I back up the system drive.
Whether the 1tb drive is fast enough for the rest of the files is something that can be measured, but its kind of hard to speculate. I am at a loss right now as far as recommending some freeware that can measure drive busyness to see if its a bottleneck.
I have a 1.5 tb for my D drive, and all is well, but my projects are very small, so that doesn't prove anything.
Problem with the larger drives is that the storage density of the platters increases faster than the speed of the arms does, so a really large drive isn't as fast as two smaller ones (hence raid).
Logical partitioning has no performace impact, the performance is determined by the arm and disk rotational speed and the storage density--as shared by all logical drives on the disk. I use partitioning as an administrative tool to help keep things organized--especially for backup and recovery purposes.
Try it and see how it goes-what you are proposing could be just the ticket.
Audio Partition and Boot Camp Partition trouble MboxToo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-15-2009 08:35 AM
HD format question. I need a fat 32 partition drmmrboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 07-27-2005 02:08 PM
Partition question neatguys 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-16-2004 12:38 PM
To partition or not to partition, that is the question bzldzl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 03-27-2003 07:59 AM
To partition or not to partition, that is the question. DTJ Digidesign Hardware & Software 2 11-14-2000 11:51 PM
