when you go to the workspace to audition files, many times i lose clock sync. it is a bit annoying.
there was some talk about this and DIGI tech support got on and told us to switch our sync to the 192 internal, quit, restart and then we could switch the sync back to our sync i/o. and then, when we went to the workspace to audition files we would not "lose sync". well... this works for while, and then i am back to losing sync with my clock. it is not BIG deal....but why? and why is the "fix" only temporary? edit: system - hd|2 accell; pt 6.9.1cs3; sync i/o; external wc; dual 2.5g mac; 4 gig ram; atto scsi. signed, wondering about the little things that make my life easier.
Tom Hambleton CAS Ministry of Fancy Noises IMDb Undertone on Facebook Undertone Custom Sound Libraries "Groupable markers would be epochal!" -Starcrash |
This is also frustrating for me. Makes that feature almost unusable. I have never seen it happen on the mix stage I work at with 3 HD systems, only my personal system. It also doesn't happen all of the time. Haven't figured out what causes it yet.
Strange, I had the same problem, did the above fix, and I haven't had a problem since. Not looking forward to that problem coming up again. Did the "fix" work again, at least for a little while?
Yes, I've got this too, makes workspace unusable as we're using a digital SSL, monitoring at Dolby Film levels - we get very loud digital splats when auditioning in the workspace.
Simon.
Simon Jones Freelance sound creative. Bristol / Cardiff, UK Re-recording mixer specialising in TV drama. Mac Pro 2019 7,1 OS10.15.5, Protools ultimate 2020.5, UA Apollo 8 & 16. |
the "fix" works for a while. i will watch more closely to see when it changes.
There's an answerbase item for this -
I get a spike, bang, or pop when opening a Pro Tools|HD session, or previewing from the Workspace, Fade, or Import Audio dialog. This occurs when using digital outputs on a 192 I/O, with a SYNC I/O as the clock master. The pop is occurring when the Loop Sync Master changes from the SYNC I/O to the 192 and back again. The pop *only* happens when an HD system's digital outputs are being routed through another device's DA converters; typically, this happens when the 192 digital outputs are feeding real-time sample rate converters, such as those found on large format digital consoles. Workaround: - Put a BNC cable from the SYNC I/O WC out into the first 192's WC in. - In the Session Setup window, set "clock source" to 192#1 -> Wordclock - Go back to Session Setup window, and set "clock source" back to SYNC I/O ID: 27736 Created: 01/27/2004 Hope this helps Danny Caccavo Digidesign |
sorry danny, i did not see this
and...i tried this workaround, but the probelm comes back. but i did not notice how long it took or what were the steps in between.
Hi people,
We have just upgraded from 6.4 to 7.1 and we are now experiencing exactly the same problem (never occurred on 6.4). I have tried the temp fix of changing clock source to 192 internal, save, relaunch protools, change clock back to sync I/O, but cannot clear the prob even temporarily. It is quite a while since anyone has posted in this thread, did anyone ever find a permanent solution, or did it disappear for everyone else with upgrades? We are actually running XP on a PC, but seems the problem is more related to peripheral hardware than the OS, and this thread seemed to be an exact description of our problem. Thanks |
Workspace Browser Auditioning -- did I dream that? | emerson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 10-19-2007 06:52 PM |
Auditioning split stereofiles in workspace? | Audiofarm | Pro Tools TDM Systems (Mac) | 2 | 05-25-2007 03:00 AM |
Workspace crash when searching or auditioning | hesnodgrass1 | Pro Tools TDM Systems (Mac) | 7 | 03-18-2005 05:30 PM |
loose system sync-auditioning workspace in 6.4! | mnet101 | Pro Tools TDM Systems (Mac) | 0 | 02-16-2005 03:50 PM |
pro tools 6 not auditioning in workspace | chagos | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-07-2004 01:09 PM |
