When setting the Open Ended Record Allocation above 90 minutes and recording 48 tracks, I get the “spinning wheel” when I hit record. The delay can be up to 2 minutes from hitting record until PT starts recording. I use the Xserve with one MAC only (via fiberchannel), not in a server configuration. I have 1 TB of disk space and about 400GB free disk space. The disk is very little fragmented. The weird thing is that this problem seams to be random! One day PT records 3 hours with no problem and the next day I have to set the Open Ended Record Allocation to 90 min or less to get a smooth operation (we record a lot of live-in-studio shows that lasts for 1-2 hours). When PT is finally recording, the disk-access meter usually shows 10% or less activity, so there is not much strain on the Xserve. But while PT is “spinning the wheel”, the disk access meter on the Xserve (the blue leds) hits the roof. When recording on a single empty 250GB FW400 disk with the same configuration), PT has no problem recording 48 tracks with Open Ended Record Allocation set way above 90 min (I know it is not recommended…). I have tried do delete preferences and digisetup files with no effect. Anyone with a solution to this problem? We are considering buying ProTools as a substitute for Tascam DA88’s in our OB trucks, but are a bit unsure about the stability of PT when recording large track counts for serveral hours. Best regards, Øystein My setup is: MAC G5 1,8Ghz with 1,5 GB RAM running on OS 10.3.4 ProTools: 6.4 cs9 Xserve: Firmware 1.2.4, Raid Admin 1.3.2 |
Problem with ProTools and Xserve RAID | OysteinHalvorsen | Storage Subsystems | 0 | 12-23-2004 07:01 AM |
Mac Xserve Raid | Daniel Mendez | Storage Subsystems | 0 | 05-01-2004 02:10 AM |
Apple Xserve RAID and protools | nayrbnoswal | Pro Tools TDM Systems (Mac) | 0 | 01-24-2004 11:14 PM |
Xserve RAID as storage for ProTools? | Matts | Storage Subsystems | 4 | 05-19-2003 08:33 PM |
Multiple ProTools 6 systems and Xserve RAID? | Matts | Pro Tools TDM Systems (Mac) | 2 | 02-25-2003 07:43 AM |
