PC Build.. Will this work?
This is my first time building a PC. I've been using PT for almost 5 years, am certified, and know the program well.. What i DON'T know well is building computers. I'm not looking to be running crazy sessions, and well only be for personal and "semi"-professional situations. I don't need a powerhouse, just a stable system.
For now, I'm running PT 7.4, but if it seems feesible, I'll upgrade to 8. I know there is the "PC build" forum... but man that is hard to sift through. A simple "yes" or "no" will suit me just fine here, unless you had recommendations or additional thoughts. Thanks in advance! Intel Core 2 Duo E5200 Asus P5QL PRO 4 GB DDR2-PC6400 / 800 MHz Okia 450 Watt Power Supply I understand this is still missing pieces, I'm not that dumb, but I wanted to at least make sure I was alright so far before making other decisions. The need to upgrade anything here will affect future decisions like hard drive size... Cory |
Re: PC Build.. Will this work?
You really should go with a quad core cpu. I would go at least with the Q6600. You need a video card but cheap is good there(I use a $37 MSI GeForce7300LE). 2 hard drives are a must but the system drive can be small(80 gig is plenty unless you plan on having tons of samples). I think 320-500 gig is plenty of audio drive for a casual user. The 450 watt power supply should be okay but I would up it to 550-600 watts. A good DVD burner is ony about $23 so no problem there. Are there any pieces from your old system that you can keep using(case, PSU, optical drive)? I know money is tight, but consider how long you hope to use this computer. That motherboard has no firewire so budget for an approved card if you want to use a firewire interface or external drives.
The performance difference between dual and quad cores is pretty steep. As for the threads that you feel are too long to go thru, just checkout the first 2 pages of each(and maybe the last 2) as you will get the most important info on page 1. Good luck
Now THAT is what i'm talking about... incredibly helpful response! Thank you so much!
As far as HDs, I'm not too concerned about too much space, but will definitely be getting 2 anyway. My record drive doesn't have to be too big anyway, because I have almost 2 TB of external storage that I transfer to when I'm not actively working on a session. My old PC was a '02 Gateway (yes! it has lasted me this long, and I STILL record/mix on it, believe it or not.. pretty impressive) P4 2.2 GHz, 1 GB ram. As far as video card is concerned, I was waiting to budget it until I got everything else squared away. My plan is try to keep things as budget friendly as possible for now (saving for a move from ME to Austin, TX in the fall) so do you think if I got that core2 now it would suit me fine until I had more money to blow and could upgrade it to a quad? The biggest reason I want to build my own is for upgrade options and to be able to buy what I NEED now, and be able to buy what i WANT later . And one last thing.. the power supply.. basically the same question as the core2 question above... will it do for now? Or will I be kickign myself when I get it all put together? The beauty is that I'm so used to just printing VIs that it's not going to kill me to not be able to go crazy with them. My biggest concern is verb/delay. I love me some delay... Sorry if that was incredibly long-winded, and thank you again for the help so far! Cory |
Macbook Pro 2.2GHz (late 2011 model), 16GB RAM, OSX 10.7.5 |
what about the Intel Core 2 Quad Q8400? Will this suit me? I'm still trying to cut corners on cost.. (and yes, I do understand that that means cutting corners on quality.) But will this be ok??
The Q8400 is a little short on L2 cache. The Q6600 is a better bet. The Q9550 is better yet. The price difference now is better than having to upgrade in the near future. But you will be the best judge of that.
is there an L2 Cache number i should be looking for? Like a "recommended minimum?" what exactly are the benefits of it in PT terms? (again, i'm new to building.. please be kind. haha)
Would this build and W8 work for PT10? | Kirby B. | Windows | 7 | 03-04-2013 04:31 AM |
PT just does not work, so should I build a new PC build or just but a MAC? | ajcsound | Windows | 17 | 05-17-2011 10:22 PM |
Think this build will work? | jmitchell1532 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 33 | 12-28-2009 05:36 AM |
Will this build work with 6.4? | mcintyw2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 06-11-2009 10:16 AM |
Anyone get Pro-Tools 8 To Work Without Issue On A P5K Quad Build? | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 01-11-2009 05:48 PM |
