Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | Intro Discussion
Old 02-24-2018, 08:18 AM
StaticBlue StaticBlue is offline
Default Pro Tools Activiation
I recently purchased the Scarlett Solo Studio which comes with Pro Tools First. After downloading iLok as well as the other indicated required softwares, I am still unable to activate my copy of Pro Tools First. On opening iLok and logging in I can see the Pro Tools option in the activation menu, and can even select it and choose the "Activate" button successfully. However when I then open Pro Tools I'm still met with the prompt asking me to activate my copy.
I'm clearly missing something here, the only explanation I can come up with is maybe it has something to do with the iLok activation code that is separate from the activation button? I was pretty overwhelmed by the amount of codes I initially received so it's possible I didn't see that if that's the case.
Old 02-28-2018, 08:10 AM
junkgear's Avatar
junkgear junkgear is offline
Default Re: Pro Tools Activiation
Can you try right clicking on the PT icon and choosing Run as administrator?
Will
System Details
Re-installed Pro-Tools 7.4. Activiation Details Missing from mydigi Matt Darcy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-04-2008 12:18 PM
