Old 02-07-2018, 02:28 AM
stefanboman stefanboman is offline
Default Monitor A/Phones out mono?
Haven´t used this output so much but surprised that my Xmon sends out mono.
Switching foldback doesn't´ seem to change anything.
Any ideas about this?
Old 02-08-2018, 03:04 PM
creativecontrol's Avatar
Default Re: Monitor A/Phones out mono?
Greetings,
Are you experiencing the mono fold for the other outputs like SLS, engineer headphones, Cue 1/2 which correlate to monitors c and d? Your main control room is unaffected correct?
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 02-09-2018, 04:17 AM
Control room and monitor C works perfectly.
As far as I can tell it´s only Monitor A. Guess thats what you call engineers headphones?
Headphones are connected straight from the 1/4" jack out from back of the Xmon.
Switching foldback from 7.1 to mono(over all)does not seem to affect Monitor A at all.
Old 02-09-2018, 08:47 AM
Yes, correct. Monitor A is mapped to engineer headphones for XMON. I presume you are using the factory DB15 breakout cable that came with the system? If all other monitors are happy it would appear to be a wiring issue. I presume you have tried swapping out the attached 1/4 cable yes? The next step in my opinion would be to try a new breakout cable.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 02-12-2018, 06:58 AM
You are absolutely correct Jeff! Thanks!
Just had to twist the headphone extension cord a bit and stereo came back.
Never heard that phenomenon before!
Live and learn!
Stefan
phones/monitor outs feedback and distortion lmno314 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-27-2011 10:51 PM
Mono Monitor for Mixing? KNM 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 09-07-2010 08:54 PM
003 Rack "Phones/Monitor" Potentiometer part number? ASAP! GordonFreeman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-17-2010 11:28 PM
Easy way to monitor my mix in MONO ??? BigRedButton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 05-04-2002 12:45 AM
Monitor OUTS only mono ! matej 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-05-2001 10:46 AM
