Old 12-06-2017, 06:46 AM
Anthony_Anz Anthony_Anz is offline
Default Re: EuControl v3.7.0/ Pro Tools | Control on iPad Pro doesn't work...
I think with the MAC OS there is a special "eucon cleaning" script you can try to run if you're having issues.. I'll see if I can dig it up.. I use a PC so I'm not 100% familiar with it..
** update **
give this a whirl.
http://avid.force.com/pkb/articles/e...nstall-for-Mac
Old 12-07-2017, 02:13 PM
Smithtrax Smithtrax is offline
Thank you... Felt like a lone wolf here! Been a ProTools user since Version 4 so I'm not a complete idiot but since no one was responding to the post I figured I must be the only one doing something wrong! Hopefully 3.7.1 will come out and I can use it again. Neyrinck V-Control until then I guess..
Old 12-08-2017, 08:33 AM
Ah.. I check this every day but I'm not a MAC user so I didn't jump in right away. Were you able to try the cleaning script? if so did it help?
Old 12-11-2017, 08:22 AM
Did the clean uninstall and ran the script and re-installed. Still no luck. The script pretty much just deletes the prefs files which I was going in and manually finding and deleting. So still not talking...
Old 12-11-2017, 08:35 PM
ah, that sux man.. so, just going back and re-reading the thread. are you not on 12.8.2 x106? -- I don't see why that would make a difference since you should be getting the "E" regardless of what PT version you're running. I'm just grasping at straws here.. I'm surprised Eddie hasn't jumped in on this yet..
** nevermind ** you said you were ON x106.. sorry.. You may want to shoot Eddie Jones a PM.. maybe he's seen this before...
  #16
Old 12-12-2017, 03:53 AM
Appreciate your input!!
  #17
Old 12-17-2017, 07:29 AM
EddieJones's Avatar
Have you tried running EuControl from Applications ?
The EUCON Control Panel is only for setting up HUI/Mackie Apps.
  #18
Old 12-18-2017, 03:43 AM
Thanks Eddie! Now I do feel like an idiot!! Always thought the only way to access the Eucon stuff was through the system prefs. Problem solved!
  #19
Old 12-28-2017, 10:02 AM
JGM JGM is offline
Did Eddie’s recommendation solve your issue?
  #20
Old 01-20-2018, 02:26 AM
Yes
BUG: Eucontrol 3.6.1 assignable knob doesn't work with application lock Raphie Artist Series 1 09-25-2017 04:18 PM
Pro tools control iPad Pro Sir_MixAlot Avid S1, S3, Dock and Control App 7 08-21-2017 09:20 AM
EuControl/Workstation 3.3 & Pro Tools | Control iPad app now available! Kyle Splittgerber Avid S1, S3, Dock and Control App 0 08-06-2015 02:59 PM
Can I control Pro Tools with an Ipad south89 macOS 4 04-05-2013 09:36 AM
