Old 03-01-2018, 07:44 AM
Juan Garcia Juan Garcia is offline
Default Fader and monitor issues
Greetings!
We've recently come up with a very strange problem. Fader #8 of the first fader module on our surface behaves as a master volume control for the Xmon.
I've tried swapping fader modules but the issue continues. It doesn't matter which kind of track is assigned to the fader. Any change of value alters the volume on the speakers.
In the monitor section, after pressing the MAIN SPEAKERS button control room volume resets. This is super odd!
It is awkward and super annoying. Any thought on this?
EDIT: you can see the problem in this video
Best,
J.
Old 03-01-2018, 04:03 PM
laki laki is offline
Default Re: Fader and monitor issues
Seems like the wrong MIDI data is being sent to the Xmon.
Have you added any new MIDI gear or altered your MIDI setup in any way lately?
Does this happen all the time or intermittently?
Does it clear up after a restart?
Old 03-01-2018, 07:27 PM
EddieJones's Avatar
What happens if you shut the S6 and Workstation down and then restart and connect ?
Old 03-01-2018, 08:35 PM
This is happening all the time. I noticed this oddity on Monday but got to diagnose in-depth yesterday. The only additional MIDI device that could have been used recently is a MIDI Keyboard. This is what I've tried,
EDIT:
I forgot to mention that before doing the following I swapped fader modules 1 & 2 (both have faulty faders, my first appointed culprits) with modules 3 & 4 which were in proper conditions. Reconfigured the S6 surface and updated all modules.
Audio MIDI Setup.
Removed all MIDI devices except USB2MIDI, including Network and IAC configurations. Nothing changed, as expected.
Pro Tools.
Opened Peripherals dialog box. Noticed USB2MIDI was declared under the MIDI Controllers tab as HUI protocol. Disabled and restarted Pro Tools and S6. Nothing changed still.
Xmon App.
Disabled and reassigned USB2MIDI as MIDI port. Still nothing.
S6/WS.
Removed and reassigned WS within the S6 settings. WSControl soft reset. No difference.
Am I missing something?
Thanks,
J.
Old 03-01-2018, 09:47 PM
EddieJones's Avatar
Is it always fader 8 ? Are you working in banking or Layout mode ? What track is on Fader 8 a PT track ?
Old 03-02-2018, 11:04 AM
I haven't been able to replicate the issue today. Fader 8 is behaving well. It USED to be always the 8th track in Pro Tools.
I'll post back if I find anything unusual.
Thanks,
J.
Old 03-07-2018, 12:16 PM
Hi All!
It seems the problem was caused because of the USB2MIDI being used as HUI protocol within the Peripherals dialog box.
There's still an intermittent issue, though. Occasionally the Control Room does not reproduce any sound until the "Main Spkrs" button is pressed in the monitor section.
Any ideas?
Thanks
J.
Old 03-08-2018, 09:17 AM
creativecontrol's Avatar
This is exceedingly strange, however I will attempt to repro it with my XMON on my rig. What version of XMON app and what OS are you on? Thanks.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 03-13-2018, 12:29 PM
The XMON app is running version 2.1.0 and the S6 software is 3.7.0.134
Thanks,
J.
Old 03-14-2018, 08:36 AM
Thanks. Unfortunately I was unable to create a scenario where I can make this behavior happen. Please let us know if you can still make it fail in the latest - 18.3 version of S6 or if you have a reproducible recipe on 3.7.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
HOW I CAN DO MONITOR ON MASTER FADER CZARUŚ VENUE Live Sound Systems 5 03-31-2007 09:37 PM
Can I ...pre fader, pre plugin Monitor?? McMasters Pro Tools TDM Systems (Mac) 7 06-21-2005 07:37 AM
Mbox: 2nd fader possible for monitor volume? P_M_C 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 01-12-2004 03:15 PM
Fader pack and Monitor section adessa ProControl, Control|24, Command|8 5 01-20-2002 03:03 PM
Can I monitor my FX Buses without being Pre-fader? Nine Spine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-11-2001 02:02 PM
