Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
Old 05-14-2019, 05:28 PM
orangepopsongs01 orangepopsongs01 is offline
Default Komplete Kontrol Broken in 2019.5
Ever since I installed 2019.5 and instantiated Komplete Kontrol the knobs and buttons no longer respond. Piano keys, pitch wheel and mod work but all other knobs don't. After several Uninstalls and reinstalls it works in stand alone, Ableton and Logic but as soon as Pro Tools is opened and KK instantiated the knobs stop working in PT and all other programs as well as standalone.
Native Instruments has been unresponsive.
Old 05-14-2019, 08:19 PM
Neale Neale is offline
Default Re: Komplete Kontrol Broken in 2019.5
I see this too. Mac OS 10.12.6. No need to reinstall for me, restart fixes it. Open Pro Tools, not even with a session, and it breaks again.
Old 05-14-2019, 09:09 PM
Same here. Looks like restart fixes it in other apps and then just opening Pro Tools kills it.
Old 05-14-2019, 09:37 PM
massivekerry massivekerry is online now
The latest KK software wasn’t even working properly with 2018.12 for me.
Old 05-14-2019, 09:40 PM
Was for me.
Old 05-14-2019, 10:09 PM
arche3's Avatar
arche3 arche3 is offline
2019.5. Hdx. Cheese grater. Kkontrol works perfectly inside vepro7 inside protools. Fyi.
For those of you using vepro7 for VIs.
Sent from my SM-G975U using Tapatalk
Old 05-14-2019, 10:19 PM
Try Komplete Kontrol outside PT after starting the program, see if it still works?
If it does, maybe this is only an issue with Vanilla Native?
Old 05-15-2019, 07:37 AM
Sean Bombz Sean Bombz is offline
Hey guys, I've had the same problem since 2018.12 with maschine mk3. There is a thread on this issue over at Native Instruments. Someone figured out that it was a specific plugin within Native Instruments causing the problem.
Go to Library/Application Support/Avid/Audio/Plug-ins and find
FB360-Control-ambiX.aaxplugin
Move it to the Plug-Ins (Unused) folder
It should not freeze your hardware after that. At least it doesn't freeze Maschine mk3
Sean Bombz
Mac Pro late 2013 3.5GHZ 6 core 64g ram
Mojave 10.14.5
Pro tools 2019.5
Apollo x 16
Apollo 16 mk2
Apollo twin mk2
Avid S3
PT Dock
PT control (iPad)
eucon 2019.5.1
Old 05-15-2019, 12:10 PM
This was suggested to me by Avid overnight. Kudos to them for the speed and usefulness of the workaround.
Old 05-15-2019, 09:03 PM
arche3's Avatar
Kkontrol on an instrument track works fine for me. Just tried it. Stand alone works fine as well.
Pro tools & Komplete Kontrol Thuser Virtual Instruments 5 12-20-2017 03:46 PM
Komplete Kontrol S88 not recognized WaddyP Pro Tools 11 6 02-03-2016 09:28 PM
NI Komplete Kontrol hosts VST AU in AAX Rectifried AAX Plug-ins 2 01-21-2016 02:28 PM
Komplete Kontrol S61 KaneStarkey Pro Tools 12 0 11-09-2015 05:14 AM
PT and Komplete Kontrol LAMEREALM Virtual Instruments 25 05-26-2015 05:58 AM
