Old 02-15-2016, 01:01 PM
fcurran fcurran is offline
Default Pro Tools 12.4.0 not working with Reason 8.3.2d7
I have a brand spanking new system, OS x 10.11.3 El Capitain, Pro Tools 12.4.0.
I installed Reason 8.3.2 but in a PT session, on any audio track, Reason does not show up when I try to setup and Insert instrument.
Has anyone seen this or done so successfully?
Old 02-15-2016, 02:29 PM
PhilSchroeder's Avatar
PhilSchroeder PhilSchroeder is offline
Default Re: Pro Tools 12.4.0 not working with Reason 8.3.2d7
First, see this to make sure you're running Reason in 64-bit mode.
See this in the event that you need to trash your prefs and have PT rescan for Reason. This happens to me every once in awhile.
MacPro 2013, 12 core, 48G RAM
OS 10.14.6
Apollo x6 & Twin
Pro Tools 2019.10
Avid Artist Mix (2)
Old 02-16-2016, 01:04 PM
Thanks Phil but these suggestions did not work for me.
First, both PT and Reason are running in 64 bit mode.
I have OS X 10.11.3 El Capitain, Pro Tools 12.4, Reason 8.3.2d7
There are only two users on this system: frankcurran and Shared
Under /Users/Shared/Library there is no folder named Avid
Under /Users/frankcurran there is no folder named Library
I also checked under /Library
Under /Library/Preferences there is no folder named Avid
I did a Spotlight search for a file named InstalledAAXPlugins searching the entire Macintosh HD.
No files by that name were found.
Anyone have ideas for what I should do next?
--Frank Curran
Old 02-16-2016, 01:51 PM
YYR123's Avatar
YYR123 YYR123 is offline
search the web for the terminal command to show the library that your looking for...it is hid by default
here it is...
http://www.idigitaltimes.com/mac-os-...folders-493856
disclaimer, I do not take responsibility for what you may do to your system..... :^0
Daniel
Old 02-16-2016, 02:46 PM
K Roche's Avatar
K Roche K Roche is offline
--Frank Curran
You don't access it through "User" or the Library in Macintosh HD.
It's in the hidden Library accessed from the "Go" tool in the Finder tool bar at the top of screen
To unhide it go to Finder > Hold down the "option" key and Click "Go" then in drop down then click "Library" > Preferences ( the Avid folder should be right at the top.) in that folder open Protools and trash "Installed AAXPlugins" then go back to Preferences and at the end of the com.apple ...plist's.... will be "com.avid.ProTools. plist." trash that
Then when you launch PT it will rescan for plugins and hopefully get Reason
System :
Avid HD Omni I/O Interface ...Mid 2010 Mac Pro/ processor- 3.33 6-core Intel Xeon "Westmere" w/ Memory- 24 GB, Radeon Pulse RX 580 8GB GDDR5 Dual HDMI Graphics Card..... OS- Mojave 10.14.6, and PTHDN 2019.6 on on primary boot drive (SSD PCIe 512 GB Samsung SM951) FCPX files storage on Samsung 970 EVO 1TB and PT sessions storage on 2nd Samsung 970 EVO 1 TB -- both in dual drive Crest I/O PCIE controller adaptor card
"Peace cannot be kept by force. It can only be achieved by understanding" Albert Einstein
Enjoy the Journey
.... Kev...
Old 02-16-2016, 02:47 PM
Many Thanks YYR123. That worked perfectly!
The Library folder was hidden as you say. I used cmd+shift+G, entered ~/Library, then navigated to Preferences/Avid/ProTools and there was the file InstalledAAXPlugins. I deleted it and restarted PT. Success! PT rescanned plugins and Reason appeared correctly in the Insert list.
Whew! Is this the way for a World Class product like PT? Make us delve into these delicate directories and manually delete files?!? I think maybe a better way is to just have a function/menu item within PT to "Rescan Plugins". The user clicks on that and the rest is handled via software. Just my 2 cents.
Thanks all,
--Frank Curran
Old 02-16-2016, 07:33 PM
indieric indieric is offline
Frank,
Thank you for sharing this very important step.
Eric Klee Johnson
Producer & Mix Engineer
The Pop Machine
eric@thepopmachine.com
www.facebook.com/erickleejohnson
www.twitter.com/erickleejohnson
www.thepopmachine.com
Old 02-16-2016, 07:56 PM
YYR123's Avatar
Truly a wonderful idea, no joke
Daniel
Reason 8 With Pro-Tools 10 Not Working troycross Pro Tools 10 3 02-16-2015 06:04 AM
Axiom keyboard presets 10 in Reason not working (Slaved in Pro Tools) bryandugans Pro Tools 10 0 04-11-2012 12:03 AM
Reason Adapt not working in Pro Tools 8 !!HELP!! cgraebe90 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-25-2009 07:49 PM
Pro Tools LE and Reason 4 w/ Rewire not working. cringe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-12-2008 02:28 PM
The best way to get reason working with 5.2 Tranquil 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-04-2004 11:32 PM
