Old 05-12-2012, 01:06 PM
jrmintz jrmintz is offline
Default WTF happened to drumagog 5?
I've been a Drumagog user for a LONG time. Yesterday I opened Drumagog 5 for the first time in a while to do a snare replacement - PT hangs. I reboot, trash prefs, reopen the session and try again - same thing. So at this point the producer says, "Screw it", and I'm going to have to take money off the bill for down time. I've been looking around and I see lots of people are having the same issue. I uninstalled, reinstalled the latest version. Nothing. On their forum they say they can't reproduce the problem. Here I see lots of people having the issue. What's going on? Have they written off the product? Has anybody found a solution?
I have to finish this project Monday and if I have to buy another piece of software I'm a former Drumagog owner.
Old 05-12-2012, 01:14 PM
AINSLIE's Avatar
AINSLIE AINSLIE is offline
Default Re: WTF happened to drumagog 5?
make sure you are on the latest version. Reinstall. Make sure your authorization works. Other than that typical PT system mainintence esp Permission repair would be appropriate.
http://www.ainsliegrosser.com/
2013 MacPro 6 x 3.5 32GB OS10.14.4 HDX2 Sonnet Chassis, PT2019.5. Macbook 2018 Watch this to follow mobile mix studio build coming: https://youtu.be/cbqMTjCVj9I
Old 05-12-2012, 02:08 PM
WernerF WernerF is offline
Get Slate Trigger. It works flawlessly.
Old 05-12-2012, 03:42 PM
All done, made no difference.
That's probably my next move, but I hate to just write off the money I have invested in Drumagog
Old 05-13-2012, 02:06 PM
Chris-Drumagog Chris-Drumagog is offline
Sorry you're having trouble--you should also make sure you've gotten the most recent InterLok drivers. Please send us an email with your system specs to support(at)drumagog.com and we'll work to resolve the issue.
Thanks,
Chris
WaveMachine Labs
Old 05-13-2012, 05:02 PM
Hi Chris,
Thank you. I downloaded and installed the most recent ilok drivers and it made no difference. Unfortunately I have clients in the morning and I've run out of time to mess with this. I've purchased other software which is working fine. I've been a Drumagog user for around 10 years and I regret having to switch, but I can't be left hanging (literally) with paying clients looking over my shoulder.
Old 05-14-2012, 12:06 PM
crizdee's Avatar
crizdee crizdee is offline
I had to trash the "drumagog prefs" user/library/prefs to stop this!!
Since then its been working ok, with only an occasional quit whilst browsing some libraries.
Chris
Producer, Engineer,
Slow Readers Club_Build A Tower top 20 UK album charts
www.ukmastering.com
PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Old 05-14-2012, 07:19 PM
dtmprod dtmprod is offline
Originally Posted by crizdee View Post
Chris
I'm having problems too with PTHD 10.1.3. Just tried trashing the drumagog prefs as well, no luck...
Old 05-15-2012, 02:57 AM
crizdee's Avatar
I haven't tried on 10.1.3 but it was working on 10.1.1 and 10.1.2
I think i had to repair desk permissions as well.
I would manually remove drumagog from the plugins folder, trash the drumagog prefs again and repair disk permission. reboot and re-install the latest version and see what happens.
Chris
Producer, Engineer,
www.ukmastering.com
Old 08-31-2012, 12:05 AM
smpkeys smpkeys is offline
I just bought the upgrade to drumagog 5, and am having the same trouble.
I'm on PT 10.2. I tried all of the above - current iLok drivers, deleted drum agog prefs, deleted PT prefs, repaired permissions, restarted.
Even if I open a new pro tools session and create one empty track, I get the spinning beach ball of death as soon as I insert the plugin.
I usually wait a while with new software before I purchase to make sure they got the bugs out, but hasn't this been out since spring?
Anyone have any luck or other workarounds?
2010 Mac Pro, 3.46 GHz 6 Core Xeon,32 GB RAM, OSX 10.9.5, PT 12.4, RME Fireface UFX, Command 8, Mytek 8x192, SSD evo on System,Audio&Samples on spinner drives WD SATA 64mb Cache
Drumagog to midi or drumagog to BFD options? crizdee Pro Tools TDM Systems (Mac) 36 11-04-2008 03:16 PM
drumagog v4 and pt 7.1 usd Pro Tools TDM Systems (Mac) 7 04-24-2006 07:48 PM
Drumagog 4 learning Pro Tools M-Powered (Win) 5 01-20-2006 11:08 PM
Drumagog rock15478 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 12-24-2005 01:03 AM
DRUMAGOG anyone use it? IntelDoc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 02-12-2004 01:00 PM
