Old 02-12-2012, 02:12 PM
tystick420 tystick420 is offline
Default I/O help
i somehow switched my input and output to my Mac speakers and mic. I cant figure out how to switch it back to my 3gen mbox. iv played with the I/O settings but just made things worse. *need beginner help*
Old 02-12-2012, 03:19 PM
cneal92's Avatar
cneal92 cneal92 is offline
Default
Setup menu > Playback Engine
At the top select your interface from the drop down menu.
Chris Neal :: SPC
.: cneal@southplainscollege.edu
.: Certified PT Instr. & Expert
:: Sent from my iPhone
Chris Neal :: South Plains College
.: Program Coordinator & Asst. Professor in Sound Technology
.: Pro Tools Certified Instructor
.: Pro Tools Expert Certified in Music
Old 02-12-2012, 10:04 PM
Default Re: I/O help
thanks, but it still is recording off my laptop! not through my mbox. any more ideas?
Old 02-12-2012, 11:09 PM
YYR123's Avatar
YYR123 YYR123 is offline
Yeah after selecting the Playback engine you should go back to the i/o setup...
This will let you visually see what is going on...You could select default's and see where that gets you...
I personally will save the i/o setup based on my current playback device...before i change the Playback device....
Then switch engines and i/o's and then when you want to go back to the first just load saved version (import settings i believe it's called).
The version of PT that you are running should have a general default for the Mbox3.....look under import settings....and then load Mbox3 default i/o's
Daniel
[IMG] code is Off
