Old 12-19-2007, 07:06 PM
fasttraxx fasttraxx is offline
Default Can You Use Plugins on Instrument Tracks?
How can you automate a plugin (delay, verb, etc..) on an instrument track? I have inserted a plugin on a instrument track, but there is no sound from the plug in. I can see that the autmation is working on the plugin, just can't hear it. I am guessing this is because it is a midi track and no sound is produced.
Thanks and God Bless!
Y.B.I.C.
Bill
Old 12-19-2007, 07:28 PM
Stig Eliassen's Avatar
Default Re: Can You Use Plugins on Instrument Tracks?
Yes, you can automate plugins on instrument tracks. Do you have a VI instantiated followed by another plugin, or a different scenario? What are you trying to do, and what goes wrong?
Old 12-19-2007, 11:48 PM
Stiff Stiff is offline
How can you automate a plugin (delay, verb, etc..) on an instrument track? [...] I am guessing this is because it is a midi track and no sound is produced.
Is it a MIDI track or an instrument track? Use the instrument track and make sure that the plug-in is AFTER the instrument in the chain.
Daily news & reviews
www.ProToolerBlog.com
Old 12-20-2007, 11:34 PM
I can make the plugin work after the VI, but not if I have, let's say 3 instrument tracks and they are all going to Reason. I guess the only way this will work is if I have a VI for EVERY instrument track.
Y.B.I.C.
Bill
Old 12-21-2007, 04:42 AM
Argh...see what I mean (I didn't even remember that I had asked approx. the same question in this thread)?
Old 12-21-2007, 05:28 AM
ondruspat ondruspat is offline
I take it from your posts that you have the sound from Reason coming back into PT as a stereo mix from Reason. When I run Reason I usually have separate MIDI tracks for each module of Reason I'm using, then have each module routed back to PT through it's own aux track (Rewire initiated on each aux set to it's own Rewire channel, modules routed through Reason's "hardware interface" module). Add inserts on the aux channels.
"Sometimes having limits keeps you sane"- Albee1952
Old 12-24-2007, 07:55 AM
DonaldM's Avatar
DonaldM DonaldM is offline
This is correct. Create mono or stereo aux tracks, depending on what you need, and then place a delay on one, reverb on another etc (as many as you want). Then, route the output of your audio or instrument track to the AUX track for the effect you want. Then you can control the input/output of the effect for each track.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
Old 12-26-2007, 03:03 PM
Thanks ondruspat and Donald M,
This seems to be the answer I was looking for. I forgot about routing in Reason and then inserting on individual auxes.
Happy Holidays
Y.B.I.C.
Bill
Old 12-26-2007, 04:53 PM
DonaldM's Avatar
Happy Holidays
Glad it helped. Have fun!!
2 instrument tracks each controlled by different MIDI input/instrument Midimax Pro Tools M-Powered (Win) 0 03-20-2012 03:10 PM
Applying Instrument Tracks to Reg. Audio Tracks d00m1001 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 03-13-2009 08:55 PM
MIDI Tracks Versus Instrument Tracks. VERY Confused. Rick540 MIDI 8 12-04-2008 11:04 AM
Time Adjuster plugins NOT working on Instrument Tracks! Horea 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-07-2008 06:02 PM
No Instrument Insert on Instrument tracks Bazbo Virtual Instruments 4 03-01-2007 06:00 AM
