Old 11-06-2002, 02:22 AM
ahmie ahmie is offline
Default Why play the loop with sustain pedal softerand softer??
I play the SSC in live
I creat loop preset my self
when I play a key and hold dow the sustain pedal
The loop sample Softer and softer until no sound
Why play the loop with sustain pedal softer and softer??
Help me !! Thx!!
ahmie
Old 11-09-2002, 12:45 AM
Kevan Staples Kevan Staples is offline
Default Re: Why play the loop with sustain pedal softerand softer??
I've been using SC for years and I've often wondered the same thing...I have no idea why it doesn't work as one might expect.
Kevan
Old 11-10-2002, 09:19 PM
Nick Batzdorf Nick Batzdorf is offline
Sounds like you need to look at the amplitude envelope.
Old 11-13-2002, 02:48 AM
no..unfortunately that isn't the issue. By default the sustain pedal is assigned to the release portion of the AMP env. It has a maximum value of 99 which more or less means it extends the release time by some unknown value. So..if the release is set to .1 seconds then all it does is hold the release for a period of time as defined by this 99 value but during that period of time the amplitude is constantly dropping just as it would during a long release time. If one lengthens the release time then this period of time is greater but still dropping in amplitude. If the value were infinity then one might get infinite sustain but that just isn't possible.
Kevan
Old 11-13-2002, 06:07 PM
jeffro's Avatar
jeffro jeffro is offline
This function mimics the behavior of a piano, where the notes slowly fade out as if the keys were held down.
What are you trying to do? Maybe there's a workaround...
Old 11-19-2002, 01:22 AM
Thanks Jeff
Yes...and it does perfectly imitate a piano style release. What would be nice would be if we could have the sustain pedal hold the sustain level at one level until the pedal is released. This is how 'most' hardware synths work. With that one could keep a looped sound repeating for quite a long time..if need be.
Kevan
HTML code is On
Sustain Pedal Not Working Numi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-24-2009 02:34 PM
Make my sustain pedal a kick pedal dr beef 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-11-2005 01:20 AM
Make my sustain pedal a kick pedal dr beef MIDI 0 05-08-2005 11:14 PM
Sustain Pedal and Reason cuethevocals 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 07-18-2004 12:50 PM
Sustain Pedal stut5 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-04-2003 12:45 PM
