Plugin Issues [solved]
I have 10 sessions and this is only randomly happening on a couple and with WAVES plugins it seems so far.
The session opens fine and plays fine with active WAVES plugins inserted. When I attempt to open any of the plugins the plugin pops up but shows as blank white .. then the session crashes. I delete the PT preferences and same thing. I can't seem to figure out where the WAVES preference is on Win. 8.1. C/User/Usernames/Library does not exist. I don't have a library folder at that path. I even tried importing new session, deleting PT preferences, removing all plugins to just have 1 plugin on the session (in case I had too much processing going). WAVES works fine on other sessions and on new test sessions I created. I just randomly have a couple that do this and I can't figure out why and how to fix this. Ugh Any things you guys think I should try? Or know where I could find the WAVES preference to remove it? The sessions worked fine a few days ago .. not sure what happened that this just now started happening. Cheers |
Re: Plugin Issues
Update - seems that Melodyne is causing this issue for me when I use it as a plugin. It happens on PT 12.2 and the 12.4 update. If I print melodyne track to a new track then disable the melodyne track and then re-import session data everything goes back to normal.
What a pain .. I'll have to contact melodyne about this one I guess. |
Re: Plugin Issues
while I haven't updated to 12.4 yet, I CAN tell you that Melodyne worked fine as a plug in in 12.2 and still does in 12.3.1 for me
Re: Plugin Issues
Melodyne works perfectly fine here on 12.4 HD in both OSX 10.8.5 and 10.11
Have stayed far far away from El Cap and will not update until we absolutely have to which may take a while
Re: Plugin Issues
melodyne works fine for me. 12.4 on 10.10.5
tuning vocals at the moment. |
Re: Plugin Issues
melodyne worked fine for 12.2 and 12.4 .. after doing some more pulling out of my hair I now finally figured out everything is fine including WAVES. The issue was I was running 3 monitors while editing and when I unplug 1 of the monitors the issue doesn't happen. Appears that the WAVES plugins don't support or like the 3rd monitor.
I just got off the phone with WAVES and they even confirmed this. |
Rewire issues with PT 11.3.1 on Mac 10.8.5 (Solved) | Mark The Frog | Pro Tools 11 | 0 | 08-25-2015 03:21 PM |
Registration issues - SOLVED | JGlen | Pro Tools 10 | 1 | 08-03-2013 03:38 PM |
Anything solved on these issues? | gives | Pro Tools 10 | 0 | 10-11-2012 07:19 PM |
This release has solved many of my issues! | euphoria89 | Windows | 0 | 10-23-2011 08:35 AM |
plugin settings all gone... [SOLVED] | macakinho | Pro Tools 9 | 2 | 11-24-2010 06:29 AM |
