Old 10-20-2019, 11:58 PM
russelaid russelaid is offline
Default Melodyne 4 compatibility
Hi all,
I have a problem with Melodyne 4 essential plugin.
I use PTF and have recently purchased from avid.com marketplace melodyne 4 essential. My problem is that the plugin is not loadeding in PTF.
I did the tests on different windows 7 pc (i7 and i5 core), I tried PTF 2018.7, PTF 2019.6 and PTF 12. I also did some tests with an old version of Melodyne (editor 2). I checked that the aaxplugin file is in the correct folder (C:\Program Files\Common Files\Avid\Audio\Plug-Ins\Melodyne.aaxplugin\Contents\x64). Nothing, the plugin does not load, Melodyne works fine in standalone mode but the plugin don't load in PTF.
I bought the plugin from avid.com and not the application, can this be the problem?
Is there anyone who has had a similar problem?
Thanks.
Francesco Romoli
Old 10-21-2019, 06:21 AM
ChuckS ChuckS is offline
Default Re: Melodyne 4 compatibility
You bought it from the Avid store which supposedly is required for third party plugs to work in PTF - so good there. How about iLok issues? Does the plug require a license update on your iLok? Regular Melodyne uses iLok auth, but don't know if different for plugs bought via Avid store.
PT 2024.3 DP 11.31 VEP 7.x with various VIs
NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11
MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11
MOTU M4 on MacBook Air M2 2023 Sonoma.4.1
Old 10-21-2019, 06:24 AM
Hi, welcome to the community.
I think licensing should be okay since the standalone application launches. Therefore contact Avid Support and ask them to help you.
Old 10-21-2019, 06:26 AM
It would seem not, I registered my plugin by entering the serial number and was immediately redirected to a celemony page, where I can check the status of my license. On my ilok license manager there is no entry for M4.
Old 10-21-2019, 06:29 AM
Hi, I talked for several days with celemony support but they couldn't help me. Now I'll try Avid support, thanks.
Old 10-21-2019, 07:08 AM
Just to be sure, you can open the standalone application (outside PT), right? Because that won't open if your licensing is screwed.
Old 10-21-2019, 07:11 AM
Yes, in standalone mode it works fine.
Old 10-21-2019, 07:30 AM
Then I'm pretty sure you don't need Celemony help, but Avid Support should figure out why it doesn't work in PT even though you bought it from Avid Marketplace. Just open a support case and let's hope you won't need to wait too long
Old 10-21-2019, 07:32 AM
Ok thanks.
All I know is there is this knowledgebase article, which says 3rd party plugins are not supported on PT 1st, but since you bought it from Avid Marketplace it kind of should work.
Melodyne ARA Compatibility Giba Pro Tools 12 19 05-26-2018 04:37 PM
Pro Tools First Compatibility with Melodyne Essentials 4 rgpinder Pro Tools 12 1 03-11-2017 07:43 PM
Melodyne Users - Melodyne Editor Beta release imminent! Driven01 Pro Tools M-Powered (Mac) 2 09-18-2009 06:31 AM
Melodyne Users - Melodyne Editor Beta release imminent! Driven01 Pro Tools M-Powered (Win) 2 09-18-2009 12:15 AM
Melodyne and Protools 6 compatibility. kizzer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-26-2008 09:35 AM
