How to install ProTools 10 trial on Mac w Pro Tools Express running Mavericks?
It was suggested that I try the full version of Pro Tools, before buying the upgrade from Express. I tried installing Pro Tools 10.3.7 and I get the warning:
Incompatible Pro Tools VersionBefore I do anything, as I have experienced so many gotchas, I want to be absolutely sure I know what I need to do to uninstall Express so that I can reinstall it later. I will want to use or upgrade Express after my full Pro Tools trial is over. Mac Pro 2 x 2.8 GHz Quad Core with 14GB ram running Mavericks 10.9.5 Thanks |
Welcome to the community.
Since you are running on Mavericks you should install the Pro Tools 11 Trial (PT10 is not supported on Mavericks or later, Mavericks support was added in 11.0.3). Also, since PT10 isn't supported on Mavericks, you'd need to manually remove files as instructed here.
• linkedin •
We currently have PT Express installed and working fine... I don't want to mess this up in his quest to try out the full version upgrade. If we had the Avid m version ( not the m-audio) version of Express, could we upgrade that on Mavericks? I read that you can't install PT Express on a Mac with Yosemite, but I do not know which version of PT Express that was referring to. Is Avid not aware that a lot of studios are still using PT 10? |
Thanks musicman,
Pro Tools Express on Mavericks | groovilator | Pro Tools 10 | 3 | 04-07-2015 11:08 AM |
Pro Tools Express not compatible with Mavericks or Yosemite | DigiTechSupt | Pro Tools Express on Mac OS X | 0 | 01-13-2015 04:02 PM |
Pro Tools Express on OS X 10.9 Mavericks | Paxil | Pro Tools Express on Mac OS X | 7 | 06-09-2014 12:52 PM |
Protools Express 10.3.3 and Native Instruments FM8 on Mavericks | GraemeC | Pro Tools Express on Mac OS X | 4 | 01-11-2014 09:26 AM |
