midi is getting recorded 50 mS late
1. I record a midi track of quarter notes using a midi keyboard while listening to an imported audio metronome track. (No softsynth inserted).
In other words, I play along with an audio metronome track. 2. I look at the midi track and compare with the audio metronome track in the edit window. 3. I observe that the midi notes are all about 50 mS later than the audio metronome track. If I duplicate this setup in a different DAW (Sonar) with same keyboard, same midi interface, the midi notes are lined up as expected with the audio metronome track, with a normal human variation of +/- 5 mS. Help! What is happening? What setting do I change to make Pro Tools midi function without timing problems? Pro Tools 12.3.1 on a PC. EDIT: The midi delay is related to my asio buffer size. I currently have it set to 512. if I set it to 64 the recorded midi delay is reduced proportionately. There has got to be something to adjust to fix this. Anybody have a suggestion? Last edited by mikedocy; 12-12-2015 at 10:50 AM. |
Re: midi is getting recorded 50 mS late
iam going to try this as well....
last time i had a problem like this...i was running an apollo....I assumed it was related to that but I am now running OEM hardware....so i hope it's not an issue.....anymore.
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
You need to put the buffer at 64 or 128 for starters. Beyond that, I have never had this issue. Maybe check preferences to see if you accidentally set a midi offset
PC Dell XPS 8700, i7 CPU @ 3.40GHz, 4 Core(s), 8 Logical Processor(s). 32 GB RAM, Windows 8.1 Recording Pro-Tools 12.4. Mbox Pro 3 (Driver 1.1.10) FireWire CPU Interface w/ Presonus FADERPORT. |
Pro Tools's recorded audio is delayed. Wave file written late on the grid. Unreliable | SHRED | Pro Tools TDM Systems (Mac) | 15 | 09-24-2013 03:15 PM |
Overdubs being recorded LATE? | Doug Hamblin | macOS | 1 | 07-24-2012 12:03 PM |
Recorded MIDI is late... | Stig Eliassen | Pro Tools TDM Systems (Mac) | 21 | 05-31-2011 09:20 AM |
Recorded audio is late. Any ideas on how to fix this? | stingerns | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-29-2009 02:33 PM |
Recorded Audio late by 3000 samples (MBOX) | melat3mg | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 12-08-2004 09:01 AM |
