PT hangs for 1-2min before starting up
I've tried to find whether someone has the same issue but either I'm searching for the wrong words or I'm alone on this. Basically, PT12 always needs forever to open up, sometimes more than 1min (it's always slightly different), doesn't matter whether it was open already and I shut it, it takes forever - the app logo bounces, it goes to the screen with the loading bar but that one just doesn't load, until at some point it's happening. I've tried quitting and leaving the Avid app manager along, different USB sockets in case it's the ilok...no luck. Any idea what it might be? It's the same on my Macbook Pro (2012) as well as on my Mac Pro (early 2009). Both have plenty of space, resources, RAM, CPU etc. Any clues? Thanks, Peter |
Re: PT hangs for 1-2min before starting up
This could potentially be Pro Tools having trouble getting access to/information on the audio interfaces. What version of OS(X) are you running? And what interface do you have?
Shift Studios Computer: Custom Built PC Mobo: Gigabyte Aorus Z270X-Gaming 7 CPU: i7 7700k MEM: 16GB Corsair Vengance DDR4 3000 GPU: Gigabyte Aorus GTX 1080Ti Extreme OS: Windows 10 Pro x64 DAWs Pro Tools 12.7.1 Interface: Universal Audio Preamps: Focusrite, Universal Audio Outboard Processors: Universal Audio Control Surfaces: AVID S3, Pro Tools | Control + Pro Tools | Dock |
Thanks!! I'm on OSX 10.8.5 with a RME Fireface UFX via Firewire. Could try to use just the internal one?
I'd say start by making sure your system is not using the Fireface for audio. Also, do you have any third party plugins installed?
Try using USB rather than firewire to connect the UFX and see if that helps.
Have you also done all the Avid optimizations and do you have the right RME drivers for your version of OS X?
@ShiftStudios
Never had an issue with that before, PT10 works fine, but will see if that helps. And yes, got lots of 3rd party plugins but it hangs before it does the 'scanning' of the plugins. Hmm. @TheWeed Okay, I'll give that a go. I have the right RME drivers, interface works great. Not sure I have done all optimisations - where do I find them? I switched of certain shortcuts as well some energy settings but, apart from that? Where can I check, here on the forum or on Avid's site? THANKS! |
I've noticed doing a system clean,(deleting temp files etc..) on the main drive or defraging effects the loading time of the program. Once this is done once, it never seems to go back to the loading speed it had at install. However the less you do it, the faster it will load, eventually getting close to the original speed. It might be beneficial to turn off any programs you have that do this automatically like: system mechanic, etc. I assume when you do a clean you're erasing connections that the computer has to re-establish. This seems to effect the locating/recognizing of plugins which makes loading take longer.
Doesn't take more than 25 seconds on any of our Macs. MBP 2013 / 2014 and Trashcan mac. What hard drives do you have? Is it a 5400rpm or 7200 or SSD?
Also trash preferences and databases and restart to see what happens. But we need the specs of that MBP
Just starting out... | Colwill0311 | Pro Tools SE and Essential (Mac) | 25 | 08-25-2010 11:23 AM |
Delay between PT starting and BFD starting | Baritonealone | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-01-2008 03:58 PM |
PT7 not starting | joematzzie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-14-2007 03:44 PM |
Starting out... | scottedog | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-07-2003 06:49 AM |
Pro Tools hangs up on starting..... | markgr82nz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-30-2001 02:24 PM |
