Go Back   Avid Pro Audio Community > Legacy Products > ProControl, Control|24, Command|8
Old 08-27-2018, 07:33 PM
ToneSetter ToneSetter is offline
Default Re: pro control db25 cables for monitor section
How do you guys go about connecting your monitors to the pro controls monitor section with db25 cables? My monitors are about 4 to 5 feet apart which seems farther than the cables will spread because the db25 cables are wrapped till the end of the cable where it fans out to the 8 trs or xlr cables.
Do you use a short db25 to female trs or xlr and connect trs or xlr cables to those that go to the monitors and the headphone amp?
Old 08-28-2018, 06:11 AM
YYR123's Avatar
YYR123 YYR123 is offline
Yeah I always use, adaptors off of the main cable, whatever they may be to reach.
I build my own cables just so I have exactly what I need and so they don’t cost a fortune.
I never used the PC as a monitor unit, I always had 3rd party units for monitoring....just because they were more robust, offered more io and were lots cleaner.
The PC was great as a control surface but it didn’t have a great monitoring control sound...especially this far into the game.
Daniel
Old 08-28-2018, 03:09 PM
Delta Music Belgium's Avatar
Delta Music Belgium Delta Music Belgium is offline
Each connector is a risk, the soldering could be bad or wrong, contacts can oxidise, connectors can come loose, etc... So in theory the best way is to go straight to the monitors without additional connectors.
But using a short db25 and extend it with extension cables will work fine too. Make sure you use xlr and not trs, because xlr connectors do make contact on a large surface (it's a large pin within a large buss) while trs connectors do make contact on a very small surface (point-to-point).
Marc Schellekens
Delta Music Belgium - Dolby Atmos Music Studio
https://www.deltamusic.be
Mac Pro 2019 - 3.2GHz 16-core - 96GB RAM - macOS 14.4.1 - PT HDX3 - Pro Tools Ultimate 2024.3.1 - Avid HD I/O 16x16 (x2) - Avid HD I/O 16x16 Digital - Digidesign 192 I/O - Digidesign 192D I/O (x3) - Avid SYNC HD - Apogee Big Ben - Apogee Rosetta 200 - Avid S3 - Slate RAVEN MTi2 (x2) - iConnectivity mioXL (x4) - Genelec ‘The Ones’ 9.1.6 Dolby Atmos Music monitoring (AES/EBU) with 8341A (x5) + 8331A (x10) + 7360A (x2) + 9301B - Almost all available AAX-DSP plug-ins
PLEASE HELP!!! Control 24 Monitor section SURGING!!! Table Syrup Records ICON & C|24 2 01-07-2008 07:56 AM
Upgraded monitor section on a Pro Control? joesgarage ProControl, Control|24, Command|8 2 10-16-2006 05:31 PM
control 24 monitor section woes insolace ICON & C|24 4 05-18-2005 09:30 AM
Monitor control room section Tomio Broman ProControl, Control|24, Command|8 1 05-19-2003 10:57 AM
Pro Control Monitor Section-Please Read Techsupt2 General 0 11-03-1999 03:38 PM
