Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | Intro Discussion
Old 11-08-2017, 04:49 PM
LivingThings LivingThings is offline
Default Delete unused clips from project
Hi all,
I have a bunch of unused audio clips in one of my current projects and the project won't upload because I am running out of cloud storage space. I would happily buy more storage space if I were sure to be able to control what I am saving on the cloud. Is there anybody who successfully managed to delete unused clips in Pro Tools First 12.8? I have tried several approaches without success.
The most common approach seems to be the one described here:
Originally Posted by Carl Kolchak View Post
In the clip / region list menu :
1. select unused region.
2. clear selected.
3. when prompted to choose between "remove" (clip region from session) & "delete" (file from hard drive), select "delete"
To avoid being asked / prompted for every audio file, hold down the Alt key when you choose "delete"
Just be damned sure you really want to do this, as the files are deleted directly from within Pro Tools, rather than moved to the trash, so it's not possible to undo once you've committed.
However, how am I supposed to remove the files if I cannot find the clip region in Pro Tools First 12.8?
Any help would be much appreciated.
Old 11-08-2017, 05:40 PM
amagras amagras is offline
Default Re: Delete unused clips from project
Ctrl+Shift+U to select unused clips, Ctrl+Shift+B to clear, Alt+Click on delete or move to trash.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 11-08-2017, 08:53 PM
Hi amagras,
Thanks for your reply. It worked! However, the program still throws an error when syncing with the cloud.
Error: file size exceeds available cloud storage
At this point I believe that I just need to buy more cloud space. I still have some doubts on the reliability of the cloud storage mechanism though. Logically, a project with less clips should take less storage space. However, it looks like when I deleted the clips the program attempted to upload the information but it failed. In fact, cloud storage space occupation did not change.
CLIPS > Select > Unused is unchanged after running Delete Unused SigFriedChicken macOS 1 07-02-2017 09:25 PM
Deleting Unused Clips ReynaldoPena Windows 3 12-02-2012 01:44 AM
Drag Clips = Delete Clips??? Connor macOS 2 07-09-2012 07:50 PM
select unused will delete unused jimlongo Pro Tools TDM Systems (Mac) 4 04-04-2001 06:39 AM
Delete unused Descriptive 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 06-02-2000 05:00 AM
