Massey DRT vs slate trigger
Who's had experience with both?
I'm looking to get one soon ! Thanks guys Also what's the audio suite version in PT 10.3.7 look like? Any stability issues for DRT ( that's the way I'm leaning)
Re: Massey DRT vs slate trigger
I haven't used both but I had trigger 1 which was very good but trigger 2 is awesome great samples, great interface and easy to use to excellent results can be achieved quickly and easily
Raoul Crane
www.blaze-studios.co.uk PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis |
Thanks R. The samples I heard in the video had pretty heavily ambiance'd room feel in them
It kinda turned me off. How many samples come with trigger2
There are loads depending on what version you buy I brought trigger platinum so I got all the samples you can use your own to. The samples are dry and you can mix in the ambience as you like :)
Raoul Crane
Also there are several expansion packs. Chris Lord Alge for example. Great for heavier stuff.
iMac Pro - MacOS 10.14.6 --- - Pro Tools U HDN 2019.6 - Avid HD Omni + HD I/O 8x8x8 - C|24 | S3 | Dock |
Yep I have the CLA and Terry Date expansion packs they are both awesome !!!!!!
Raoul Crane
They're kind of two different products. DRT is primarily for analyzing a drum track and outputting midi, whereas Trigger is for drum replacing on the spot in real time. Trigger also has a way to output midi, but I haven't explored it much.
I find DRT to be kind of clunky to use, and I feel that Trigger is way more versatile in every way. If you look at the product descriptions on Sweetwater for Trigger EX and Trigger Platinum, it gives an idea of the difference. The main difference is the number of different samples. Platinum has about 4 times the amount as EX. Another difference is that Platinum now has an extra feature which is some kind of gating tool. For only $50 more, it's definitely worth it to get Platinum. They also have various expansion packs that are excellent. Note that the various expansion packs, and the stock Trigger samples, are the same as those available for Steven Slate Drums 4. The only difference is that the Trigger stuff does not include any cymbals or hi-hats. Also, there are more and more 3rd party companies making samples that are compatible with Trigger. Very good ones, I might add. And, Trigger comes with an easy to use tool called the Instrument Editor (a separate application) that makes it very easy to convert WAV files and make your own samples that work in Trigger. These could be drums that you record yourself, or other existing WAV files. As for the Slate samples, I find them to be more useful than many would have you believe. They take additional processing very well and I find that is the key to making them fit your music. All of the Slate samples have both close miked and ambient perspectives, and you can mix/blend them the way you want. So don't be put off by what you heard. Finally, both these products have demos available, so you can check it out yourself. DRT is a lite version, but gives you a basic idea. Trigger demo comes with a couple of kicks and snares to give you an idea how it works, and limits a few features. |
If you like you can have a look at this track at about 2:50 to listen to some kick and toms, as I have used them in a metal track with Trigger 1:
http://deadwoodvoid.bandcamp.com/tra...ng-the-earth-2 Apart from the cymbals I replaced all drums with Slate samples on the entire album.
Nice sounds / thanks NST7 - I was planning on getting the demo's after I record a session next week.
So I will check them out - still looking at videos for each
I use both, depending on the situation.
I find DRT a lot more flexible compared to Trigger2. Creating a midi track means I can use all manner of VI's to replace the snare - mainly a couple of NI drum libraries of BFD2. Trigger2 is a lot more straight forward. Just slap it on a track, choose your snare sound and go. I really dislike the snare sounds that come stock with it though. Over processed and not my thing, tonally.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command. |
Slate Trigger 2 (AAX 64 / 32 & RTAS) | crizdee | AAX Plug-ins | 12 | 10-15-2013 01:53 PM |
Slate Trigger questions | bonzerboy | The Drum Room | 1 | 12-11-2012 03:32 PM |
FYI - Slate Trigger EX | jmitchell1532 | Pro Tools 10 | 0 | 12-10-2012 08:55 AM |
for all Slate Trigger users... | elicious | General Discussion | 1 | 08-15-2012 04:57 PM |
Slate Trigger Outputs | Siegfried Meier | Pro Tools TDM Systems (Mac) | 9 | 11-27-2011 11:05 AM |
