Relinking issue with MXF audio
I´m having a problem with one reel. My workflow is AAF with external MXF media. I´m upresing 16bit MXF to 24bit while doing the "copy media" option when doing the AAF import. Problem is that there are about 10 files that PT refuses to relink. The files are 110% on my drive and have the identical file ID. I´ve tried the following: deleted DBs (about 20 times) ran applejack relinked by name only Things I haven´t tired yet (but I´m close to doing it): -Buy some TNT and blow up my PT rig nothing works. The strange thig is that ALL the cross fades between those files in the sequence are rendered out and audible so PT DOES know where the audio is and processes it. Only the actual clips do not relink. I´ve opened the same reel with a different cut before and it worked fine so relinking has worked before. But now it just doesn´t. Any further hints besides reinstalling PT 5.1.3 and doing the relinking there ? Frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Re: Relinking issue with MXF audio
Tim |
PT searches about 10minutes through a single folder (where those files are) but no candidates are found.
It takes me about 1 minutes to find the files manually in the finder, BTW. Does anyone know where to buy TNT in Berlin?
never mind.
I´ve "solved" it by copying the extracted session file from another member of the crew.
Timothy |
frank.
This obviously is only for cases, when there's only few files Pro Tools is unable to relink - for whatever freaking reason.
Timothy |
After that the files files are still off-line. Render sources-folder is gone. Now they are off-line and no chance to relink. Repeated operation gives a message that "files are different Fs that session" (oh really?! sigh...). I guess this feature is simply buggy.
In the Relink window do the files it's looking for have the same name, modified date and unique ID as the files you're trying to relink to?
Name, length and ID are identical. creation and modification date is N/A. (the modification date can´t be identical anyway because I´m working on a copy of the avid media-files) One strange thing I found is that the file PT marks off-line is an MXF file but the "Format" collumn says "wav". The original file that I´m trying to relink however shows "MXF" under format. Which is why PT says the format does´t match. But even when I de-select "match format" and relink only by name the files are not accepted. Length is identical BTW. Frank.
Relinking audio issue in 10?? | albee1952 | Pro Tools 10 | 3 | 10-29-2012 05:47 PM |
Help relinking audio | Tom Case | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-15-2010 08:47 PM |
Issue Relinking Files in PT7.4 for sessions created in 7.3? | corym | Pro Tools TDM Systems (Mac) | 0 | 07-10-2008 08:55 AM |
relinking issue | tshev | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 04-30-2005 04:51 PM |
Audio relinking | Strider | Pro Tools TDM Systems (Mac) | 2 | 11-12-2003 10:56 AM |
