Old 06-12-2003, 07:58 PM
The Zone The Zone is offline
Location: Middle of Virginia, just far enough away from civilization to be able to relax.
Default ACCESS DENIED???
Okay class, I got a strange thing happening and I know you guys can help me with this because you always do.
When I finish with a Pro Tools 5.1 session, I will burn a data CD of all the various files onto CD and store it. Simple enough, right?
Time passes. I need to re-edit something so I re-load the session. It loads in perfectly and comes up perfectly.
Problem: I highlight a part of one of the songs and try to alter it using one of the many "Audio Suite" things I have at my disposal, and it refuses to work. I get this error message that says "ACCESS DENIED" How do I get rid of that???
I can record NEW THINGS into that session and edit those . . . it's just not allowing me to edit things that have been loaded from CD.
This is probably pretty simple, but it's got me whooped. Thanks. [img]images/icons/shocked.gif[/img]
Mac Pro running OSX 10.5.6, using Pro Tools LE 7.4.2/Digi 003/Digi C24 w-DV Toolkit 2, a pair of Avalon 737 VT-737sp's, Great River MP-2NV, RME OctaMic II, pair of Mackie HR-824's, my best mics? a Neumann U87 and a Royer R-121 . . . best amps? Bogner Ecstasy 101B and a Bogner Uberschall-Revision Blue . . . All my drums are BFD2 triggered by Roland TD-20s kit, with live Zildjian cymbals, Korg Triton LE 88 with weighted keys . . . lots of other toys that make beautiful music . . .
Old 06-12-2003, 08:06 PM
Rudger Rudger is offline
Default Re: ACCESS DENIED???
I'm taking a guess here. When something is burned to CD it is changed to a "read only" file. Go to the session folder in windows explorer, right click on it, select properties and uncheck the read only check box. I think that should fix it. Good Luck, Jason
P4 3.2,ABIT IC7,875P chipset,512 Ram,Digi 002,LE 6.7
www.jasonwhinnery.com
jason@jasonwhinnery.com
Old 06-12-2003, 08:07 PM
Roy Howell Roy Howell is offline
Let me ask you, when you get the files from the CD, and copy them back to your drive (before opening them in PT), are you unchecking 'Read-only' files from them?
If not, here's the easy way(just in case you may not know).
1.'Select all' the files on the CD.
2. Right click any one file(with all of them highlighted), and uncheck 'Read only files'. ALL the files will become unchecked. Choose 'Ignore all' if it comes up.
3.Copy all
4.Paste to the drive of your choice, and open the PT session.
As I say, you may know or be doing this, but if not....
~Roy
rh music
Old 06-12-2003, 08:10 PM
So, you saved it to CD, and now you're trying to work on the copy that remained on the hard disk, or you restored from CD first?
I'd look at the folder and files to see if anything has been set to 'read only'
Quad 2.5 G5, 4.5G RAM
Old 06-12-2003, 08:40 PM
Scoobster Scoobster is offline
yep I throw my support behind the read only solution.
Cheers
Oh what do you think graveleye!! [img]images/icons/wink.gif[/img]
Scoobster
Old 06-13-2003, 09:44 AM
Haigbabe Haigbabe is offline
Cheers
<font size="2" face="Verdana, Arial">Check file attributes.
Oh and then reboot! [img]images/icons/wink.gif[/img]
Haigbabe
Drive fast, take chances
Old 06-13-2003, 12:32 PM
I will try that and get back to you guys on this . . . . that makes perfect sense.
Thank you
Access Denied? sharpo07 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-13-2011 07:55 AM
Access Denied! Zetajazz44 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 11-30-2004 02:27 PM
Access Denied Please help! lancegoiter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-15-2004 08:06 PM
Access Denied VividMax 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-20-2001 11:38 PM
access violation/access is denied dj_czech 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-02-2001 01:37 AM
