Control 24 sharing between 2 computers
Ok, so I have an LE setup sitting aside a Mix setup, and I need both in there for different things. How can I share the Control 24 easily?
To be clear, I don't intend to switch back and for between active sessions, although that could be cool too. I'd like to be able to have it hooked up on a hub or something so that whatever system fires up will see it. Is that all I need? just a hub? Or do I need a switch? Anyone? I'm sure somebody has done this. I do realize that I probably won't be able to switch between active sessions, at least not without manually disconnecting the Control 24 in peripherals and then refreshing peripherals on the other system. Not sure I'd ever need to anyway. I'd either be using one system or the other in most cases. The keyboard, mouse and monitor will be shared on a KVM Switch so it'll be quick to flip. Monitors (spkrs) will share through a phoenix gold selector. Just wanna figure out how to easily have the Control 24 connected as well. Anyone? Thanx
Shorty: Table Syrup Records Mac Pro 5,1 3.33 GHz Hex, 32GB EFI Flashed - 5 GT/s Modded 7950, Dual Apple 23" OSX Sierra Pro Tools HD 11.2.2 Waves IOS, IOX, STG2412 Extreme Server (x2) Logic Pro X, DSP Quattro, Final Cut Pro X Waves Mercury+SSL+AbbeyRoads Trident S65 with embedded US-2400 Live: 2012 Mac Mini, Dual SSD, i7 2.4, 16GB Win 10, OSX Sierra LV1, MRSG Hardware from above (same gear) Dual Dell P2418HT Touch Screens Waves Icon X (x2), M, with Screens Custom enclosure |
Re: Control 24 sharing between 2 computers
Shorty,
You can probably just wire up a switch box for it. Not sure the ramifications of switching stations for ethernet, but it should be possible. |
Wouldn't be hard to wire, it's just 8 wires per cable. Check out AEI in golden valley, they should have everything you'd need to make it.
It might be more practical to just buy one though, there's probably some company that makes one already. |
+1 for John
Is it a regular ethernet cable (CAT5) on the control 24? I thought it had some form of looping going on or something similar!! It may be more complex than you first thought. If it were a normal cable you could easily build a switch but I am sure there is something different about it, just can't remember off the top of my head. Good luck trying though.
A:)
I Love Audio!!! |
I guess what I will try first is just hooking up through a hub or a switch. A hub will probably do it. If only one system has Pro Tools open at a time, then only one will be trying to see the Control 24 and I shouldn't have an issue. I think.
Hub - good
switch - better Router - best But you're right a hub will probably work. |
Hub - good
Switch - better if other devices are attached to the same physical network, such as another computer. If it's just the computer and the 24, no difference (all other things being equal) Router - an actual router is not relevant in this equation. the connection between the computer and the Control 24 is Layer 2 networking (think MAC addresses), not Layer 3. Routing happens at Layer 3 (think IP addresses). You may be referring to something like a Linksys router, which is actually just a switch between the LAN ports. Which brings up an interesting point. In a dedicated, no-internet computer you can turn off all that stuff under the networking properties except the Digi driver. My computer has no MS Client, No IP address, etc. Just the Digi driver and it works fine with the 24. |
ilok sharing between 2 computers | ronwasserman | Pro Tools HDX & HD Native Systems (Mac) | 9 | 03-10-2013 05:10 PM |
Lets Talk Screen Sharing (Remote Control) | therecordinghouse | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-15-2010 10:19 AM |
Sharing a video in same session for ADR (video in booth and video in control room) | Boogie457 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-01-2010 04:52 PM |
session sharing between computers | jesseleyh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-03-2003 01:16 PM |
Sharing one Opcode Studio 4 with 2 computers? How do I... | ckerian | General Discussion | 2 | 04-03-2002 09:03 AM |
