Old 11-18-2015, 09:56 AM
Sausage Mexicane Sausage Mexicane is offline
Default Recording MIDI cymbal chokes
Having recently put my new setup together (see system spec for details) I am starting to record the MIDI drum track for my first song, but notice that the cymbal chokes that I recorded (and could hear on the monitor mix during recording) do not sound choked on playback, i.e. the full cymbal decay can be heard instead. I'm using Roland V-Drums with a Roland TD-8 drum module and I'm using this as both the trigger to MIDI interface and for playback of the drum sounds. I guess this may have something to do with the MIDI setup in Pro Tools (input filter?) but otherwise I'm a bit stuck. I can't work out from the TD-8 manual, which MIDI parameter (controller?) relates to cymbal choking and how to make Pro Tools record this data. Can any of you clever people please help me out?
PS I know I could get round this problem by editing the MIDI data and replacing the un-choked crash sounds with choked ones, but being a 'real' drummer, I want to get this correct at source.
Old 11-18-2015, 10:07 AM
thanos4 thanos4 is offline
Default Re: Recording MIDI cymbal chokes
i had this issue once...and if i remember i "solved" it by deleting the aftertouch from midi editor...For some reason it recorded totally wrong data
Old 11-20-2015, 08:13 PM
Oli P Oli P is offline
I have the same problem...and the data is "polyphonic aftertouch".
It sounds right during recording, but at playback nothing happens.
In the midi event list, I made sure the polyphonic aftertouch is not filtered, but it still won't play the chokes.
The polyphonic aftertouch data in the midi event list, shows it to be 000 ...and if I change those values manually to 127 it will choke...but will also choke all the other un-choked notes it is supposed to leave alone...
Bottomline...a useless mess
www.olipoulsen.com
iMac27 i9 3.6 (late 2019) / 64 GB Ram / OS 10.15.7
Apollo 8 / PT Ultimate 2020.9.1
Old 11-21-2015, 04:30 AM
Have any of you tried posting ab out this over on the Vdrums.com forum? Might want to give that a try. Primarily a Roland forum.
http://www.vdrums.com/
Jack
QAPLA!
PT 10 Chokes bad on Midi keyboard input MusicByDesign Pro Tools 10 10 07-10-2015 10:01 PM
What does the length of a midi cymbal note really do? DC-Choppah Tips & Tricks 9 01-07-2013 06:03 PM
G5 dual chokes while recording and Power Book does Coastside Music 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 17 08-20-2006 09:43 PM
protools chokes on midi program change rslander MIDI 3 07-06-2006 06:57 PM
Creating a MIDI trigger from an acousitc snare/cymbal? j20056 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-24-2002 04:50 PM
