  #31
Old 02-27-2007, 01:54 AM
25ghosts 25ghosts is offline
Default Re: A new & free helper application for ProTools
yes - please include the "Freeze Killer" and Database Corrector ))))
No - Your app is truly SUPERCOOL....
Thanks A Lot
25
2016 MacBook Pro Retina | 16GB RAM | 1TB SSD | OS X Latest - PTHD 12 Latest | 4K LG Thunderbolt Display | Logic Pro 10
  #32
Old 02-27-2007, 02:55 AM
crizdee's Avatar
crizdee crizdee is offline
I'm making the version 2.
Am I forgetting something?
JC
A way to get paid for your labours donation ware should help!
How about being able to move all the files to a specified location/folder!! this way it could be used for backing up your prefs when they are fresh and all working well, and also it would enable them to be placed back in to situ if the pref trashing wasn't the problem etc.
This would help a lot especially when doing cs updates etc that overwrite certain prefs and folders.. midi patch names and stuff like this that gets blatted when doing updates.
Great app
Chris
Producer, Engineer,
www.ukmastering.com
  #33
Old 02-28-2007, 06:50 AM
colinweeks colinweeks is offline
Instead of a big button with predefined files, it will be a BIGGER BUTTON with check box on the side to select a custom set of files, plus a backup/restore preferences option (but not for the Digidesign Database folders -a V3 feature-), and maybe an icon and a French translation.
It will include the ~/library/application support/digidesign/databases/Volumes, ~/library/preferences/ByHost/com.apple.Midi.1231xxx.plist, ~/audio/Midi Configurations.
JC
definitely being able to archive/restore preference files would be great... if there was a way to make it a startup item so that everytime a user logged into the OS protools preferences would be restored to 'x'... that could be fun.... would you want to archive the digi databases? wouldn't that cause havoc somehow?
anyhow, great work, greatly appreciated... digi should send you a check....
  #34
Old 03-04-2007, 07:47 PM
Zep Dude Zep Dude is offline
Being able to restore (replace) the prefs files would be a better idea. I have a set of "clean" prefs that I keep in a folder with all the optiones for PT set up the way I work -these are virgin uncurrupted prefs. I drag these into the prefs folder instead of trashing prefs so then I don't have to set everything back up. I make an alias of the prefs folder in the system and an alias of the backup prefs folder so I just have to double click each then drag between windows.
Angelo
Majestic Music
www.majesticmusic.com
  #35
Old 03-06-2007, 11:32 AM
wasabi wasabi is offline
Default Re: Free Pro Tools Application - Delete Prefs/Database
Thanks a lot!!!!
GREAT!!!
www.artesuono.it
  #36
Old 03-06-2007, 11:53 AM
smlworld smlworld is offline
It occurred to me that when you create the portion that saves the 'good' prefs you might want to add the I/O settings to that as well. Not that they get corrupted but for those of us who use other machines it would be a cool way of 'remembering' to grab them....
in fact I think i would take the app and my 'good' settings with me and install them on the rental machines.
anyway - just a thought.
[img]/images/graemlins/tongue.gif[/img] <<<<< in the psychiatric emergency handbook this is bad news.
  #37
Old 03-07-2007, 02:00 AM
[email protected] feldy67@earthlink.net is offline
This does not trash databases in library-app support-digidesign-databases. Thank you for this tho
  #38
Old 03-07-2007, 02:11 PM
JC925602 JC925602 is offline
Just one week or two for the next version with close to all the requests. I was a little bit busy.
JC
  #39
Old 03-10-2007, 10:17 AM
Will this work for LE or is it TDM specific?
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
  #40
Old 03-10-2007, 10:42 AM
works both.
Can't find Pro Tools 8 prefs to delete in Mountain Lion Cartoonguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-18-2012 09:48 AM
trash database and prefs in P T 8 ??? not2tech Pro Tools TDM Systems (Mac) 1 10-06-2009 12:32 PM
I delete prefs and the Database open session then system crashes 8.0.1 philip888 Pro Tools M-Powered (Win) 8 09-10-2009 06:42 AM
Free Pro Tools Application - Delete Prefs/Database JC925602 Pro Tools M-Powered (Mac) 1 03-21-2007 03:04 AM
Free Pro Tools Application - Delete Prefs/Database JC925602 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 03-18-2007 11:20 AM
