Old 12-08-2016, 12:53 AM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
Default 12.6.1 / aae-9173 anyone?
Hi guys,
I agree with everyone that 12.6.1 is a solid step in the right direction. MIDI and breakpoints have been solved. Apparently, so has the click issue. Good work, Avid.
However (I'm on Windows 10), I still get -9173 errors even when CPU usage is 25%. Never had this prior to PT12. Every other DAW I know handles CPU efficiently. Is anyone else still getting these errors?
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins
Old 12-08-2016, 01:27 AM
Seafoam_Green's Avatar
Seafoam_Green Seafoam_Green is offline
Default Re: 12.6.1 / aae-9173 anyone?
Originally Posted by lesbrunn View Post
Hi guys,
Yes I got the 9173 the other day with just one single V.I instance running .., all I was doing was checking out the MODO Bass.
Pro Tools 2021.6.0 Native * Slate Raven MTi-1 Version 3.9.1 * AVID MBox3 Pro * OSX Mojave 10.14.6 * MAC PRO (late 2013) * 3.0 GHz 10-Core Intel Xeon E5 * 64 GB Ram 1866 MHz DDR * AMD FirePro D700 6GB * Lacie LBD 1TB Thunderbolt 2 PCiE * Blackmagic Multidock Thunderbolt2 * Samsung SSD's 850 Pro * WD Black HDD's
Old 12-08-2016, 02:36 AM
lesbrunn's Avatar
Hi Seafoam,
Has it been just this one time or does it happen frequently? I've lost where I saw this, but someone else was literally getting these things like almost every five minutes... I get them maybe 4-6 times a day, sometimes even when I've disabled core 0.
I haven't been able to put a finger on what actually causes this thing, but for me it usually happens during editing, either MIDI or audio.
Old 12-08-2016, 07:25 AM
TOM@METRO's Avatar
There are things I can do that will always cause these errors, but other times they happen here without a clue as to why.
Always post what you were doing when you get them, Avid is working to solve this, but they need any information you can offer.
Even posting dlogs here may help.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 12-08-2016, 10:04 AM
rinky rinky is offline
It's still happening here. Not as frequent as the previous versions but still a nuisance, to say the least, especially in front of clients.
PT Ultimate 2024.3
PT HDX
MacPro 7,1 (Intel)
16 Core
96 GB ram
macOS Ventura 13.4
Somehow, musicians are now technicians!
Old 12-08-2016, 08:45 PM
Hi Seafoam,
It happens randomly , always when using MIDI . I was also getting it more with the last version , but it certainly has not ended the errors in 12.6.1
Old 12-09-2016, 01:28 AM
Downtown_BE Downtown_BE is offline
a lot of -9173 here when using midi and instruments
not at all when just mixing with plugins.. I compared 12.5.2 and 12.6.1 both on the same machine (I have 2 systems running) and its exactly the same with -9173 errors
I think its more a problem of the way those software synths use memory and cpu power than protools itself..
Old 12-09-2016, 03:16 AM
abes abes is offline
I always have Bluetooth and WiFi off when running Pro Tools 12.5.2 on 10.10.5.
I received the 9173 error the other day. My WiFi was on. Turned it off, now back to a stable system.
It's worth a try.
Old 12-09-2016, 03:32 AM
lesbrunn's Avatar
Hi guys,
Thanks for posting. I was beginning to think I was doing something wrong. I know workarounds that reduce the frequency, but it's still a serious nuisance. Other than that, 12.6.1 is a definite improvement over the other versions after 12.4
Old 12-09-2016, 03:43 AM
lesbrunn's Avatar
Thanks Tom,
It's good to know Avid is aware, and that they're working on it. Hope it happens soon!
Aae -9173 frcjt Pro Tools 12 17 03-27-2016 08:09 PM
PT 12 - When 9173 is not actually 9173? taft_mashburn Pro Tools 12 2 10-06-2015 09:28 PM
Cpu 9173 mistermackum Pro Tools 11 1 12-20-2014 02:20 AM
Aae-9173 txrx Pro Tools 11 5 12-28-2013 04:34 PM
