Old 01-26-2020, 03:56 AM
The Saxplayer The Saxplayer is offline
Default Importing Audio vs Session Data
I could not figure out a proper title for this thread but here is my issue.
I have added audio from another drive to a session (without copying it unfortunately) that will obviously only show up if that drive is connected.
I have made a "copy to" of the entire session which copies all audio to a new session but I was wondering if there is a command to bring the audio from the other drive to the audio folder of the current session without the need to copy.
Furthermore I have started to work with a template and when I import session data to match tracks with my template tracks the audio is not copied but remains in the original session which brings me back to my initial question.
Thanks for sharing your thoughts!
Georges
Thanks very much
Georges
The Saxplayer
Old 01-26-2020, 04:07 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Importing Audio vs Session Data
Copy without copying? Not that I know of.
But if you did copy the audio file(s) to your session folder and disconnected the original source drive, then next time you open session it says this and that file cannot be found and asks you to relink. Then you can tell PT to search your session folder and it should find the manually copied files from there, because all files have unique ID that does not change when you manually copy the file from external drive to your session folder.
Makes sense?
Janne
Old 01-26-2020, 04:23 AM
priorytools priorytools is offline
Makes sense?
If bringing in just a couple of "new" audio files, I quite often just check that all audio has the current session location selected in the disk allocation window, then just select the new audio in the edit window & press "Option+Shift+3".
Of course this will only consolidate the clip not the entire parent audio file.
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG
~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~
Old 01-26-2020, 04:35 AM
Thanks. I have manually copied audio files into a session now and Protools did find them.
However I have a large project where I fear that I might miss some, so I was hoping there was an option to consolidate everything together.
Consolidating the track using option+shift+3 is a neat workaround since it creates a new file in the folder of the audio session.
That is at least one good solution, and you only keep what you need. Which may be an issue if you need to go back to select different audio ...
Cheers
Thanks very much
Georges
The Saxplayer
Old 01-26-2020, 04:36 AM
JFreak's Avatar
Sure, that's a quick and dirty way of doing that. Of course, a new file is created with a new ID but who cares, gets the job done. What I suggested brings in the whole original audio with few clicks.
Janne
Old 01-26-2020, 05:53 AM
I agree JF.
Maybe the op should just save copy in to consolidate his situation . . ?
Old 01-26-2020, 05:57 AM
JFreak's Avatar
I agree JF.
Maybe. Depends how many files are out there. If just a few, fixing the session is faster. IF most of the files are on externals however, Save Copy In is very straightforward
Janne
Old 01-26-2020, 08:20 AM
gwhatley's Avatar
gwhatley gwhatley is offline
I like to open the Workspace Browser Window (option+semicolon),
click on the session icon on the left pane, then click on the "Audio Files" folder;
from the columns generated in the right pane, click on "Path" to sort by Path.
From here it is easy to see audio files that are outside of your main session folder. You can select them all, them right-click on one of them and choose "copy and relink". Choose where you want the new copies to be (presumably within your main session folder), and... There they go.
Sent from my LG-H872 using Tapatalk
Garrard Whatley
Seismic Post Audio
Post Audio for Film and Television
System/Hardware Info
IMDb credits
Old 01-26-2020, 02:29 PM
gwhatley's Avatar
What I like about this workflow:
(1) it is immediately evident, without any hunting/pecking, what files are from outside your session folder.
(2) you can choose to copy and relink these files to an organized folder (e.g., "cues from composer") if that's important for you.
(3) you get the full file, so no loss of heads and tails that would result from consolidating
(4) you can keep your original session with all of your previous versions and session file backups, which may go by the wayside if you were to instead do a "Save Copy As..."
It's easy, flexible, and built-in to pro tools.
G.
Garrard Whatley
Seismic Post Audio
IMDb credits
Old 01-26-2020, 02:54 PM
G.
I fully concur.
Waveforms increase in size when importing audio file as session data import myeviltwin Pro Tools 2018 4 02-10-2018 02:20 PM
PT 11.3 no longer importing audio files along with session data jsbeeth Pro Tools 11 3 02-25-2017 04:28 AM
Can't find 16 bit audio files when Importing Session Data DavidCaporale macOS 0 04-23-2015 08:50 AM
MBox - importing session data, missing audio!? spike.mk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 01-08-2009 08:42 AM
Problems importing audio, session data, etc. essay Pro Tools TDM Systems (Mac) 0 09-12-2006 10:18 PM
