Old 11-02-2012, 06:11 PM
boboroshi boboroshi is offline
Default Digi002R Not working with PT10, but does with Logic
I am running 10.6.8 with PT10 (10.3.2)
I used the system a week ago to bounce a track for mastering, unplugged everything from the wall for the hurricane, and plugged it back in and fired up the racks today.
The unit looks fine, and audio-midi setup recognizes is and shows it as 18in/18out. Upon starting ProTools, the 1394 light goes out. It works fine with Logic tho.
I have cleaned the white/clear power connectors with contact cleaner, uninstalled (including DAE) and reinstalled 10.2. Same issue. Upgraded back to 10.3.2. Same issue. After each upgrade, I installed the newest driver for the 002
Anyone have any ideas?
Old 11-04-2012, 02:36 PM
jasonthurley's Avatar
jasonthurley jasonthurley is offline
Default Re: Digi002R Not working with PT10, but does with Logic
So when the light goes out does PT give you an error message?? Does it just quit or open with no hardware use? Any more information will help
Old 11-08-2012, 09:58 AM
Jason - it does not throw an error message. The light goes out while the splash screen is up and it's loading plugins. Once open it defaults to ProTools Aggregate and no longer shows the Digi002 as an option. Audio/Midi Setup, if opened after PT10 boots and the light goes out, shows the Digi002, but only as a 2in/2out interface and it won't let you select it.
If, after a restart, you fireup Core Audio Manager, you can select the Digi002 and it has the full I/O structure (and is usable by Logic).
Old 11-19-2012, 07:43 PM
anyone?
Old 11-19-2012, 07:49 PM
drguitar drguitar is offline
If it's working with Logic, then you know it's not a hardware problem. You need the latest driver. Then it will work fine. My 002 is fine in 10.3.2 with 10.8.2
Just do a search for the latest 002 driver for OS X
Old 11-20-2012, 10:21 AM
Okay, I'll try that again. had reinstalled both the 002/003 driver as well as PT 10 on my dedicated drive. Is there an order one should do this? Driver first? PT first?
Old 11-20-2012, 11:12 AM
Nope, whether you install PT first or the drivers first doesn't matter.
002_and_003_Family_Drivers_v90_r3_73509 is the current version, and I believe it's been mentioned that Avid plans to release a new version sometime in the foreseeable future.
Old 11-20-2012, 12:37 PM
Piers Gibbon Piers Gibbon is offline
and you've done the old "hold n key down on PT startup" to double check it is in full comms with the 002 presumably
www.piersgibbon.com
www.soundcloud.com/piersgibbon
VOICEOVER - Avalon 737sp/Focusrite Saffire Pro 40/Neumann + Rode inside an Esmono voiceover studio (+ Source Connect, Prima LT, Sonifex TBU, Sonnox plugins)
Record: MBP 13 inch mid 2012, 2.9 ghz i7 8gig ram, PT 11, GDrive Professional Ext Hard Drive
Backup:15 inch early 2008 MBP, OSX 10.10.2
(+Windows 7 PC running Audio TX isdn and tbu codec)
Edit: PT Express 10.3.4 on 13-inch, Late 2010 MacBook Air, OS X 10.10.4
Old 12-03-2012, 06:51 PM
holding down N does get it to register, and the light comes back on, but it only shows 1-2 I/O and actually plays out of the internal speaker in the tower.
Old 12-03-2012, 11:39 PM
Siege Recordings Siege Recordings is offline
Have you tried going into the I/O setup menu in PT and hitting 'default'. it usually gets all your inputs and outputs back.
www.corosoniclab.co.nz
Noise on L channel of my 11R only when using SPDIF to connect to Digi002r w/PT10. SchweineMeister Eleven Rack 6 11-08-2012 10:27 PM
Digi002r, PT10.2, Errors Seen Thus Far Greg M Windows 1 06-01-2012 09:02 AM
Digi002R with Logic Pro 6.4.3 maxcarella 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-07-2004 03:07 PM
Can I use Logic Audio with Digi002R? BigRedCat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-23-2003 06:45 AM
Digi002R Core Audio not working w. Cubase SX2.01 BrownMan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-12-2003 04:22 PM
