Old 05-13-2008, 09:36 PM
Monstadrums Monstadrums is offline
Default Hi Hat too loud!
OK I've got too much hi-hat in the overheads. Cant re-track. All other songs are fine but the bastard drummer (me) must have gone hard on one particular track. I've got the actual hi hat track muted but want less in the overheads. I know I can automate but I thought that if I swapped the phase on the hi hat track itself that, that may cancel the hi hat on the overhead. Theoretically this should have worked I think but it made no difference. Maybe I did it wrong. I just put on a eq plug in and hit the little circle with the line through it...that's right isn't it? Any ideas?
Breaking things is fun but getting expensive.
Old 05-14-2008, 07:37 AM
albee1952 albee1952 is online now
Default Re: Hi Hat too loud!
I think your theory is correct but you forgot one detail. The time difference between the hat mic and the overheads. If you zoom in on the wave, you will likely see that the hat mic is slightly earlier than the hat hits on the overheads. MAYBE by shifting the hat track earlier so the hits line up perfectly, you might get some cancellation. The other solution would be a narrow band EQ on the overhead tracks and dial it in on the hat sound and hopefully it won't ruin everything else. Another option IF you had something like ezdrummer would be to create a new set of cymbal and hat tracks in the box. Damn drummers....
Old 05-14-2008, 08:10 AM
elicious elicious is offline
D'Esser
me, i'm still waiting for that anti-hi hat mic
e
ihatetyping
Old 05-14-2008, 10:36 AM
EGS's Avatar
EGS EGS is offline
I think automating the overheads down as needed would be your best sounding solution.
Desktop: PT 2020.3 / Win 10 / GIGABYTE GA-X58A-UD3R / i7-980X hex @ 3.9GHz / 32GB / Focusrite LS56
Laptop: PT 2020.3 / Win 10 / HP ProBook / i7 quad / U-PHORIA UMC1820
Legacy: PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI001
Info/Services link
Old 05-14-2008, 11:11 AM
sunburst79 sunburst79 is offline
If its within 30 days you may be able to take the drummer back and exchange it
A lot of times they don't want to to take them back though.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 05-14-2008, 01:41 PM
ebonyles ebonyles is offline
I'm actually having the same problem only though the snare mic- I'm getting around it with a gate that is oh so finely tweaked- but I'd say that your best bet is actually all of the above- if you can automate and try to snipe that frequency- hopefully you won't have to go too far overboard on either to the point that it sound weird. The other option being find a producer who likes hi hat
2.66Ghz Mac Pro Duo Core 3GB Ram
OSX 10.5.6 MBox2 External 250GB HD
PT LE 8.0cs2
Battery3, Klassic Keys, Addictive Drums, RennMaxx, Production Toolkit, Vienna Special Edition
Old 05-14-2008, 02:07 PM
Cheers for that guys. I'm actually the drummer! ha ha. I did change to a quieter set of hi hats for the whole session and on the other 5 songs that I did that day it's not a problem. Just this one. It's not disastrous (that doesn't look like it's spelt right) I agree that it could be the delay between the hh mic and the oh mic. I will try that. Automation is hard to get sounding natural, so is de essing and eq. Phase cancelling should be the best option. With regards to too much hh in snare besides replacing the snare which I normally do I also sometimes have used a collar that I made. Its basically a piece of accoustic foam that is about 12" by 12" square with a hole in the middle that fits the snare mic snugly. Point the lumpy side towards the hi hat. Cut it down if its too big and/or causing funny reflections on the hi hat mic. This technique I've found to be very effective.
Old 05-14-2008, 02:32 PM
EGS's Avatar
EGS EGS is offline
...Automation is hard to get sounding natural...
Why is that? Alternately, You could duplicate the OH tracks, then delete the hat sections for one set of OH tracks, and delete the non-hats sections for the other set. Adjust faders, done. I think the phasing and EQ and de-ess ideas mentioned above will create a lot of sound quality issues. My 2 cents.
Info/Services link
Old 05-15-2008, 10:51 AM
boboroshi boboroshi is offline
The narrowband EQ would be my first attempt but you're going to lose everything in that range. If you close mic'd everything, you could also try to fake the room by auxing all the drums to a stereo bus with Dverb and mixing it up until you get a fake room sound. Not ideal, but overheads are difficult to fix in general.
Old 05-15-2008, 03:01 PM
I'm STILL laughing over this one......
Kontakt Player loud loud noise at play stop Sven62 MIDI 3 05-05-2011 01:43 PM
loud "POP" DJ Insomaniac 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-07-2005 10:26 AM
So Loud! nozza1 ProControl, Control|24, Command|8 3 12-08-2001 02:30 PM
My PC is too loud!! JMS40 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 08-01-2001 05:10 AM
Does Big mean Loud? imi Storage Subsystems 1 05-01-1999 01:41 PM
