ExpressproTools initialization
ANYONE FROM DIGI THERE??? I am pretty unhappy I have to wait till Monday with this....:
I'm installing 2 new Cheetah 18GBs with ATTO DualPort card/G4 533MHZ. Digi wants me to use ATTO ExpressProTools to intialize the drives and explains this can be done from the utilities menu in Exp.PT. But there's no initialize option in my menu..... I have not installed the EPT extension as this should only be recommended for removable drives. Somebody please adv. as i can't start using the drives until I'm sure they are formatted right. [This message has been edited by savage (edited April 14, 2001).] |
Re: ExpressproTools initialization
I don't have my system in front of me right now, But if I recall correctly, I believe you want 'low level format' under the 'options' menu (of course after selecting the appropriate drive). I use version 2.5, not sure if it's any different from previous versions. There's even an option to optimize for digital audio, though I honestly can't say I know how this differs from nornmal.
use version 2.3.2 that comes with install cd-rom, it's generally safer.
jp |
Thank you guys.
I'm using 2.3.2 coming with the 5.1 install CD. But why would I want to LOW LEVEL format the drives, which should be unnecessary and generally unsafe since you can never get the same formatting conditions on location as on the factory. What Digi suggests is an INITIALIZATION and that's not mentioned in my menus???????? Please advise anyone I',m still stuck here. |
......Even ATTOs PDF manual for ExpressProtools mentions INITIALIZATION under the menu. Why on Earth can't I find this option?
From what I remember as I haven't done this for a while, you need to play with the drop down on the top of the left window which lets you see devices rather than buses or volumes rather than devices. Either that or you need to choose a volume in the right hand window. Sorry I am nowhere near my rig at the moment I hope this isn't even more confusing. ATTO software is not very intuitive. Don't low level format. You're right it is a last resort as the mapping from the software is nothing like as intelligent as that on a hardware formatting device found at the factory. If I get back to my rig later I will have a look and get back to you.
Stuff, mostly |
It's been a while, but I think you need to look for "Erase Disk" or something like that from one of the pull down menus.
"Erase Disk" is correct.
Don't low level format unless you absolutely have to. DC |
Most brand new drives out of the box need to be low level formatted for first time use.
I have two brand new 18 G Cheetahs I need to connect. They come up on the desktop when I uncheck 'inhibit load driver' in the information window, but I suspect they're corrupting my system, as after a few boot ups I get bombs at bootup with message 10, or 'illegal instruction', or 'unimplemented trap'', so I disconnected all drives and made a clean system install, reinstalled ProTools etc. and everything is fine. So I don't want to connect the drives until I know what to do with them.
I seems there are different opinions on whether to low level format or not. Is there an 'initialize option under 'erase'? Who knows about this? I appreciate any comments. |
Mbox 2 Pro FW initialization | docbop | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 09-20-2008 04:09 PM |
Initialization Error... | Equality 7-2521 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-23-2005 05:46 AM |
Initialization Error ?? | Producers Never Sleep | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-06-2005 11:11 AM |
Initialization Error | TheLP | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-03-2004 12:11 PM |
OMS Initialization Error | Straatocastoer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 12-01-2003 05:39 AM |
