Old 02-18-2020, 10:26 AM
TNM TNM is offline
Default Reloading a project I just saved 10 mins back..can't find files?
I literally have not deleted any files from clip browser, or from the finder, and I have not moved the project.
All I did was close pro tools then re open it around 10 mins later and reloaded the project I was working on, and it says it can't find freeze files.
It could not find them by auto searching either.
is this a new one with 2019.12? I mean I need my projects to reload and play!
PT is really starting to annoy me the last month, and no one loves PT more than me (I really do love the workflow I just wish it wasn't so damn buggy!)
Luckily, I was able to work around it by unfreezing the tracks, and they reverted to their original audio.. But next time I might not be so lucky..
anyone else experienced this?
So now we have in 2019.12
1) midi selection recording timing bug
2) Random freeze file lost bug
3) Alt-H move clip bug still persists with samples (on windows it's fine) with beats/measures ruler
4) Random midi output connections lost on project reload, impossible to predict. If you are using a decent amount of VI's and or external midi, you will definitely lose a connection or two. I have NEVER seen ANY other DAW do this ever.
JFreak told me to start support tickets.. I already have, a couple years back, for 3 and 4. I have exchanged MANY emails with them and the final result is always "it's on the list but no ETA". So tell me what more can I do jfreak?
Yes, of course I will create a support request about these two new bugs.
At this stage I would just love to know if anyone else has a problem with missing freeze files on reload.. this happened on my mojave partition but could happen on windows too for all I know, so any input welcomed.
I barely use freeze - so this might be an older issue that I only just found out about.
however, I really want to START using freeze more when I realised just how excellent PT's version of it is, and how easy to use up to certain inserts only.. Once a track is done, that's a great way to save resources, particularly on VI's!
Note to Avid, if you ever read this.. being able to copy and paste frozen audio would be mental (in a good way).
- Intel 14900K/NzXt Kraken Elite/64GB Kingston DDR5 6000 mhz (32x2)/ Asus Pro Art Z790/Asus 4090/Win 11 Pro 23H2/UAD Apollo 8 x2 w TBolt 3 card u/g/UAD Twin X.
Old 02-18-2020, 01:19 PM
Default Re: Reloading a project I just saved 10 mins back..can't find files?
Was there any external drive connected(when you last ran the session) that is now not connected? Re the idea of copy/paste audio while frozen, just use Track Commit instead. Doing this gives you total edit control, but your original track can be kept just as you left it, with the options of making inactive and/or hiding. Personally, I am a big fan of Track Commit, and not a fan of Track Freeze
Old 02-18-2020, 02:08 PM
TNM TNM is offline
I HAVE been using commit, not freeze.. that's what I meant. But I am really enjoying the speed and SINGLE click of freeze :)
No, just the macbook with it's internal SSD! Weird huh.
Old 02-19-2020, 08:52 PM
Yep
Old 02-20-2020, 03:33 AM
Farhoof's Avatar
Farhoof Farhoof is offline
Might be this issue:
https://www.pro-tools-expert.com/hom...he-wrong-audio
Old 02-20-2020, 06:30 AM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
It's not a new bug. I have experienced this a few times in 12.8.1. After the initial panic I solved it by unfreezing, then refreezing the affected tracks. The files showed up then.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins
Old 02-20-2020, 09:24 AM
TNM TNM is offline
Thanks for confirming...
Yeah at least in my mind I can feel secure that unfreeze seems to work, so I won't actually lose anything, which is the most important thing.
Cheers.
Old 02-23-2020, 03:59 PM
lesbrunn's Avatar
+1 for damn effing buggy!
New to 2019 so I haven't experienced this yet. How does it present itself?
I've had this for years. Totally unacceptable! Avid never seems to know their priorities when it comes to bug-fixes!
Freeze is a a great feature especially with VI's and plugins, where PT is especially weak CPU-wise. Fortunately unfreezing/refreezing solves the missing file issue.
Yes! But Avid never listens. A frozen track is exactly that...frozen solid. A partial defrost (at least) would be super!
Pro tools first crashes when trying to open saved project Fat32 Pro Tools | Intro Discussion 0 02-02-2018 09:42 PM
Are plugin parameters saved in project? David.Straley Pro Tools 11 14 11-04-2016 02:10 PM
Where do I find my saved Plug-In Presets ? Talisker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-02-2010 11:00 AM
Can a saved project in PT8 be opened in 7.4x? Daviskenn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-22-2008 07:31 PM
sends not working when opening a saved project. ashdeini 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-11-2006 06:51 PM
