Old 02-13-2020, 01:41 AM
Downtown_BE Downtown_BE is offline
Default Input Monitoring
I have a question about input monitoring
when I mix ITB I usually route everything to a mix bus and then to stereo audio track for the mix - that means if I want to switch between the roughmix on the stereo audio track and the actual mix I`m working on I just have to push input monitoring which is pretty cool...
NOW: is there any shortcut or trick to not always have to scroll all down to the final mix stereo audio track and push input monitoring there? that would be üretty amazing.. I even have a faderport and a avid artist mix but both of them seem to not be able to swithc between input monitoring and normal monitoring
thx for your help
Old 02-13-2020, 08:09 AM
The Weed's Avatar
The Weed The Weed is offline
Default Re: Input Monitoring
Move the final mix track to the top of the Edit Window?
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 02-13-2020, 10:00 AM
doesn`t really help because I`m talking about 60-70 tracks and my monitor only shows about 10 of them so wherever I am I have to scroll anyway..
Old 02-13-2020, 10:42 AM
JFreak's Avatar
JFreak JFreak is offline
Avid Dock has "attention" channel that you can use for your needs
Janne
Old 02-13-2020, 12:41 PM
off the wall's Avatar
off the wall off the wall is offline
Yeah, I think a control surface is in your future. On the D-Commands I always have a couple of tracks nailed to the right side with the Command Group function.
offthewallproductions
Mac Pro 5,1 3.46 Ghz 12 core, Open Core 0.9.8, Radeon RX580 GPU, GC-TITAN RIDGE TB3 PCIe card, M.2 NVMe SSD boot drive on PCIe card, 48GB RAM, macOS 12.7.4
Pro Tools Ultimate 2024.3.1/HD Driver 2023.3 HDX, UA Octo PCIe card in external TB3 chassis, MTRX Studio I/O, C|24 control surface.
Genelec 1031AP/7070A 5.1 monitoring.
Old 02-13-2020, 01:20 PM
henningaround henningaround is offline
thx for your help
You can put the audio track into record and hit alt-i for toggling input monitor (on all record-enabled tracks)
Old 02-13-2020, 02:47 PM
sounds great but : alt-i opens up a workspace here..
are you talking about a OSX shortcut?
Old 02-13-2020, 02:54 PM
Re the Artist Mix, it seems to me that there was a way to select input mode. It might have been Shift+record(in any case, its worth a look thru the manual or the features of recent Eucon updates)
Old 02-14-2020, 09:04 AM
Oops I meant ... alt-k? Sorry, this is too deep in my head :)
Old 02-14-2020, 10:40 AM
holy moly alt-k WORKS
thx a million!! this is so cool..
Input monitoring rmiller335 Windows 5 06-01-2012 08:36 PM
Auto input/input only monitoring failing in PTLE 8.0.4 miketeachesclass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 04-11-2012 08:48 AM
Monitoring my input in pt9 Raoul23 Pro Tools 9 9 12-19-2010 06:59 PM
Input Monitoring ThunderKyss 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-06-2010 06:58 AM
Auto Input monitoring / Input only monitoring - Alt+K AdamPT8 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-09-2010 10:50 AM
