Can I run 10 and 2018 on new Mac Mini?
Question for ya guys as Im just trying to plan ahead.
Thinking about purchasing a new Mac mini and dumping my MP cheese grater 6 core 2013. I would like the ability to open my pro tools 10 sessions so I can reference mixes and plugins from older sessions. If I upgrade to Mac Mini/Mojave and Pro Tools 2019, is there a possible way to boot off an old drive or can I install pro tools 10 also. Plugins like McDsp and a couple others have changed so opening my old sessions on 2019 doesnt pull their settings up. Thanks guys |
Re: Can I run 10 and 2018 on new Mac Mini?
Can you? Probably. Is it supported? No.
Can I run 10 on Mojave? Will both 10 and 2019 run
Well we tried to run HD10.3.10 on a nMP with Mojave as we needed to convert a few older sessions to be used in HD 2018 but that was a total ssshhhhiiiit show and can NOT recommend that. Remember not even the current PT version is supported on Mojave let alone PT10 so my advice / Stay away!
If you really ”need” to use PT10 then either make a seperate boot drive with Mavericks for example or keep a older computer working with a OSX that support PT10. Dont try to mix these versions you have as it wont be pretty.
Can I make a separate boot drive that will boot an older OS with the new mac mini??
no, unless you can hack the new drivers into the old operating system
I doubt it. Most Apple products aren't backwards compatible - they will only run versions of OSX from when they were released, and onwards, so I wouldn't expect the Mac Mini 2018 model to run anything less than Mojave.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command. |
Mojave PTs 10hd works as a conversion utility for me.
Note: its not a viable DAW. But after adjusting my plugins folders for both aax and rtas i can minimal-launch. Open old sd2 ptf sessions then save copy and convert yo my current needs. Not graphics ony apear after a mouse rollover. PITA but works. This likely won’t work in fully 64 bit OSs
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit Last edited by DetroitT; 03-02-2019 at 06:42 AM. |
Mojave (...) 10HD works as conversion utility (...) likely won't work in fully 64bit OS (such as Mojave) What I am missing here?
Re: I run 10 and 2018 on Mojave √
Yes. Just made a very short conversion vid in Mojave (1:45). YouTube Here
Mojave is touted as last non fully 64 bit OS
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit Last edited by DetroitT; 03-02-2019 at 10:07 AM. Reason: Added short vid clip 1:45 |
-9173 Driving me NUTS 2018 Mac mini | SevenRising | Pro Tools 2018 | 26 | 01-23-2019 08:03 PM |
HDX with 2018 Mac Mini | A Chapman | Pro Tools HDX & HD Native Systems (Mac) | 5 | 01-17-2019 09:35 AM |
2018.4 to 2018.7 upgrade advice and experience | chuckwow | Pro Tools 2018 | 6 | 09-21-2018 11:09 AM |
Macbook Pro 2018 w/ UAD Apollo 8p and PT 2018.7 Performance Issues | Dudiester | Pro Tools 2018 | 5 | 08-12-2018 08:33 AM |
Pro Tools 2018.3 / 2018.4 crashing when switching window configurations | matthewmkb | macOS | 0 | 06-27-2018 06:33 AM |
