Analog Summing; problems with recording back into Pro Tools. Clocking issue?
Hi guys,
I've just started doing some analog summing and have been experiencing problems when bouncing the summed audio back into Pro Tools. The session is running absolutely fine but when I record it back into PT and listen back to that track, there are clicks and pops all over the place! Here is my setup: Mac Pro, Pro Tools 11. Apogee Ensemble running it's 8 analog outs, then from the ADAT output, I'm running it into an RME Fireface 400, which is converting that out to it's 6 analog outputs. It all runs into an Audient Sumo and records back into Pro Tools into the Apogee Ensemble. Any thoughts? Could it be a clocking issue? I'm clocking via ADAT. Any thoughts would be super helpful! Cheers, James
View my website: James Arter Music www.jamesarter.com Soundcloud http://www.soundcloud.com/happybunnyproductions |
Re: Analog Summing; problems with recording back into Pro Tools. Clocking issue?
which unit is the master? does the other unit show "lock"?
Well, I've tried both ways and it seems that it works better when the Apogee is the master - RME has a great option to set it to AutoSync anyway, which is proving to be really good. They won't seem to sync at all if it's the other way round.
I've actually just found a way that seems to work a little better actually - having the RME as the main interface and running the Apogee as a stand alone unit. So far, it seems to be working much better and I'm able to record audio back in. I'm not entirely convinced it's perfect though; considering trying the word clock option. Any thoughts on that?
I would try the word clock route.
I've had no issues passing ADAT signal back and forth when using Word Clock.
www.montabonsound.com www.29counts.com Pro Tools HD 2019.12 | HD Native PCIe & HD Native Thunderbolt | Lynx Aurora 16 HD | HD I/O | Digi 192 | 2010 Mac Pro 12 Core 3.46ghz | macOS Mojave 10.14.4 | 48 gigs RAM | Tascam DM3200 | Crane Song Avocet II | Antelope Isochrone OCX | Universal Audio Quad & Duo | Waves Mercury + Studio Classics v10 & Abbey Road Collection |
Strike that.
Yes, decide on the master & use word
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~ ~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG ~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~ |
Ok great, I'll try that then.
Just to confirm the process, if I were to make the RME the master, I would take the WC OUT from that into the WC IN on the Apogee, then terminate the signal there (via the 75ohm button). Then obviously choose Word Clock on both devices and should be good to go?
No, you'd only need to set the slave device to Wordclock. The master needs to be set to Internal clock. You probably won't need the termination switch to have sync, since it's a stubble device being slaved, but you can switch the termination switch to ensure it's terminated.
Yarrp . .
Ok, I'm with you. Right, I'm going to give that a go and see how it goes. Thanks all for the help!
Just a thought … it's always worth just checking the "ignore errors" box in the playback engine isn't ticked
Analog Summing | TCM | General Discussion | 2 | 05-15-2011 01:10 AM |
Analog Summing Mixers with Pro Tools | munit54 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-12-2010 11:38 AM |
passive analog summing. | deezwayz | General Discussion | 0 | 05-06-2005 11:00 AM |
analog summing buss | agent_k | Tips & Tricks | 5 | 01-01-2005 07:12 PM |
Analog Summing vs. HD Mix Bus | Nicolasixxx | Pro Tools TDM Systems (Mac) | 3 | 03-06-2003 03:13 PM |
