PT HD on saffire pro 40 or 56?
has anyone tried mixing on surround with either the saffire pro 40 or liquid saffire 56 using PT10HD or PT11hd?
im mainly curious if the HD software can identify the interface as having 8 and being able to use them properly to mix in surround with surround plugins? |
Re: PT HD on saffire pro 40 or 56?
The HD software will see any interface with enough outputs as a viable surround source. In fact, you can even set up a surround session with an interface that only has two outputs. You would just only hear two channels, unless you use the built in downmixer plugin, that would provide fold downs of the other channels.
I'm currently using my 2010 Mac Pro HDMI multichannel out (via a MiniDisplayport to HDMI adapter) into my consumer reciever and can monitor through my consumer home theater system (I only recently discovered I can do this). It works great. You will not have a problem using the Focusrite units. You will have the option to set up the output of it so that all of your needed outputs (6 or 8, depending on if you're doing 5.1 or 7.1) will go through your volume knob/monitor section, which is great, unless you already have a separate surround monitor controller. |
on your setup, are you using pro tools hd or native?
I am using HD. I have the HD software because I have the HD Native and Omni system. But I do not have the extra powered studio monitors to hook up to the Omni. So instead I am using my home theater for surround monitoring, since it is in the same room as my computer and Protools setup (though I still need a 25 foot HDMI cable to reach the receiver).
But you can use the Focusrite units just fine if that's what you're thinking about. |
The Pro 40 and Liquid Saffire 56 are both great interfaces for Surround Mixing in Pro Tools.
You will find the Digitally Controlled Monitor Knob useful as once you go into Saffire MixControl and make sure each Monitor Enable Button for those Line Outputs (these are just above the large Software Monitor Knob) is Blue they are all controlled by the Software and Physical Monitor Knobs. Please let me know if there is anything I can do to assist you.
Katherine Kaplan // Focusrite Technical Support http://www.focusrite.com/answerbase/en/ |
Is it still the case that the 8 analog outputs can be grouped and controlled by the physical knob on the front panel?
Chris Conlee PTHD 2018.1, Behringer FCA610, Blackmagic Intensity Pro (driver v10.8.2) Mac OS 10.13.2, 2009 Mac Pro, 32Gb RAM |
Yes, that's what she was saying. I use my Saffire 56 for surround mixing and have used a Pro 40 in the past - they work and sound great!!
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (3) Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
Pt 10+ liquid saffire 56+ saffire pro 40 masterclock? | Nightworker | Pro Tools 10 | 16 | 12-08-2012 10:29 PM |
003 with saffire | peterreal | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-27-2012 04:10 PM |
Saffire le | gmsjay | Pro Tools 9 | 16 | 01-06-2011 04:56 AM |
saffire pro 40 vs liquid saffire 56 | AxeDye | Pro Tools 9 | 9 | 12-09-2010 05:19 PM |
PT 9 and Saffire 56 | Empireofthesun | Pro Tools 9 | 0 | 11-05-2010 03:32 PM |
