Old 11-12-2007, 09:24 AM
spidey901 spidey901 is offline
Default Mixing and Mastering
Hi Guys.
I need some help with this issue.
Lets say after I have done my mixing, (leveling, eq, compression etc etc)which is the best way to prepare the audio for mastering? should I go ahead and insert the mastering software right there on the master faders then bounce to disk, or do i bounce the file to disk, then import the wave file file into a new session create a master fader and do the mastering here with just the bounce file and the master fader? your help is greatly appreciated, thank you
Old 11-12-2007, 10:23 AM
EGS's Avatar
EGS EGS is offline
Default Re: Mixing and Mastering
I like to bounce the mix to the same bit depth/sample rate as the session. Then I pull that bounce into a new PT session, again in the same bit/sampling rate, apply all magic mastering processing (this is an entire topic in and of itself), and lastly dither to 16/44.1khz.
Click for audio/video demo
Click for resume
Old 11-12-2007, 10:28 AM
kmank kmank is offline
This could perhaps be reflective of your available resources. If you bounce to disk first, you have the added benefit of freeing up resources that were used within the individual tracks for your processing plugins.
Old 11-12-2007, 10:40 AM
Thanks Guys, your response was very helpful, again thank you very much
Mixing & Mastering! Please Help! cichy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-24-2008 02:24 PM
mixing and mastering dopemoney 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-28-2007 10:38 AM
mixing and mastering on the m box? johnnymojo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-23-2004 06:07 AM
mixing and mastering vx2kfilmer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-30-2003 05:03 AM
Mixing / Mastering for TV???? pepperman Tips & Tricks 5 07-23-2003 05:24 PM
