Old 11-21-2002, 05:23 PM
peter parker peter parker is offline
Default HOW can you import a "stereo" WAV. file into PT as a "mono" file?
how can i get a stereo wav. file from a cdrom imported into my session as a single mono file?
i can do it with audio files with Toast Extractor, but how do you do it with a Wav file? can it be done......a stereo file imported as a mono file for the session..........it would be nice since the wav. samples are already cut up so perfect.......where as the audio files still need to be cut up.......
Old 11-21-2002, 05:32 PM
Default Re: HOW can you import a "stereo" WAV. file into PT as a "mono" file?
am i missing something........it keeps importing itself into the session as a stereo file..........i want the wav. file to be mono damn it!!!
Old 11-21-2002, 05:57 PM
Slim Shady Slim Shady is offline
You'll have to import it as stereo and then bounce it down to a mono file, then re-import it.
Your other option is to use a program like to peak to do the stereo->mono conversion, then import the file.
Old 11-21-2002, 09:14 PM
nukmusic nukmusic is offline
I second that. Slim is right!
Docta'J
Download free music at
http://www.nukmusic.com
nEVER uNDERESTIMATE kNOWLEDGE
"Import Session Data" Audio File Duplicates acstctws Pro Tools 10 1 03-01-2013 03:06 PM
What are the difference between using a "mono" vs "mono/stereo" plug in on mono track rockguitarist1255 Pro Tools 10 4 12-07-2012 08:07 AM
Save as > "Could not 14404 because File or folder not found (-43) while opening "..." Elias Stiza 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-10-2012 07:06 PM
"unable to parse audio file" and "OSStatus Error -208" ! reichman Post - Surround - Video 2 03-22-2010 04:46 AM
What do i import a "dual mono" audio file as??? mono or split stereo? peter parker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 07-17-2002 04:02 AM
