Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Mac)
Old 03-04-2014, 11:24 AM
carvinbassplyr carvinbassplyr is offline
Default Using different Mboxes with the same Pro Tools
I recently grabbed a MacBook Pro to give myself the option of a mobile rig. My question is, can I get an Mbox 2(3) mini for my MacBook to make my mobile rig more portable? I know I can't run two machines simultaneously off one license, I just want to be able to "pick up and go" when I need to without having to lug the full size Mbox 2 everywhere. I'd obviously be picking one up used so what all would I need to make sure I get from the seller?
Old 03-04-2014, 12:03 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Using different Mboxes with the same Pro Tools
Yeh no problem, the software will work with any compatible Mbox. if its working now with one Mbox then any other Mbox 2/3 will also work with nothing extra needed as you already have the software authorised with your first Mbox
chris
Producer, Engineer,
www.ukmastering.com
Old 03-04-2014, 12:32 PM
Craig F Craig F is offline
Not knowing what version of Pro Tools your running all will warn that I/O naming constancy is paramount
Thank you,
Craig
Old 03-04-2014, 01:07 PM
Originally Posted by crizdee View Post
chris
There's no registration or other paperwork I'll need when buying one second hand?
Old 03-04-2014, 01:10 PM
I'm using Pro Tools LE 8.0.5 on Snow Leopard
New Pro Tools Express for Mboxes nst7 Pro Tools Express on Mac OS X 16 06-06-2012 06:22 PM
MBoxes kconsor Digidesign Hardware & Software 1 01-28-2011 06:55 PM
mboxes vicwind 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-25-2007 12:44 PM
Is it possible to use 2 Mboxes? Cerulean 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-06-2007 06:00 PM
can i use 2 Mboxes? sendhelp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-01-2006 10:54 PM
