Pt 10 crash
Hi.I'm encountering a Pro Tools problem for a while. I tried about a billion possible solutions still standing where i was before.
Almost all of the projects i'm editing and mixing is working great. But some random projects makes Pro Tools crash when i try to add a bus or delete/add a channel etc. Removing all the plugins on channels and make a new project using save copy in didn't work. Don't know what makes PT crash to desktop but this is driving me crazy. I'm using MacOS 10.8 and PT 10.3.9. Btw i was encountering this problem when i was using PT10.3.8. The projects that makes PT crash is working fine on PT11 but i have plugins that doesn't have AAX versions that i want to use. I'd be happiest person in the world if i can solve this weird problem. Thanks. 2.66 ghz quad core 16 gig ram osx 10.8.5 |
Pt 10 chrash
What exact error messages do you get from Pro Tools or OS X when Pro Tools "crashes"?
If an OS X application crash, post the full crash report from the system console (Console.app) here. What are all your playback engine settings? And try..... Trashing prefs and databases. Try creating a new empty session and importing the old session media into the new session. Try removing all third party RTAS and AAX-32 plugin files from the Pro Tools plugin folders. Just removing a plugin from the inset list in Pro Tools is often not enough, the plugin us still loaded in memory and able to do bad things. |
Re: Pt 10 chrash
First of all thanks for your reply.
The problem is, there's no error message. Protools just crashing to desktop and all i see is my desktop window. My playback engine settings: Buffer size : 1024 Samples Host Processors : 6 processors CPU Usage Limit : %90 Delay Compensation Engine : Maximum Also i tried trashing preferences and databases, creating a new session and importing the media from old session. The only thing i haven't tried is removing the plugins from PT plugin folders. |
Re: Pt 10 chrash
Well what shows up in Console.app?
Under User Diagnostic Reports in the Left Hand side column are there any Pro Tools crashes? How many? If so select the most recent crash and paste the full text of the crash from the right hand panel here, you may need to paste across multiple posts to fit all the text here. In playback engine settings make sure to uncheck ignore errors (always uncheck that when debugging). And its time for you to move aside all third party pluging files and try again. Make sure you are following all the instructions for your OS X version to trash prefs and databases, if they don't make sense etc. ask. As you do other troubleshooting, its is often a good idea to occasionally go back and trash that stuff again. What interface and exact driver version are you using? Still having problems I would also try creating a new Admin account and testing from there, but I doubt that is the issue here. |
Re: Pt 10 crash
Hi again.
I tried more possible solutions such as running the project on an external hdd etc. and the problem still standing there unsolved. I'm posting the latest crash report from console like you said. Hope this crash report can help me to solve this weird problem. Thank you again. |
Re: Pt 10 crash
Process: Pro Tools [905]
Path: /Applications/Avid/*/Pro Tools.app/Contents/MacOS/Pro Tools Identifier: com.digidesign.ProTools Version: 10.3.9.462 (10.3.9f462) Build Info: Unknown-10390462~462 Code Type: X86 (Native) Parent Process: launchd [195] User ID: 501 Date/Time: 2014-08-06 16:46:47.680 +0300 OS Version: Mac OS X 10.8.5 (12F45) Report Version: 10 Crashed Thread: 0 Dispatch queue: com.apple.main-thread Exception Type: EXC_BAD_ACCESS (SIGBUS) Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000024 VM Regions Near 0x24: --> __PAGEZERO 0000000000000000-0000000000001000 [ 4K] ---/--- SM=NUL /Applications/Avid/*/Pro Tools.app/Contents/MacOS/Pro Tools __TEXT 0000000000001000-0000000000143000 [ 1288K] r-x/rwx SM=COW /Applications/Avid/*/Pro Tools.app/Contents/MacOS/Pro Tools Thread 0 Crashed:: Dispatch queue: com.apple.main-thread 0 com.digidesign.framework.ProTools 0x0c94915c MFortressHWBPEntryPoint_exit_mfort6317_ + 8162866 1 com.digidesign.framework.ProTools 0x0c94945f MFortressHWBPEntryPoint_exit_mfort6317_ + 8163637 2 com.digidesign.framework.ProTools 0x0c9585db MFortressHWBPEntryPoint_exit_mfort6317_ + 8225457 3 com.digidesign.framework.ProTools 0x0c958b7b MFortressHWBPEntryPoint_exit_mfort6317_ + 8226897 4 com.digidesign.framework.ProTools 0x0c9453ee MFortressHWBPEntryPoint_exit_mfort6317_ + 8147140 5 com.digidesign.framework.ProTools 0x0c953f77 MFortressHWBPEntryPoint_exit_mfort6317_ + 8207437 6 com.digidesign.framework.ProTools 0x0d125c96 MFortressHWBPEntryPoint_exit_mfort6317_ + 16406892 7 com.digidesign.framework.DFW 0x005ae32c TEventHandler::HandleIdle(IdlePhase) + 92 8 com.digidesign.framework.DFW 0x00590acf TApplication::Idle(IdlePhase) + 207 9 com.digidesign.framework.DFW 0x0058f195 TApplication::ClearEventsWithSpecifiedContextOut(T View*) + 437 10 com.digidesign.framework.DFW 0x005fd3f7 DFW_Timers::LockedCallbackTimerProc:perator()(vo id*) + 87 11 com.digidesign.framework.DFW 0x00711bcc DFW_Timers::CallbackTimerManager::MasterCallback(v oid*) + 188 12 com.digidesign.framework.DFW 0x00710e12 DFW_SatinManager::dialogNotification(std::string, std::vector<std::string, std::allocator<std::string> >) + 50882 13 com.digidesign.framework.DFW 0x007133c5 DFW_Timers::CallbackTimerManager::OperateOnSet(voi d (*)(void (*)(void*)), DFW_Timers::TimerSetID const&) + 2069 14 com.apple.HIToolbox 0x91e4135c TimerVector + 22 15 com.apple.CoreFoundation 0x97d58406 __CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUN CTION__ + 22 16 com.apple.CoreFoundation 0x97d57da5 __CFRunLoopDoTimer + 709 17 com.apple.CoreFoundation 0x97d3cbb2 __CFRunLoopRun + 1842 18 com.apple.CoreFoundation 0x97d3c01a CFRunLoopRunSpecific + 378 19 com.apple.CoreFoundation 0x97d3be8b CFRunLoopRunInMode + 123 20 com.apple.HIToolbox 0x91e30f5a RunCurrentEventLoopInMode + 242 21 com.apple.HIToolbox 0x91e30bf5 ReceiveNextEventCommon + 162 22 com.apple.HIToolbox 0x91f961ad _AcquireNextEvent + 68 23 com.apple.HIToolbox 0x91f84f6a RunApplicationEventLoop + 225 24 com.digidesign.framework.DFW 0x006fea5b DFW_EventLoop::RunApplicationEventLoop() + 11 25 com.digidesign.framework.DFW 0x0058ec5d TApplication::Run() + 45 26 com.digidesign.framework.ProTools 0x0dbe9401 MFortressHWBPEntryPoint_exit_mfort6317_ + 27693271 27 com.digidesign.framework.ProTools 0x0dbea924 LaunchProTools + 1412 28 com.digidesign.ProTools 0x0000f277 0x1000 + 57975 29 com.digidesign.ProTools 0x0001037a 0x1000 + 62330 30 com.digidesign.ProTools 0x0000effd 0x1000 + 57341 Thread 1:: Dispatch queue: com.apple.libdispatch-manager 0 libsystem_kernel.dylib 0x914e79ae kevent + 10 1 libdispatch.dylib 0x96e09c71 _dispatch_mgr_invoke + 993 2 libdispatch.dylib 0x96e097a9 _dispatch_mgr_thread + 53 Thread 2: 0 libsystem_kernel.dylib 0x914e480a semaphore_wait_trap + 10 1 com.digidesign.framework.digitrace 0x02a6198a digitrace_initialize + 10122 2 com.digidesign.framework.digitrace 0x02a660df DigiTraceIsActiveFunc + 1263 3 com.digidesign.framework.digitrace 0x02a66265 DigiTraceIsActiveFunc + 1653 4 com.digidesign.framework.digitrace 0x02a663c1 DigiTraceIsActiveFunc + 2001 5 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 6 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 3: 0 libsystem_kernel.dylib 0x914e47ce mach_msg_trap + 10 1 libsystem_kernel.dylib 0x914e3cac mach_msg + 68 2 com.apple.CoreFoundation 0x97d36f79 __CFRunLoopServiceMachPort + 185 3 com.apple.CoreFoundation 0x97d3c95f __CFRunLoopRun + 1247 4 com.apple.CoreFoundation 0x97d3c01a CFRunLoopRunSpecific + 378 5 com.apple.CoreFoundation 0x97d4bab1 CFRunLoopRun + 129 6 com.digidesign.framework.ProTools 0x0dbe6ce7 MFortressHWBPEntryPoint_exit_mfort6317_ + 27683261 7 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 8 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 4: 0 libsystem_kernel.dylib 0x914e47ce mach_msg_trap + 10 1 libsystem_kernel.dylib 0x914e3cac mach_msg + 68 2 com.digidesign.framework.CoreFoundation 0x0024f372 Sys_MachExceptionHandler::Init(bool, int) + 706 3 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 4 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 5: 0 libsystem_kernel.dylib 0x914e47ce mach_msg_trap + 10 1 libsystem_kernel.dylib 0x914e3cac mach_msg + 68 2 com.apple.CoreFoundation 0x97d36f79 __CFRunLoopServiceMachPort + 185 3 com.apple.CoreFoundation 0x97d3c95f __CFRunLoopRun + 1247 4 com.apple.CoreFoundation 0x97d3c01a CFRunLoopRunSpecific + 378 5 com.apple.CoreFoundation 0x97d4bab1 CFRunLoopRun + 129 6 com.digidesign.framework.DAE 0x0eea8d97 FicIsAlive + 983 7 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 8 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 6: 0 libsystem_kernel.dylib 0x914e6366 __ioctl + 10 1 com.digidesign.framework.PlatformSupport 0x008c4e71 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 8220 2 com.digidesign.framework.PlatformSupport 0x008cf52e PSThreadTable_AddTable(SPSThreadPriorityEntry const*, unsigned long) + 492 3 com.digidesign.framework.CoreFoundation 0x00249846 Sys_BlockingTimer:estroy(Sys_BlockingTimer*&) + 886 4 com.digidesign.framework.CoreFoundation 0x0022d280 Sys_RawThreadTimerTask::Exec() + 64 5 com.digidesign.framework.CoreFoundation 0x0022d094 Sys_RawThreadTask::Run() + 36 6 com.digidesign.framework.CoreFoundation 0x00249c34 Sys_RawThread::ThreadIDsAreEqual(void*, void*) + 68 7 com.digidesign.framework.PlatformSupport 0x008c52a3 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9294 8 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 9 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 7: 0 libsystem_kernel.dylib 0x914e6366 __ioctl + 10 1 com.digidesign.framework.PlatformSupport 0x008c4e71 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 8220 2 com.digidesign.framework.PlatformSupport 0x008cf52e PSThreadTable_AddTable(SPSThreadPriorityEntry const*, unsigned long) + 492 3 com.digidesign.framework.CoreFoundation 0x00249846 Sys_BlockingTimer:estroy(Sys_BlockingTimer*&) + 886 4 com.digidesign.framework.CoreFoundation 0x0022d280 Sys_RawThreadTimerTask::Exec() + 64 5 com.digidesign.framework.CoreFoundation 0x0022d094 Sys_RawThreadTask::Run() + 36 6 com.digidesign.framework.CoreFoundation 0x00249c34 Sys_RawThread::ThreadIDsAreEqual(void*, void*) + 68 7 com.digidesign.framework.PlatformSupport 0x008c52a3 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9294 8 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 9 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 8: 0 libsystem_kernel.dylib 0x914e6366 __ioctl + 10 1 com.digidesign.framework.PlatformSupport 0x008c4e71 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 8220 2 com.digidesign.framework.PlatformSupport 0x008cf52e PSThreadTable_AddTable(SPSThreadPriorityEntry const*, unsigned long) + 492 3 com.digidesign.framework.DAE 0x0ef16df0 FicGetContiguousMemRequirements + 150336 4 com.digidesign.framework.CoreFoundation 0x0022d094 Sys_RawThreadTask::Run() + 36 5 com.digidesign.framework.CoreFoundation 0x00249c34 Sys_RawThread::ThreadIDsAreEqual(void*, void*) + 68 6 com.digidesign.framework.PlatformSupport 0x008c52a3 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9294 7 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 8 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 9: 0 libsystem_kernel.dylib 0x914e48e2 mach_wait_until + 10 1 com.apple.CoreServices.CarbonCore 0x98a59592 MPDelayUntil + 29 2 com.apple.CoreServices.CarbonCore 0x98a6a8bd Delay + 90 3 se.propellerheads.rewire.library 0x1bb1e654 RWIsReWireMixerAppRunningImp + 30420 4 se.propellerheads.rewire.library 0x1bb2d228 RWIsReWireMixerAppRunningImp + 90792 5 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 6 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 10: 0 libsystem_kernel.dylib 0x914e6366 __ioctl + 10 1 com.digidesign.framework.PlatformSupport 0x008c4e71 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 8220 2 com.digidesign.framework.PlatformSupport 0x008cf52e PSThreadTable_AddTable(SPSThreadPriorityEntry const*, unsigned long) + 492 3 com.digidesign.framework.CoreFoundation 0x00249846 Sys_BlockingTimer:estroy(Sys_BlockingTimer*&) + 886 4 com.digidesign.framework.CoreFoundation 0x0022d280 Sys_RawThreadTimerTask::Exec() + 64 5 com.digidesign.framework.CoreFoundation 0x0022d094 Sys_RawThreadTask::Run() + 36 6 com.digidesign.framework.CoreFoundation 0x00249c34 Sys_RawThread::ThreadIDsAreEqual(void*, void*) + 68 7 com.digidesign.framework.PlatformSupport 0x008c52a3 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9294 8 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 9 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 11: 0 libsystem_kernel.dylib 0x914e6366 __ioctl + 10 1 com.digidesign.framework.PlatformSupport 0x008c4e71 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 8220 2 com.digidesign.framework.PlatformSupport 0x008cf52e PSThreadTable_AddTable(SPSThreadPriorityEntry const*, unsigned long) + 492 3 com.digidesign.framework.CoreFoundation 0x00249846 Sys_BlockingTimer:estroy(Sys_BlockingTimer*&) + 886 4 com.digidesign.framework.CoreFoundation 0x0022d280 Sys_RawThreadTimerTask::Exec() + 64 5 com.digidesign.framework.CoreFoundation 0x0022d094 Sys_RawThreadTask::Run() + 36 6 com.digidesign.framework.CoreFoundation 0x00249c34 Sys_RawThread::ThreadIDsAreEqual(void*, void*) + 68 7 com.digidesign.framework.PlatformSupport 0x008c52a3 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9294 8 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 9 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 12: 0 libsystem_kernel.dylib 0x914e6366 __ioctl + 10 1 com.digidesign.framework.PlatformSupport 0x008c4e71 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 8220 2 com.digidesign.framework.DAE 0x0efa4ef5 FWMidiCallback + 505269 3 com.digidesign.framework.DAE 0x0ef517a3 FWMidiCallback + 163427 4 com.digidesign.framework.DAE 0x0efa4e92 FWMidiCallback + 505170 5 com.digidesign.framework.PlatformSupport 0x008c52b8 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9315 6 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 7 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 13: 0 libsystem_kernel.dylib 0x914e6366 __ioctl + 10 1 com.digidesign.framework.PlatformSupport 0x008c4e71 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 8220 2 com.digidesign.framework.DAE 0x0efa4ef5 FWMidiCallback + 505269 3 com.digidesign.framework.DAE 0x0ef51573 FWMidiCallback + 162867 4 com.digidesign.framework.DAE 0x0efa4e92 FWMidiCallback + 505170 5 com.digidesign.framework.PlatformSupport 0x008c52b8 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9315 6 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 7 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 14: 0 libsystem_kernel.dylib 0x914e6366 __ioctl + 10 1 com.digidesign.framework.PlatformSupport 0x008c4e71 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 8220 2 com.digidesign.framework.DSK 0x0fac4e32 DSK_ParsedZone::Reset() + 22146 3 com.digidesign.framework.CoreFoundation 0x0022d094 Sys_RawThreadTask::Run() + 36 4 com.digidesign.framework.CoreFoundation 0x00249c34 Sys_RawThread::ThreadIDsAreEqual(void*, void*) + 68 5 com.digidesign.framework.PlatformSupport 0x008c52a3 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9294 6 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 7 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 15: 0 libsystem_kernel.dylib 0x914e6366 __ioctl + 10 1 com.digidesign.framework.PlatformSupport 0x008c4e71 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 8220 2 com.digidesign.framework.DSK 0x0fac4e32 DSK_ParsedZone::Reset() + 22146 3 com.digidesign.framework.CoreFoundation 0x0022d094 Sys_RawThreadTask::Run() + 36 4 com.digidesign.framework.CoreFoundation 0x00249c34 Sys_RawThread::ThreadIDsAreEqual(void*, void*) + 68 5 com.digidesign.framework.PlatformSupport 0x008c52a3 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9294 6 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 7 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 16: 0 libsystem_kernel.dylib 0x914e6366 __ioctl + 10 1 com.digidesign.framework.PlatformSupport 0x008c4e71 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 8220 2 com.digidesign.framework.DSK 0x0fac4e32 DSK_ParsedZone::Reset() + 22146 3 com.digidesign.framework.CoreFoundation 0x0022d094 Sys_RawThreadTask::Run() + 36 4 com.digidesign.framework.CoreFoundation 0x00249c34 Sys_RawThread::ThreadIDsAreEqual(void*, void*) + 68 5 com.digidesign.framework.PlatformSupport 0x008c52a3 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9294 6 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 7 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 17: 0 libsystem_kernel.dylib 0x914e6366 __ioctl + 10 1 com.digidesign.framework.PlatformSupport 0x008c4e71 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 8220 2 com.digidesign.framework.DSK 0x0fac4e32 DSK_ParsedZone::Reset() + 22146 3 com.digidesign.framework.CoreFoundation 0x0022d094 Sys_RawThreadTask::Run() + 36 4 com.digidesign.framework.CoreFoundation 0x00249c34 Sys_RawThread::ThreadIDsAreEqual(void*, void*) + 68 5 com.digidesign.framework.PlatformSupport 0x008c52a3 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9294 6 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 7 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 18: 0 libsystem_kernel.dylib 0x914e6366 __ioctl + 10 1 com.digidesign.framework.PlatformSupport 0x008c4e71 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 8220 2 com.digidesign.framework.DSK 0x0fac0d4c DSK_ParsedZone::Reset() + 5532 3 com.digidesign.framework.CoreFoundation 0x0022d094 Sys_RawThreadTask::Run() + 36 4 com.digidesign.framework.CoreFoundation 0x00249c34 Sys_RawThread::ThreadIDsAreEqual(void*, void*) + 68 5 com.digidesign.framework.PlatformSupport 0x008c52a3 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9294 6 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 7 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 19: 0 libsystem_kernel.dylib 0x914e6366 __ioctl + 10 1 com.digidesign.framework.PlatformSupport 0x008c4e71 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 8220 2 com.digidesign.framework.DSK 0x0fac0d4c DSK_ParsedZone::Reset() + 5532 3 com.digidesign.framework.CoreFoundation 0x0022d094 Sys_RawThreadTask::Run() + 36 4 com.digidesign.framework.CoreFoundation 0x00249c34 Sys_RawThread::ThreadIDsAreEqual(void*, void*) + 68 5 com.digidesign.framework.PlatformSupport 0x008c52a3 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9294 6 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 7 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 20: 0 libsystem_kernel.dylib 0x914e6366 __ioctl + 10 1 com.digidesign.framework.PlatformSupport 0x008c4e71 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 8220 2 com.digidesign.framework.DSK 0x0fac0d4c DSK_ParsedZone::Reset() + 5532 3 com.digidesign.framework.CoreFoundation 0x0022d094 Sys_RawThreadTask::Run() + 36 4 com.digidesign.framework.CoreFoundation 0x00249c34 Sys_RawThread::ThreadIDsAreEqual(void*, void*) + 68 5 com.digidesign.framework.PlatformSupport 0x008c52a3 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9294 6 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 7 libsystem_c.dylib 0x954f7dce thread_start + 34 |
Re: Pt 10 crash
Thread 21:
0 libsystem_kernel.dylib 0x914e6366 __ioctl + 10 1 com.digidesign.framework.PlatformSupport 0x008c4e71 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 8220 2 com.digidesign.framework.DSK 0x0fac0d4c DSK_ParsedZone::Reset() + 5532 3 com.digidesign.framework.CoreFoundation 0x0022d094 Sys_RawThreadTask::Run() + 36 4 com.digidesign.framework.CoreFoundation 0x00249c34 Sys_RawThread::ThreadIDsAreEqual(void*, void*) + 68 5 com.digidesign.framework.PlatformSupport 0x008c52a3 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9294 6 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 7 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 22: 0 libsystem_kernel.dylib 0x914e6366 __ioctl + 10 1 com.digidesign.framework.PlatformSupport 0x008c4e71 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 8220 2 com.digidesign.framework.DSK 0x0fac0d4c DSK_ParsedZone::Reset() + 5532 3 com.digidesign.framework.CoreFoundation 0x0022d094 Sys_RawThreadTask::Run() + 36 4 com.digidesign.framework.CoreFoundation 0x00249c34 Sys_RawThread::ThreadIDsAreEqual(void*, void*) + 68 5 com.digidesign.framework.PlatformSupport 0x008c52a3 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9294 6 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 7 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 23: 0 libsystem_kernel.dylib 0x914e6366 __ioctl + 10 1 com.digidesign.framework.PlatformSupport 0x008c4e71 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 8220 2 com.digidesign.framework.DSK 0x0fac0d4c DSK_ParsedZone::Reset() + 5532 3 com.digidesign.framework.CoreFoundation 0x0022d094 Sys_RawThreadTask::Run() + 36 4 com.digidesign.framework.CoreFoundation 0x00249c34 Sys_RawThread::ThreadIDsAreEqual(void*, void*) + 68 5 com.digidesign.framework.PlatformSupport 0x008c52a3 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9294 6 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 7 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 24: 0 libsystem_kernel.dylib 0x914e6366 __ioctl + 10 1 com.digidesign.framework.PlatformSupport 0x008c4e71 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 8220 2 com.digidesign.framework.DAE 0x0efa4ef5 FWMidiCallback + 505269 3 com.digidesign.framework.DAE 0x0ef787db FWMidiCallback + 323227 4 com.digidesign.framework.DAE 0x0efa4e92 FWMidiCallback + 505170 5 com.digidesign.framework.PlatformSupport 0x008c52b8 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9315 6 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 7 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 25: 0 libsystem_kernel.dylib 0x914e6366 __ioctl + 10 1 com.digidesign.framework.PlatformSupport 0x008c4e71 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 8220 2 com.digidesign.framework.DAE 0x0efa4ef5 FWMidiCallback + 505269 3 com.digidesign.framework.DAE 0x0ef787db FWMidiCallback + 323227 4 com.digidesign.framework.DAE 0x0efa4e92 FWMidiCallback + 505170 5 com.digidesign.framework.PlatformSupport 0x008c52b8 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9315 6 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 7 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 26: 0 libsystem_kernel.dylib 0x914e6366 __ioctl + 10 1 com.digidesign.framework.PlatformSupport 0x008c4e71 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 8220 2 com.digidesign.framework.DAE 0x0efa4ef5 FWMidiCallback + 505269 3 com.digidesign.framework.DAE 0x0ef787db FWMidiCallback + 323227 4 com.digidesign.framework.DAE 0x0efa4e92 FWMidiCallback + 505170 5 com.digidesign.framework.PlatformSupport 0x008c52b8 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9315 6 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 7 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 27: 0 libsystem_kernel.dylib 0x914e6366 __ioctl + 10 1 com.digidesign.framework.PlatformSupport 0x008c4e71 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 8220 2 com.digidesign.framework.DAE 0x0efa4ef5 FWMidiCallback + 505269 3 com.digidesign.framework.DAE 0x0ef787db FWMidiCallback + 323227 4 com.digidesign.framework.DAE 0x0efa4e92 FWMidiCallback + 505170 5 com.digidesign.framework.PlatformSupport 0x008c52b8 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9315 6 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 7 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 28: 0 libsystem_kernel.dylib 0x914e6366 __ioctl + 10 1 com.digidesign.framework.PlatformSupport 0x008c4e71 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 8220 2 com.digidesign.framework.DAE 0x0efa4ef5 FWMidiCallback + 505269 3 com.digidesign.framework.DAE 0x0ef787db FWMidiCallback + 323227 4 com.digidesign.framework.DAE 0x0efa4e92 FWMidiCallback + 505170 5 com.digidesign.framework.PlatformSupport 0x008c52b8 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9315 6 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 7 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 29: 0 libsystem_kernel.dylib 0x914e6366 __ioctl + 10 1 com.digidesign.framework.PlatformSupport 0x008c4e71 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 8220 2 com.digidesign.framework.DAE 0x0efa4ef5 FWMidiCallback + 505269 3 com.digidesign.framework.DAE 0x0ef787db FWMidiCallback + 323227 4 com.digidesign.framework.DAE 0x0efa4e92 FWMidiCallback + 505170 5 com.digidesign.framework.PlatformSupport 0x008c52b8 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9315 6 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 7 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 30: 0 libsystem_kernel.dylib 0x914e6366 __ioctl + 10 1 com.digidesign.framework.PlatformSupport 0x008c4e71 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 8220 2 com.digidesign.framework.DAE 0x0efa4ef5 FWMidiCallback + 505269 3 com.digidesign.framework.DAE 0x0ef787db FWMidiCallback + 323227 4 com.digidesign.framework.DAE 0x0efa4e92 FWMidiCallback + 505170 5 com.digidesign.framework.PlatformSupport 0x008c52b8 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9315 6 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 7 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 31:: com.apple.audio.IOThread.client 0 libsystem_kernel.dylib 0x914e47ce mach_msg_trap + 10 1 libsystem_kernel.dylib 0x914e3cac mach_msg + 68 2 com.apple.audio.CoreAudio 0x999498ba HALB_MachPort::SendMessageWithReply(unsigned int, unsigned int, unsigned long, unsigned long, mach_msg_header_t*, bool, unsigned int) + 138 3 com.apple.audio.CoreAudio 0x99943f2e HALB_MachPort::SendSimpleMessageWithSimpleReply(un signed int, unsigned int, int, int&, bool, unsigned int) + 70 4 com.apple.audio.CoreAudio 0x999425cd HALC_ProxyIOContext::IOWorkLoop() + 1287 5 com.apple.audio.CoreAudio 0x99942017 HALC_ProxyIOContext::IOThreadEntry(void*) + 145 6 com.apple.audio.CoreAudio 0x9994c561 ___ZN19HALC_ProxyIOContextC2Emj_block_invoke_0 + 20 7 com.apple.audio.CoreAudio 0x99941f3d HALB_IOThread::Entry(void*) + 71 8 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 9 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 32: 0 libsystem_kernel.dylib 0x914e6366 __ioctl + 10 1 com.digidesign.framework.PlatformSupport 0x008c4e71 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 8220 2 com.digidesign.framework.PlatformSupport 0x008cf52e PSThreadTable_AddTable(SPSThreadPriorityEntry const*, unsigned long) + 492 3 com.digidesign.framework.CoreFoundation 0x00249846 Sys_BlockingTimer:estroy(Sys_BlockingTimer*&) + 886 4 com.digidesign.framework.CoreFoundation 0x0022d280 Sys_RawThreadTimerTask::Exec() + 64 5 com.digidesign.framework.CoreFoundation 0x0022d094 Sys_RawThreadTask::Run() + 36 6 com.digidesign.framework.CoreFoundation 0x00249c34 Sys_RawThread::ThreadIDsAreEqual(void*, void*) + 68 7 com.digidesign.framework.PlatformSupport 0x008c52a3 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9294 8 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 9 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 33: 0 libsystem_kernel.dylib 0x914e691a __psynch_mutexwait + 10 1 libsystem_c.dylib 0x9551319b pthread_mutex_lock + 595 2 com.digidesign.framework.PlatformSupport 0x008c60c9 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 12916 3 com.digidesign.framework.CoreFoundation 0x0022d2a9 Sys_RawThreadTimerTask::Exec() + 105 4 com.digidesign.framework.CoreFoundation 0x0022d094 Sys_RawThreadTask::Run() + 36 5 com.digidesign.framework.CoreFoundation 0x00249c34 Sys_RawThread::ThreadIDsAreEqual(void*, void*) + 68 6 com.digidesign.framework.PlatformSupport 0x008c52a3 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9294 7 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 8 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 34: 0 libsystem_kernel.dylib 0x914e6366 __ioctl + 10 1 com.digidesign.framework.PlatformSupport 0x008c4e71 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 8220 2 com.digidesign.framework.PlatformSupport 0x008cf52e PSThreadTable_AddTable(SPSThreadPriorityEntry const*, unsigned long) + 492 3 com.digidesign.framework.ProTools 0x0dfce475 TTimelineSelectionLayer_ForwardDeclarationHack::Re moveReference(TTimelineSelectionLayer*) + 3395109 4 com.digidesign.framework.ProTools 0x0dfce8c8 TTimelineSelectionLayer_ForwardDeclarationHack::Re moveReference(TTimelineSelectionLayer*) + 3396216 5 com.digidesign.framework.CoreFoundation 0x0022d094 Sys_RawThreadTask::Run() + 36 6 com.digidesign.framework.CoreFoundation 0x00249c34 Sys_RawThread::ThreadIDsAreEqual(void*, void*) + 68 7 com.digidesign.framework.PlatformSupport 0x008c52a3 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9294 8 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 9 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 35: 0 libsystem_kernel.dylib 0x914e6366 __ioctl + 10 1 com.digidesign.framework.PlatformSupport 0x008c4e71 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 8220 2 com.digidesign.framework.PlatformSupport 0x008cf52e PSThreadTable_AddTable(SPSThreadPriorityEntry const*, unsigned long) + 492 3 com.digidesign.framework.ProTools 0x0dfce475 TTimelineSelectionLayer_ForwardDeclarationHack::Re moveReference(TTimelineSelectionLayer*) + 3395109 4 com.digidesign.framework.ProTools 0x0dfce4a8 TTimelineSelectionLayer_ForwardDeclarationHack::Re moveReference(TTimelineSelectionLayer*) + 3395160 5 com.digidesign.framework.CoreFoundation 0x0022d094 Sys_RawThreadTask::Run() + 36 6 com.digidesign.framework.CoreFoundation 0x00249c34 Sys_RawThread::ThreadIDsAreEqual(void*, void*) + 68 7 com.digidesign.framework.PlatformSupport 0x008c52a3 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9294 8 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 9 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 36: 0 libsystem_kernel.dylib 0x914e6366 __ioctl + 10 1 com.digidesign.framework.PlatformSupport 0x008c4e71 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 8220 2 com.digidesign.framework.PlatformSupport 0x008cf52e PSThreadTable_AddTable(SPSThreadPriorityEntry const*, unsigned long) + 492 3 com.digidesign.framework.CoreFoundation 0x0024987e Sys_BlockingTimer:estroy(Sys_BlockingTimer*&) + 942 4 com.digidesign.framework.ProTools 0x0dfee41d TTimelineSelectionLayer_ForwardDeclarationHack::Re moveReference(TTimelineSelectionLayer*) + 3526093 5 com.digidesign.framework.CoreFoundation 0x0022d094 Sys_RawThreadTask::Run() + 36 6 com.digidesign.framework.CoreFoundation 0x00249c34 Sys_RawThread::ThreadIDsAreEqual(void*, void*) + 68 7 com.digidesign.framework.PlatformSupport 0x008c52a3 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9294 8 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 9 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 37: 0 libsystem_kernel.dylib 0x914e6366 __ioctl + 10 1 com.digidesign.framework.PlatformSupport 0x008c4e71 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 8220 2 com.digidesign.framework.PlatformSupport 0x008cf52e PSThreadTable_AddTable(SPSThreadPriorityEntry const*, unsigned long) + 492 3 com.digidesign.framework.ProTools 0x0dfce475 TTimelineSelectionLayer_ForwardDeclarationHack::Re moveReference(TTimelineSelectionLayer*) + 3395109 4 com.digidesign.framework.ProTools 0x0dfce8c8 TTimelineSelectionLayer_ForwardDeclarationHack::Re moveReference(TTimelineSelectionLayer*) + 3396216 5 com.digidesign.framework.CoreFoundation 0x0022d094 Sys_RawThreadTask::Run() + 36 6 com.digidesign.framework.CoreFoundation 0x00249c34 Sys_RawThread::ThreadIDsAreEqual(void*, void*) + 68 7 com.digidesign.framework.PlatformSupport 0x008c52a3 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9294 8 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 9 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 38: 0 libsystem_kernel.dylib 0x914e47ce mach_msg_trap + 10 1 libsystem_kernel.dylib 0x914e3cac mach_msg + 68 2 com.apple.audio.midi.CoreMIDI 0x004d922d XServerMachPort::ReceiveMessage(int&, void*, int&) + 101 3 com.apple.audio.midi.CoreMIDI 0x004f6ae0 MIDIProcess::RunMIDIInThread() + 144 4 com.apple.audio.midi.CoreMIDI 0x004fcc48 MIDIProcess::MIDIInPortThread::Run() + 24 5 com.apple.audio.midi.CoreMIDI 0x004da805 XThread::RunHelper(void*) + 17 6 com.apple.audio.midi.CoreMIDI 0x004da2ee CAPThread::Entry(CAPThread*) + 196 7 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 8 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 39:: HSL::Collection 0 libsystem_kernel.dylib 0x914e6c72 __semwait_signal + 10 1 libsystem_c.dylib 0x95597a49 nanosleep$UNIX2003 + 189 2 libsystem_c.dylib 0x95597912 usleep$UNIX2003 + 60 3 libEuCon2.dylib 0x34997cb5 HSL::CCollectionThread::Run() + 25 4 libEuCon2.dylib 0x34994217 EuThreadRunWrapper::RunWrapper(EuThread*) + 17 5 libEuCon2.dylib 0x34993cad EuThread::ThreadStart(EuThread*) + 213 6 libEuCon2.dylib 0x34994091 (anonymous namespace)::startRoutine(void*) + 17 7 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 8 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 40:: EuDOF SendManager 0 libsystem_kernel.dylib 0x914e68e2 __psynch_cvwait + 10 1 libsystem_c.dylib 0x95512280 _pthread_cond_wait + 833 2 libsystem_c.dylib 0x955980d4 pthread_cond_timedwait$UNIX2003 + 70 3 libEuCon2.dylib 0x349944a7 EuEvent::Wait(unsigned int) + 187 4 libEuCon2.dylib 0x349aff6f EuDOF::SendManager::Run() + 377 5 libEuCon2.dylib 0x34994217 EuThreadRunWrapper::RunWrapper(EuThread*) + 17 6 libEuCon2.dylib 0x34993cad EuThread::ThreadStart(EuThread*) + 213 7 libEuCon2.dylib 0x34994091 (anonymous namespace)::startRoutine(void*) + 17 8 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 9 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 41:: EuDOF ReconnectServer 0 libsystem_kernel.dylib 0x914e6b3e __recvfrom + 10 1 libEuCon2.dylib 0x3498ca82 EuDataSocket::ReadFrom(EuSocketAddress&, void*, unsigned int&) + 136 2 libEuCon2.dylib 0x349ac812 EuDOF::ReconnectServer::Run() + 1220 3 libEuCon2.dylib 0x34994217 EuThreadRunWrapper::RunWrapper(EuThread*) + 17 4 libEuCon2.dylib 0x34993cad EuThread::ThreadStart(EuThread*) + 213 5 libEuCon2.dylib 0x34994091 (anonymous namespace)::startRoutine(void*) + 17 6 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 7 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 42:: Bonjour 0 libsystem_kernel.dylib 0x914e6be6 __select + 10 1 libEuCon2.dylib 0x349b495a EuDNSServices::HandleEvents(long) + 346 2 libEuCon2.dylib 0x349b51ff EuDNSServicesThread::Run() + 39 3 libEuCon2.dylib 0x34994217 EuThreadRunWrapper::RunWrapper(EuThread*) + 17 4 libEuCon2.dylib 0x34993cad EuThread::ThreadStart(EuThread*) + 213 5 libEuCon2.dylib 0x34994091 (anonymous namespace)::startRoutine(void*) + 17 6 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 7 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 43:: Periodic Update 0 libsystem_kernel.dylib 0x914e6c72 __semwait_signal + 10 1 libsystem_c.dylib 0x95597a49 nanosleep$UNIX2003 + 189 2 libsystem_c.dylib 0x95597912 usleep$UNIX2003 + 60 3 libEuCon2.dylib 0x348939eb EuPeriodicUpdateThread::Run() + 115 4 libEuCon2.dylib 0x3494b101 EuThreadCrashReport::RunWrapperCrashReport::RunWra pper(EuThread*) + 17 5 libEuCon2.dylib 0x34993cad EuThread::ThreadStart(EuThread*) + 213 6 libEuCon2.dylib 0x34994091 (anonymous namespace)::startRoutine(void*) + 17 7 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 8 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 44: 0 libsystem_kernel.dylib 0x914e6be6 __select + 10 1 libEuCon2.dylib 0x349ab358 EuDOF::ConnectionGroup::Wait(EuDOF::Connection*&, EuTime&) + 520 2 libEuCon2.dylib 0x349b2345 EuDOF::ServerModule::Run() + 669 3 libEuCon2.dylib 0x3494b101 EuThreadCrashReport::RunWrapperCrashReport::RunWra pper(EuThread*) + 17 4 libEuCon2.dylib 0x34993cad EuThread::ThreadStart(EuThread*) + 213 5 libEuCon2.dylib 0x34994091 (anonymous namespace)::startRoutine(void*) + 17 6 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 7 libsystem_c.dylib 0x954f7dce thread_start + 34 |
Re: Pt 10 crash
Thread 45:
0 libsystem_kernel.dylib 0x914e6366 __ioctl + 10 1 com.digidesign.framework.PlatformSupport 0x008c4e71 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 8220 2 com.digidesign.framework.PlatformSupport 0x008cf52e PSThreadTable_AddTable(SPSThreadPriorityEntry const*, unsigned long) + 492 3 com.digidesign.framework.CoreFoundation 0x00249846 Sys_BlockingTimer:estroy(Sys_BlockingTimer*&) + 886 4 com.digidesign.framework.CoreFoundation 0x0022d280 Sys_RawThreadTimerTask::Exec() + 64 5 com.digidesign.framework.CoreFoundation 0x0022d094 Sys_RawThreadTask::Run() + 36 6 com.digidesign.framework.CoreFoundation 0x00249c34 Sys_RawThread::ThreadIDsAreEqual(void*, void*) + 68 7 com.digidesign.framework.PlatformSupport 0x008c52a3 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9294 8 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 9 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 46: 0 libsystem_kernel.dylib 0x914e6be6 __select + 10 1 com.digidesign.framework.CoreFoundation 0x002492a0 Sys_Selectable::Select(Sys_SelectableVector&, Sys_SelectableVector&, Sys_SelectableVector&, long) + 560 2 com.digidesign.framework.TCPE 0x08295c46 TCPE_CommTask::ThreadMain() + 1062 3 com.digidesign.framework.CoreFoundation 0x0022d094 Sys_RawThreadTask::Run() + 36 4 com.digidesign.framework.CoreFoundation 0x00249c34 Sys_RawThread::ThreadIDsAreEqual(void*, void*) + 68 5 com.digidesign.framework.PlatformSupport 0x008c52a3 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9294 6 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 7 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 47: 0 libsystem_kernel.dylib 0x914e6366 __ioctl + 10 1 com.digidesign.framework.PlatformSupport 0x008c4e71 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 8220 2 com.digidesign.framework.PlatformSupport 0x008cf52e PSThreadTable_AddTable(SPSThreadPriorityEntry const*, unsigned long) + 492 3 com.digidesign.framework.TCPE 0x082928cd TCPE_SyncCommandTask::ThreadMain() + 141 4 com.digidesign.framework.CoreFoundation 0x0022d094 Sys_RawThreadTask::Run() + 36 5 com.digidesign.framework.CoreFoundation 0x00249c34 Sys_RawThread::ThreadIDsAreEqual(void*, void*) + 68 6 com.digidesign.framework.PlatformSupport 0x008c52a3 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9294 7 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 8 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 48: 0 libsystem_kernel.dylib 0x914e6366 __ioctl + 10 1 com.digidesign.framework.PlatformSupport 0x008c4e71 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 8220 2 com.digidesign.framework.PlatformSupport 0x008cf52e PSThreadTable_AddTable(SPSThreadPriorityEntry const*, unsigned long) + 492 3 com.digidesign.framework.CoreFoundation 0x0024a1ad Sys_WorkerThreadPool::ReleaseTask(Sys_WorkerThread Task*) + 285 4 com.digidesign.framework.CoreFoundation 0x0022d094 Sys_RawThreadTask::Run() + 36 5 com.digidesign.framework.CoreFoundation 0x00249c34 Sys_RawThread::ThreadIDsAreEqual(void*, void*) + 68 6 com.digidesign.framework.PlatformSupport 0x008c52a3 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9294 7 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 8 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 49: 0 libsystem_kernel.dylib 0x914e6366 __ioctl + 10 1 com.digidesign.framework.PlatformSupport 0x008c4e71 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 8220 2 com.digidesign.framework.DSK 0x0facb2f3 DSK_CAudioTraits:perator==(DSK_CAudioTraits const&) const + 1843 3 com.digidesign.framework.DSK 0x0facb4f9 DSK_CAudioTraits:perator==(DSK_CAudioTraits const&) const + 2361 4 com.digidesign.framework.CoreFoundation 0x0022d094 Sys_RawThreadTask::Run() + 36 5 com.digidesign.framework.CoreFoundation 0x00249c34 Sys_RawThread::ThreadIDsAreEqual(void*, void*) + 68 6 com.digidesign.framework.PlatformSupport 0x008c52a3 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9294 7 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 8 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 50: 0 libsystem_kernel.dylib 0x914e6366 __ioctl + 10 1 com.digidesign.framework.PlatformSupport 0x008c4e71 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 8220 2 com.digidesign.framework.DSK 0x0facb2f3 DSK_CAudioTraits:perator==(DSK_CAudioTraits const&) const + 1843 3 com.digidesign.framework.DSK 0x0facb4d9 DSK_CAudioTraits:perator==(DSK_CAudioTraits const&) const + 2329 4 com.digidesign.framework.CoreFoundation 0x0022d094 Sys_RawThreadTask::Run() + 36 5 com.digidesign.framework.CoreFoundation 0x00249c34 Sys_RawThread::ThreadIDsAreEqual(void*, void*) + 68 6 com.digidesign.framework.PlatformSupport 0x008c52a3 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9294 7 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 8 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 51: 0 libsystem_kernel.dylib 0x914e6366 __ioctl + 10 1 com.digidesign.framework.PlatformSupport 0x008c4e71 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 8220 2 com.digidesign.framework.DSK 0x0facb2f3 DSK_CAudioTraits:perator==(DSK_CAudioTraits const&) const + 1843 3 com.digidesign.framework.DSK 0x0facb499 DSK_CAudioTraits:perator==(DSK_CAudioTraits const&) const + 2265 4 com.digidesign.framework.CoreFoundation 0x0022d094 Sys_RawThreadTask::Run() + 36 5 com.digidesign.framework.CoreFoundation 0x00249c34 Sys_RawThread::ThreadIDsAreEqual(void*, void*) + 68 6 com.digidesign.framework.PlatformSupport 0x008c52a3 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9294 7 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 8 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 52: 0 libsystem_kernel.dylib 0x914e6366 __ioctl + 10 1 com.digidesign.framework.PlatformSupport 0x008c4e71 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 8220 2 com.digidesign.framework.DSK 0x0facb2f3 DSK_CAudioTraits:perator==(DSK_CAudioTraits const&) const + 1843 3 com.digidesign.framework.DSK 0x0facb4b9 DSK_CAudioTraits:perator==(DSK_CAudioTraits const&) const + 2297 4 com.digidesign.framework.CoreFoundation 0x0022d094 Sys_RawThreadTask::Run() + 36 5 com.digidesign.framework.CoreFoundation 0x00249c34 Sys_RawThread::ThreadIDsAreEqual(void*, void*) + 68 6 com.digidesign.framework.PlatformSupport 0x008c52a3 PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 9294 7 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 8 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 53: 0 libsystem_kernel.dylib 0x914e68e2 __psynch_cvwait + 10 1 libsystem_c.dylib 0x95512280 _pthread_cond_wait + 833 2 libsystem_c.dylib 0x955980d4 pthread_cond_timedwait$UNIX2003 + 70 3 com.slate-digital.VirtualChannel 0x3b0ed8f3 juce::WaitableEvent::wait(int) const + 163 4 com.slate-digital.VirtualChannel 0x3b2603df juce::InternalTimerThread::run() + 495 5 com.slate-digital.VirtualChannel 0x3b1379b0 juce::Thread::threadEntryPoint() + 800 6 com.slate-digital.VirtualChannel 0x3b15c54c juce::threadEntryProc(void*) + 76 7 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 8 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 54: 0 libsystem_kernel.dylib 0x914e68e2 __psynch_cvwait + 10 1 libsystem_c.dylib 0x95512280 _pthread_cond_wait + 833 2 libsystem_c.dylib 0x955980d4 pthread_cond_timedwait$UNIX2003 + 70 3 com.bluecataudio.BC MB-7 Mixer 2 AAX(Stereo) 0x4e0ace7f ACFRegisterPlugin + 6371903 4 com.bluecataudio.BC MB-7 Mixer 2 AAX(Stereo) 0x4df8de65 ACFRegisterPlugin + 5196325 5 com.bluecataudio.BC MB-7 Mixer 2 AAX(Stereo) 0x4ddfd5f7 ACFRegisterPlugin + 3555767 6 com.bluecataudio.BC MB-7 Mixer 2 AAX(Stereo) 0x4e08df3c ACFRegisterPlugin + 6245116 7 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 8 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 55: 0 libsystem_kernel.dylib 0x914e68e2 __psynch_cvwait + 10 1 libsystem_c.dylib 0x95512280 _pthread_cond_wait + 833 2 libsystem_c.dylib 0x955980d4 pthread_cond_timedwait$UNIX2003 + 70 3 com.bluecataudio.BC MB-7 Mixer 2 AAX(Stereo) 0x4e0ace7f ACFRegisterPlugin + 6371903 4 com.bluecataudio.BC MB-7 Mixer 2 AAX(Stereo) 0x4df8de65 ACFRegisterPlugin + 5196325 5 com.bluecataudio.BC MB-7 Mixer 2 AAX(Stereo) 0x4ddfd5f7 ACFRegisterPlugin + 3555767 6 com.bluecataudio.BC MB-7 Mixer 2 AAX(Stereo) 0x4e08df3c ACFRegisterPlugin + 6245116 7 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 8 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 56: 0 libsystem_kernel.dylib 0x914e70ee __workq_kernreturn + 10 1 libsystem_c.dylib 0x955100ac _pthread_workq_return + 45 2 libsystem_c.dylib 0x9550fe79 _pthread_wqthread + 448 3 libsystem_c.dylib 0x954f7daa start_wqthread + 30 Thread 57:: Juce Timer 0 libsystem_kernel.dylib 0x914e68e2 __psynch_cvwait + 10 1 libsystem_c.dylib 0x95512280 _pthread_cond_wait + 833 2 libsystem_c.dylib 0x955980d4 pthread_cond_timedwait$UNIX2003 + 70 3 com.slatedigital.vtm 0x58519470 0x582d2000 + 2389104 4 com.slatedigital.vtm 0x5851a84d 0x582d2000 + 2394189 5 com.slatedigital.vtm 0x5853e8f7 0x582d2000 + 2541815 6 com.slatedigital.vtm 0x5851a038 0x582d2000 + 2392120 7 com.slatedigital.vtm 0x58524475 0x582d2000 + 2434165 8 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 9 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 58: 0 libsystem_kernel.dylib 0x914e70ee __workq_kernreturn + 10 1 libsystem_c.dylib 0x955100ac _pthread_workq_return + 45 2 libsystem_c.dylib 0x9550fe79 _pthread_wqthread + 448 3 libsystem_c.dylib 0x954f7daa start_wqthread + 30 Thread 59:: CVDisplayLink 0 libsystem_kernel.dylib 0x914e68e2 __psynch_cvwait + 10 1 libsystem_c.dylib 0x95512280 _pthread_cond_wait + 833 2 libsystem_c.dylib 0x95598089 pthread_cond_wait$UNIX2003 + 71 3 com.apple.CoreVideo 0x9913c15a CVDisplayLink::runIOThread() + 912 4 com.apple.CoreVideo 0x9913bdb2 startIOThread(void*) + 160 5 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 6 libsystem_c.dylib 0x954f7dce thread_start + 34 Thread 60: 0 libsystem_kernel.dylib 0x914e70ee __workq_kernreturn + 10 1 libsystem_c.dylib 0x955100ac _pthread_workq_return + 45 2 libsystem_c.dylib 0x9550fe79 _pthread_wqthread + 448 3 libsystem_c.dylib 0x954f7daa start_wqthread + 30 Thread 61: 0 libsystem_kernel.dylib 0x914e5e9a __accept + 10 1 com.slate-digital.VirtualChannel 0x3b154997 juce::StreamingSocket::waitForNextConnection() const + 71 2 com.slate-digital.VirtualChannel 0x3b187c4a juce::InterprocessConnectionServer::run() + 42 3 com.slate-digital.VirtualChannel 0x3b1379b0 juce::Thread::threadEntryPoint() + 800 4 com.slate-digital.VirtualChannel 0x3b15c54c juce::threadEntryProc(void*) + 76 5 libsystem_c.dylib 0x9550d5b7 _pthread_start + 344 6 libsystem_c.dylib 0x954f7dce thread_start + 34 |
Re: Pt 10 crash
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x00000000 ebx: 0x0c949031 ecx: 0x00000011 edx: 0x00000000 edi: 0x00000000 esi: 0x668e7740 ebp: 0xbfffdf08 esp: 0xbfffde70 ss: 0x00000023 efl: 0x00010246 eip: 0x0c94915c cs: 0x0000001b ds: 0x00000023 es: 0x00000023 fs: 0x00000000 gs: 0x0000000f cr2: 0x00000024 Logical CPU: 2 Binary Images: 0x1000 - 0x142fef +com.digidesign.ProTools (10.3.9.462 - 10.3.9f462) <1317DBD5-9C7B-D245-88A4-9E392E09F0B6> /Applications/Avid/*/Pro Tools.app/Contents/MacOS/Pro Tools 0x173000 - 0x174fff +com.avid.breakpad_glue (1.0) <F79C0D39-60FE-D15D-9752-AA9F23604617> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/breakpad_glue.framework/Versions/A/breakpad_glue 0x178000 - 0x42afef +com.digidesign.framework.CoreFoundation (10.3.9.462 - 10.3.9f462) <AEBC747D-00D0-BA5A-3727-1A49F4BAE9DB> /Library/Frameworks/CFnd.framework/Versions/A/CFnd 0x4cb000 - 0x513ffb com.apple.audio.midi.CoreMIDI (1.9 - 78) <7AAE4076-36FA-37C1-9EAE-344F1C8F14D9> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI 0x538000 - 0x7e3fff +com.digidesign.framework.DFW (10.3.9.462 - 10.3.9f462) <43262F70-0678-7326-F4A7-F03D0238D6DF> /Library/Frameworks/DFW.framework/Versions/A/DFW 0x8bd000 - 0x8ebffb +com.digidesign.framework.PlatformSupport (10.3.9.462 - 10.3.9f462) <1C49888B-96DE-A28E-7770-230C61996B38> /Library/Frameworks/DigiPlatformSupport.framework/Versions/A/DigiPlatformSupport 0x90c000 - 0x9befff +com.digidesign.framework.DSI (10.3.9.462 - 10.3.9f462) <345EAC8D-AB4A-9E96-5277-0DD41F913A15> /Library/Frameworks/DSI.framework/Versions/A/DSI 0x9f4000 - 0xe4efe7 +com.digidesign.framework.FileFormat (10.3.9.462 - 10.3.9f462) <5D332F26-8083-5EAC-C968-478150935795> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/FFmt.framework/Versions/A/FFmt 0xf0f000 - 0xf17ff7 +com.googlecode.google-breakpad (1.0) <C2CDAF01-CA13-F537-9A8F-381D89EDF0F1> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/Breakpad.framework/Versions/A/Breakpad 0xf1f000 - 0xf2ffe7 +breakpadUtilities.dylib (1) <C35B07CF-D1E4-38C3-AF56-D2FA0BF5FC66> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/Breakpad.framework/Versions/A/Resources/breakpadUtilities.dylib 0xf3b000 - 0xf54ff7 com.apple.ScriptingBridge (1.3 - 61.2) <74397541-E4DD-3DCA-BA5F-F7AAF145819A> /System/Library/Frameworks/ScriptingBridge.framework/Versions/A/ScriptingBridge 0xf63000 - 0xf63ff7 libffi.dylib (18) <362F6C27-6407-388E-9521-8A2A0845188C> /usr/lib/libffi.dylib 0xf67000 - 0xf7dffc libexpat.1.dylib (12) <D4F1FD2B-F75A-322C-843E-113EF5F8EEAF> /usr/lib/libexpat.1.dylib 0xf86000 - 0x10a5ffb com.apple.WebKit (8536 - 8536.30.1) <4A5E9136-681F-3AB1-AD69-B59F2B9126E7> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit 0x1156000 - 0x1debff3 com.apple.WebCore (8536 - 8536.30.2) <D644997F-5F1A-34B4-AF32-DD427E9043E2> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore 0x2570000 - 0x2896fff +libNeoAccessPro.dylib (10.3.9) <3C80AD4E-DC9E-46AE-4614-1CE9C97DEB14> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/libNeoAccessPro.dylib 0x28f5000 - 0x28f8ff7 +com.digidesign.framework.LGC (10.3.9x462 - 10.3.9d462) <8FD7C80D-F580-BBC2-3C97-ECB4C8AFD4C0> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/LGC.framework/Versions/A/LGC 0x28fd000 - 0x29c8fe3 +libOMFToolkit.dylib (10.3.9) <8BCD9955-68C8-AC4D-0734-73B954BED0A9> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/libOMFToolkit.dylib 0x29e2000 - 0x29f8ff7 +com.digidesign.framework.AudioFoundation (10.3.9.462 - 10.3.9f462) <4D1EF84B-CFAF-92C4-1258-5A419594B67E> /Library/Frameworks/AFnd.framework/Versions/A/AFnd 0x2a5b000 - 0x2a6affb +com.digidesign.framework.digitrace (10.3.9.462 - 10.3.9f462) <E179E5C2-F698-3FC7-E96A-056E28E6AFCE> /Library/Application Support/Avid/*/Digitrace.framework/Digitrace 0x2fde000 - 0x2febff3 com.apple.Librarian (1.1 - 1) <68F8F983-5F16-3BA5-BDA7-1A5451CC02BB> /System/Library/PrivateFrameworks/Librarian.framework/Versions/A/Librarian 0x3fed000 - 0x3ff2fff +com.digidesign.framework.AAXShared (10.3.9.462 - 10.3.9f462) <577B97E0-EBBE-FD36-6133-F0AC9756AFDD> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/AAXShared.framework/Versions/A/AAXShared 0x3ff6000 - 0x3ffaff7 +com.digidesign.framework.TISys (10.3.9.462 - 10.3.9f462) <E87F8529-1AEB-5B95-E6AE-427DA5B0058C> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/TISys.framework/Versions/A/TISys 0x72f6000 - 0x72f9ff3 +libFicClockComponent.dylib (10.3.9) <7DA25872-0020-C03D-0EC9-5F09D0C035CA> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/libFicClockComponent.dylib 0x77c0000 - 0x77deff3 +com.digidesign.framework.CFD (10.3.9.462 - 10.3.9f462) <AE4F5CA1-EC00-EE40-1E52-16312CCDD3F4> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/CFD.framework/Versions/A/CFD 0x77e6000 - 0x77f1ff3 +com.digidesign.framework.TableView (1.0 - 10.3.9f462) <FE86EA2B-0055-A9A3-06F7-46231E155106> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/TableView.framework/Versions/A/TableView 0x8263000 - 0x827dffb +com.digidesign.framework.DMC (10.3.9.462 - 10.3.9f462) <B5FBBB35-B15C-A681-F380-A06515702D6A> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/DMC.framework/Versions/A/DMC 0x828c000 - 0x82a6fef +com.digidesign.framework.TCPE (10.3.9.462 - 10.3.9f462) <C6336B47-CD60-7CD0-C64A-1EE6DD281EB9> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/TCPE.framework/Versions/A/TCPE 0x82b6000 - 0x82bfff7 +com.digidesign.framework.KMM (10.3.9.462 - 10.3.9f462) <1BBAAC00-47F3-D53B-3C21-88A8477338BA> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/KMM.framework/Versions/A/KMM 0xb597000 - 0xb655ff3 ColorSyncDeprecated.dylib (400) <35E3054C-5DF1-30D4-A368-C4FDB0992373> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib 0xb703000 - 0xb70efff libGPUSupport.dylib (8.10.1) <B1E7ACE7-5A35-3182-912F-58143A39ECAF> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupport.dylib 0xb715000 - 0xb740ff7 GLRendererFloat (8.10.1) <18713434-312C-3B45-B3CE-B618DA3C8D09> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFloat 0xb749000 - 0xb751ffd libcldcpuengine.dylib (2.2.16) <43E630D7-14C3-3455-9A4E-B5EBFA638C9D> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib 0xb86f000 - 0xb8c9fdf +com.reFX.Nexus (1.4.1 - 1.4.1) /Library/Application Support/Digidesign/*/Nexus 0xb941000 - 0xb946fff com.apple.audio.AppleHDAHALPlugIn (2.4.7 - 2.4.7fc4) <E76A669B-0A88-32B1-88F3-75D7DE065956> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn 0xc0cd000 - 0xe8b2fe3 +com.digidesign.framework.ProTools (10.3.9.462 - 10.3.9f462) <2E3D7FB0-C84E-0FDB-0EE4-12F45F6ED771> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/Pro Tools.framework/Pro Tools 0xee9c000 - 0xf189ff3 +com.digidesign.framework.DAE (10.3.9.462 - 10.3.9f462) <C7F0ABB7-F092-ACBF-7EA9-5128FFE96AE1> /Library/Frameworks/DAE.framework/Versions/A/DAE 0xf1e8000 - 0xf355ff3 +com.digidesign.framework.SystemLink (10.3.9.462 - 10.3.9f462) <7F30AD9D-A65B-C3E1-4F1F-C81A9908D395> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/SystemLink.framework/Versions/A/SystemLink 0xf3a3000 - 0xf3e7ffb +com.digidesign.framework.Sib (1.0 - 1.0) <FAB47CDB-236E-70A9-A614-07DC74E3A5C6> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/Sib.framework/Versions/A/Sib 0xf412000 - 0xf4e9ffb +com.digidesign.framework.BUI (10.3.9.462 - 10.3.9f462) <60F9852E-0EEE-42A4-C3CD-7C46A8B0D62B> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/BUI.framework/Versions/A/BUI 0xf536000 - 0xf59dff3 +com.digidesign.framework.Gtr (10.3.9.462 - 10.3.9f462) <7A38F10F-475E-5D9D-77F2-E497E9895471> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/Gtr.framework/Versions/A/Gtr 0xf5bb000 - 0xf5c5ffb +VenueLink (10.3.9) <FF9F3BAB-4999-6A4A-FE96-ACEDE35E7DBF> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/VenueLink.framework/Versions/A/VenueLink 0xf5d6000 - 0xf786ffb +com.avid.framework.TIShellMgr (10.3.9.462 - 10.3.9f462) <890AD1FF-F3A9-D192-B659-AE62145A7986> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/TIShellMgr.framework/Versions/A/TIShellMgr 0xf804000 - 0xf82bff7 +com.digidesign.framework.TIDSPMgr (10.3.9.462 - 10.3.9f462) <4DA26529-709C-02FB-D086-E4A1BFE8ED27> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/TIDspMgr.framework/Versions/A/TIDspMgr 0xf832000 - 0xfa1fffb +com.avid.framework.AAXHost (10.3.9.462 - 10.3.9f462) <3385C4FD-FA97-469A-F20C-444859AF76EA> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/AAXHost.framework/Versions/A/AAXHost 0xfa69000 - 0xfaa8ffb +com.digidesign.framework.DSPManager (10.3.9.462 - 10.3.9f462) <B797B67B-02E1-3CD1-13CD-B518289E4DB7> /Library/Frameworks/DSPManager.framework/Versions/A/DSPManager 0xfab0000 - 0xfaf2fe7 +com.digidesign.framework.DSK (10.3.9.462 - 10.3.9f462) <A6C2F576-0EB6-030B-3801-60F8570E5021> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/DSK.framework/Versions/A/DSK 0xfafd000 - 0xfb2cfff +com.digidesign.framework.CDS (10.3.9.462 - 10.3.9f462) <50234598-F1D5-6D17-C114-A70FED5EBE01> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/CDS.framework/Versions/A/CDS 0xfb33000 - 0xfb47ff7 +libTrns.dylib (10.3.9) <505B1974-8299-9CFE-2CD9-51F555C8C78B> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/libTrns.dylib 0x10fd0000 - 0x10fd1ffd com.apple.ironwoodcore (1.1.1 - 1.1.1) <098CE576-3239-3B41-9141-A5BE6E476C84> /System/Library/PrivateFrameworks/SpeechObjects.framework/Versions/A/Frameworks/DictationServicesCore.framework/DictationServicesCore 0x11f00000 - 0x11f6bffb +com.digidesign.plugin.DigiReWire (10.3.9.462 - 10.3.9f462) <E8470E5F-8062-587D-083E-3177D922FA18> /Library/Application Support/Digidesign/*/DigiReWire 0x13200000 - 0x1393cfe7 +com.bluecataudio.BC Chorus 4 RTAS(Mono) ("4.02" - "4.02") <04911190-18FC-2CBE-8C75-E402C713E4F9> /Library/Application Support/Digidesign/*/BC Chorus 4 RTAS(Mono) 0x13bb2000 - 0x142fefef +com.bluecataudio.BC Chorus 4 RTAS(Stereo) ("4.02" - "4.02") <8C20834D-D9C4-2E18-F706-B6EA611F3653> /Library/Application Support/Digidesign/*/BC Chorus 4 RTAS(Stereo) 0x14577000 - 0x14cb3fe7 +com.bluecataudio.BC Flanger 3 RTAS(Mono) ("3.02" - "3.02") <BD0E87B5-8AE1-E4DE-1D6C-E658F3198F33> /Library/Application Support/Digidesign/*/BC Flanger 3 RTAS(Mono) 0x14f29000 - 0x15675fff +com.bluecataudio.BC Flanger 3 RTAS(Stereo) ("3.02" - "3.02") <65BA0AA3-89F9-44FB-262D-699F3C086135> /Library/Application Support/Digidesign/*/BC Flanger 3 RTAS(Stereo) 0x158ee000 - 0x16044fe7 +com.bluecataudio.BC FreqAnalyst 2 RTAS(Mono) ("2.02" - "2.02") <F08916D9-5569-B8C5-CEE7-5472F37FA6DF> /Library/Application Support/Digidesign/*/BC FreqAnalyst 2 RTAS(Mono) 0x162be000 - 0x16a25fe3 +com.bluecataudio.BC FreqAnalyst 2 RTAS(Stereo) ("2.02" - "2.02") <B0FD6152-9AD3-BDD3-47D5-9C91B2EAEB9E> /Library/Application Support/Digidesign/*/BC FreqAnalyst 2 RTAS(Stereo) 0x16ca2000 - 0x173fdfeb +com.bluecataudio.BC Gain 3 RTAS(Dual) ("3.02" - "3.02") <649AD786-10F3-2289-47C7-19FC40D71DD0> /Library/Application Support/Digidesign/*/BC Gain 3 RTAS(Dual) 0x1767c000 - 0x17db7fff +com.bluecataudio.BC Gain 3 RTAS(Mono) ("3.02" - "3.02") <90E8EBF5-A042-24B8-CB0B-03912952C61D> /Library/Application Support/Digidesign/*/BC Gain 3 RTAS(Mono) 0x1802d000 - 0x18776feb +com.bluecataudio.BC Gain 3 RTAS(Stereo) ("3.02" - "3.02") <2F7C49FD-3795-73BB-7ED0-CA23C7332BB9> /Library/Application Support/Digidesign/*/BC Gain 3 RTAS(Stereo) 0x189f0000 - 0x1912dfeb +com.bluecataudio.BC Phaser 3 RTAS(Mono) ("3.02" - "3.02") <99A844BF-5EF6-3896-EDC1-7B2FE29D896F> /Library/Application Support/Digidesign/*/BC Phaser 3 RTAS(Mono) 0x193a3000 - 0x19af0ff3 +com.bluecataudio.BC Phaser 3 RTAS(Stereo) ("3.02" - "3.02") <422BF053-BB0D-7649-5CD1-D2DB3C3D36C5> /Library/Application Support/Digidesign/*/BC Phaser 3 RTAS(Stereo) 0x19d69000 - 0x1a4d3fef +com.bluecataudio.BC Triple EQ 4 RTAS(Dual) ("4.02" - "4.02") <3D27FA25-C12B-4E14-3AEC-18BB32DB756D> /Library/Application Support/Digidesign/*/BC Triple EQ 4 RTAS(Dual) 0x1a752000 - 0x1aea0ff3 +com.bluecataudio.BC Triple EQ 4 RTAS(Mono) ("4.02" - "4.02") <3C6BA014-2A07-49EA-BABF-8436F93F29BB> /Library/Application Support/Digidesign/*/BC Triple EQ 4 RTAS(Mono) 0x1b11b000 - 0x1b875fef +com.bluecataudio.BC Triple EQ 4 RTAS(Stereo) ("4.02" - "4.02") <E4F9409D-F7CD-26B9-6209-A826340FD4CE> /Library/Application Support/Digidesign/*/BC Triple EQ 4 RTAS(Stereo) 0x1baf5000 - 0x1bb7cffb +se.propellerheads.rewire.library (1.8.1 build 124 - 1.8.1) <79A1E240-4153-9288-475D-697D84C94343> /Library/Application Support/Propellerhead Software/*/ReWire.bundle/Contents/MacOS/ReWire 0x1bb8a000 - 0x1bd3efec +com.Lexicon.Native.LexChamber (Release 1.1.3 - 1.1.3) <D17C3E6A-E83E-D986-75AA-5593CA34B676> /Library/Application Support/Digidesign/*/LexChamber 0x1be7a000 - 0x1bee0fcf +[Unknown Bundle] (???) <5A1DE9E0-9F4C-49B3-B9A9-D95A837841F3> [Unknown Bundle] 0x1bf02000 - 0x1bf2ffe3 +com.avid.avid.AvidCoreAudioPlugIn (10.3.9.462 - 10.3.9f462) <5A11C693-E72B-4A20-22E5-D1E1A5F6E570> /Library/Audio/Plug-Ins/HAL/Avid CoreAudio.plugin/Contents/MacOS/Avid CoreAudio 0x1c15e000 - 0x1c355ff3 +com.soundtoys.rtas.Crystallizer (4.1.1 - 4.1.1) <BF0A8823-1C1D-276E-E3EC-00AE58871C33> /Library/Application Support/Digidesign/*/Crystallizer 0x1c517000 - 0x1c541ff7 +com.grame.JackRouter (JackRouter - 0.9.5) <13AB2581-FFAF-AC76-FB8F-D1C8779C94AF> /Library/Audio/Plug-Ins/HAL/JackRouter.plugin/Contents/MacOS/JackRouter 0x1c557000 - 0x1c580fff +Jackmp (1) <0B8EB3A5-FD59-2D99-839C-2D4A9A59AA94> /Library/Frameworks/Jackmp.framework/Versions/A/Jackmp 0x1c8a3000 - 0x1ca54fec +com.Lexicon.Native.LexConcertHall (Release 1.1.3 - 1.1.3) <2CE2C075-FB4C-1AEF-FA80-5F86695D4CEA> /Library/Application Support/Digidesign/*/LexConcertHall 0x1caca000 - 0x1cc7dfec +com.Lexicon.Native.LexHall (Release 1.1.3 - 1.1.3) <167ACC65-62AA-40AC-39E3-2AE9BB334563> /Library/Application Support/Digidesign/*/LexHall 0x1ccf5000 - 0x1cea9ffc +com.Lexicon.Native.LexPlate (Release 1.1.3 - 1.1.3) <83412A55-2999-0AF2-7198-7F3341AD5D3C> /Library/Application Support/Digidesign/*/LexPlate 0x1cf21000 - 0x1d0d4fec +com.Lexicon.Native.LexRandomHall (Release 1.1.3 - 1.1.3) <C9CF76BD-6358-1F0C-DF81-4A7156848F6B> /Library/Application Support/Digidesign/*/LexRandomHall 0x1d14c000 - 0x1d2ffffc +com.Lexicon.Native.LexRoom (Release 1.1.3 - 1.1.3) <45A333A6-B605-71A3-988D-298EFD7AC718> /Library/Application Support/Digidesign/*/LexRoom 0x1d39b000 - 0x1d54fffc +com.Lexicon.Native.LexVintagePlate (Release 1.1.3 - 1.1.3) <49F869D3-1B41-DAFA-329E-B43CF0579D9D> /Library/Application Support/Digidesign/*/LexVintagePlate 0x1d5c7000 - 0x1dca5ff7 +com.samplemagic.ABPlugin (1.0) <0739AF6B-03F7-D737-CDE4-178886B9898A> /Library/Application Support/Digidesign/*/Magic AB RTAS 0x1defe000 - 0x1e76effb +com.zynaptiq.pitchmap (1.6.1) <D16C6A77-4E88-FEB0-CFB3-6B1C0C456EA0> /Library/Application Support/Digidesign/*/PITCHMAP RTAS 0x1ea03000 - 0x1ed7efe7 +com.112dB.Redline.Monitor.RTAS (1.0.6 - 1.0.6) <B7D4DC14-B633-3724-8DE5-22F8A3B1080B> /Library/Application Support/Digidesign/*/Redline Monitor 0x1edf0000 - 0x1f16afef +com.112dB.Redline.Reverb.RTAS (1.0.8 - 1.0.8) <BF8891B7-231B-3691-B23F-6521C3D1BB9E> /Library/Application Support/Digidesign/*/Redline Reverb 0x1f1dd000 - 0x1f252feb +com.digidesign.plugin.SignalGenerator (8.0.0 - 8.0.0f314) <A1D4E580-71BE-08CF-EC16-51112EE3D4B4> /Library/Application Support/Digidesign/*/Signal Generator 0x1f2aa000 - 0x2002bffb +com.slatedigital.SSDSampler (1.1 - ???) <8111C996-BC15-7824-24A1-C76DB93CADB1> /Library/Application Support/Digidesign/*/SSDSampler 0x201d8000 - 0x2025dfe3 +com.digidesign.mixer.surround (10.3.9.462 - 10.3.9f462) <DCF33750-5F88-9C70-D496-FAE02B19F612> /Library/Application Support/Digidesign/*/Surround Mixer 0x2029a000 - 0x20b48fff +com.zynaptiq.unfilter (1.2.1) <554A9F96-0AC0-CF42-7CA1-FE48B86D42E6> /Library/Application Support/Digidesign/*/UNFILTER RTAS 0x20dde000 - 0x2165dfeb +com.zynaptiq.unveil (1.7.6) <7F1FA165-8F97-88CD-2DC4-1F709C3D81C9> /Library/Application Support/Digidesign/*/UNVEIL RTAS 0x218ec000 - 0x21974fef +com.synchroarts.audiosuite.VocALignPro (4.1.4 - 4.1.4) <01D742AC-45E3-1EC3-AC94-D9D70A3F9F1A> /Library/Application Support/Digidesign/*/VocALignPro 0x21bc0000 - 0x21de0fe3 +com.WavesAudio.WaveShell-DAE.9.2.100 (9.2.100 - 9.2.1006) <77ECF6E9-12A9-9A6E-29A8-398AF8E81D56> /Library/Application Support/Digidesign/*/WaveShell-DAE 0x21f9d000 - 0x22131ffb GLEngine (8.10.1) <8A61333B-95FF-34C4-8D4F-73A592F98FEC> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine 0x22168000 - 0x222e9fff libGLProgrammability.dylib (8.10.1) <3DE23C07-D1D8-3647-8185-6C5A0113669F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib 0x223ef000 - 0x223f1ff7 +GenericMacIntel.dylib (0) <52F058BF-F3AB-A5AB-154E-9DABF83BDD54> /Applications/Waves/*/1447251280.bundle/Contents/MacOS/GenericMacIntel.dylib 0x223f4000 - 0x223f5fff +GenericMacIntel.dylib (0) <86B9E67F-4DA1-11F8-5F7A-6B4CA860534E> /Applications/Waves/*/1398031697.bundle/Contents/MacOS/GenericMacIntel.dylib 0x227f4000 - 0x227f5ff1 +cl_kernels (???) <7D12F599-AE00-4F11-B6DD-82917102E854> cl_kernels 0x23800000 - 0x23a0afe3 +com.WavesAudio.WavesLib_9.2.9.2.80 (9.2.80 - 9.2.802) <6858252F-6169-4083-BC9F-14249AD53D02> /Applications/Waves/*/WavesLib_9.2.framework/Versions/A/WavesLib 0x23b56000 - 0x23ba0fe7 +com.digidesign.personality.003 (10.3.9.462 - 10.3.9f462) <9646F9C3-ED6D-A625-E811-C04A121841E5> /Applications/Avid/*/003.bundle/Contents/MacOS/003 0x23d00000 - 0x24315feb +com.bluecataudio.Blue Cat DPeakMeter Pro RTAS(Mono) (VERSION_STR - 1.0) <B0A69E78-4E88-A222-1B67-58E34F706AB2> /Library/Application Support/Digidesign/*/Blue Cat DPeakMeter Pro RTAS(Mono) 0x2452e000 - 0x24b4eff3 +com.bluecataudio.Blue Cat DPeakMeter Pro RTAS(Stereo) (VERSION_STR - 1.0) <E1CB7DA1-E5E1-C6BD-40AB-E7065C3DE842> /Library/Application Support/Digidesign/*/Blue Cat DPeakMeter Pro RTAS(Stereo) 0x24d6b000 - 0x25349feb +com.bluecataudio.Blue Cat Dynamics RTAS(Mono) (VERSION_STR - 1.0) <6E10CFAE-D824-6E7E-DA76-7F7AC45B9900> /Library/Application Support/Digidesign/*/Blue Cat Dynamics RTAS(Mono) 0x2558f000 - 0x25b76fef +com.bluecataudio.Blue Cat Dynamics RTAS(Stereo) (VERSION_STR - 1.0) <9B4F431D-523E-0B18-26A0-FDF793F91611> /Library/Application Support/Digidesign/*/Blue Cat Dynamics RTAS(Stereo) 0x25dbe000 - 0x263ebfe3 +com.bluecataudio.Blue Cat FreqAnalyst Multi RTAS (VERSION_STR - 1.0) <60A1474F-DE55-9980-B1E7-517D54D37263> /Library/Application Support/Digidesign/*/Blue Cat FreqAnalyst Multi RTAS 0x26608000 - 0x26c33ffb +com.bluecataudio.Blue Cat FreqAnalyst Pro RTAS(Mono) (VERSION_STR - 1.0) <C6DB813B-C990-AE15-8872-503EC3D3705B> /Library/Application Support/Digidesign/*/Blue Cat FreqAnalyst Pro RTAS(Mono) 0x26e50000 - 0x2748bff3 +com.bluecataudio.Blue Cat FreqAnalyst Pro RTAS(Stereo) (VERSION_STR - 1.0) <3CF3D18D-1141-DE5E-3038-84265B9F5D2B> /Library/Application Support/Digidesign/*/Blue Cat FreqAnalyst Pro RTAS(Stereo) 0x276ab000 - 0x27c80fef +com.bluecataudio.Blue Cat Liny EQ RTAS(Mono) (VERSION_STR - 1.0) <EDD91033-61F1-D816-643A-62E5972968E0> /Library/Application Support/Digidesign/*/Blue Cat Liny EQ RTAS(Mono) |
Re: Pt 10 crash
0x27ec6000 - 0x2849cff7 +com.bluecataudio.Blue Cat Liny EQ RTAS(Stereo) (VERSION_STR - 1.0) <A431D870-F972-3F21-4654-80335BC126F3> /Library/Application Support/Digidesign/*/Blue Cat Liny EQ RTAS(Stereo)
0x286e3000 - 0x28d26fe3 +com.bluecataudio.Blue Cat MB5 Dynamix RTAS(Mono) (VERSION_STR - 1.0) <9D4469D1-0953-4E33-0CD2-269F67D2A8C1> /Library/Application Support/Digidesign/*/Blue Cat MB5 Dynamix RTAS(Mono) 0x29542000 - 0x295a2ff7 +com.digidesign.framework.HWC (10.3.9.462 - 10.3.9f462) <6D260920-C7F3-EB41-B7E2-C2ECC7A8F832> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/HWC.framework/Versions/A/HWC 0x295f6000 - 0x295f6fff +cl_kernels (???) <59228558-E02C-4DF5-BF88-0360C14BB83C> cl_kernels 0x295fb000 - 0x295fbff5 +cl_kernels (???) <666AC664-CD60-46D5-9696-1B0BE9E7B719> cl_kernels 0x29742000 - 0x29d92ff3 +com.bluecataudio.Blue Cat MB5 Dynamix RTAS(Stereo) (VERSION_STR - 1.0) <AAB128D6-14D9-4FDE-8DE3-04A96BC25D33> /Library/Application Support/Digidesign/*/Blue Cat MB5 Dynamix RTAS(Stereo) 0x29ff2000 - 0x29ff7ff3 +GenericMacIntel.dylib (0) <B49284BF-A879-413E-A243-A60BD9BDAA43> /Applications/Waves/*/1448169780.bundle/Contents/MacOS/GenericMacIntel.dylib 0x29ffa000 - 0x29ffbff7 +GenericMacIntel.dylib (0) <D101E8F0-F9A5-F155-ED1D-AF7CDB6E633A> /Applications/Waves/*/1398030938.bundle/Contents/MacOS/GenericMacIntel.dylib 0x2a100000 - 0x2a182fef +com.digidesign.personality.C24 (10.3.9.462 - 10.3.9f462) <D3575D6B-538C-464E-5011-0B5EC31F51AE> /Applications/Avid/*/C24.bundle/Contents/MacOS/C24 0x2a1b1000 - 0x2a7daff3 +com.bluecataudio.Blue Cat Oscilloscope Multi RTAS (VERSION_STR - 1.0) <D61E096A-F115-8296-3DDD-914B5E7B0525> /Library/Application Support/Digidesign/*/Blue Cat Oscilloscope Multi RTAS 0x2a9f9000 - 0x2afe7fe7 +com.bluecataudio.Blue Cat ParametrEQ RTAS(Mono) (VERSION_STR - 1.0) <187F13E8-3E9E-6E32-D7A5-238D79DE2B82> /Library/Application Support/Digidesign/*/Blue Cat ParametrEQ RTAS(Mono) 0x2b236000 - 0x2b828feb +com.bluecataudio.Blue Cat ParametrEQ RTAS(Stereo) (VERSION_STR - 1.0) <CC6AFBBE-A1D8-DD4A-086C-1C5A8F79595A> /Library/Application Support/Digidesign/*/Blue Cat ParametrEQ RTAS(Stereo) 0x2ba78000 - 0x2c041ff7 +com.bluecataudio.Blue Cat Protector RTAS (VERSION_STR - 1.0) <54033BFA-60B9-DCEA-9C4B-39A01075BF15> /Library/Application Support/Digidesign/*/Blue Cat Protector RTAS 0x2c284000 - 0x2c860fff +com.bluecataudio.Blue Cat Stereo Liny EQ RTAS (VERSION_STR - 1.0) <3CF4A519-D0FB-8EE4-E609-80FECCB5B5EA> /Library/Application Support/Digidesign/*/Blue Cat Stereo Liny EQ RTAS 0x2caa9000 - 0x2d09efef +com.bluecataudio.Blue Cat Stereo ParametrEQ RTAS (VERSION_STR - 1.0) <51095589-D636-610B-4BFB-B73E24D8D8A1> /Library/Application Support/Digidesign/*/Blue Cat Stereo ParametrEQ RTAS 0x2d2ee000 - 0x2d8ccff7 +com.bluecataudio.Blue Cat Stereo Triple EQ RTAS (VERSION_STR - 1.0) <5A5A06D8-94DD-C9F7-0054-0C2C24C035A9> /Library/Application Support/Digidesign/*/Blue Cat Stereo Triple EQ RTAS 0x2db19000 - 0x2e138ff3 +com.bluecataudio.Blue Cat StereoScope Multi RTAS (VERSION_STR - 1.0) <F8112B6A-D764-2C03-8722-1F441586EC44> /Library/Application Support/Digidesign/*/Blue Cat StereoScope Multi RTAS 0x2e354000 - 0x2e976ffb +com.bluecataudio.Blue Cat StereoScope Pro RTAS (VERSION_STR - 1.0) <50379FB1-AE7F-C04E-7F23-6A0C5868B722> /Library/Application Support/Digidesign/*/Blue Cat StereoScope Pro RTAS 0x2eb93000 - 0x2f174fff +com.bluecataudio.Blue Cat Widening Liny EQ RTAS (VERSION_STR - 1.0) <787C23D3-B0EA-1211-CB01-652EC0F21AA0> /Library/Application Support/Digidesign/*/Blue Cat Widening Liny EQ RTAS 0x2f3be000 - 0x2f9b9fe3 +com.bluecataudio.Blue Cat Widening ParametrEQ RTAS (VERSION_STR - 1.0) <BF332E7B-D44F-2990-1435-2287BE6DBD11> /Library/Application Support/Digidesign/*/Blue Cat Widening ParametrEQ RTAS 0x2fc0c000 - 0x301effff +com.bluecataudio.Blue Cat Widening Triple EQ RTAS (VERSION_STR - 1.0) <C27288DE-24E3-4876-6035-F2EC54FE5C63> /Library/Application Support/Digidesign/*/Blue Cat Widening Triple EQ RTAS 0x3043f000 - 0x30be1ff8 +com.slatedigital.Trigger (1.66 - ???) <0909FB06-7A2F-11EE-959A-5AB9E9EBE027> /Library/Application Support/Digidesign/*/Trigger 0x3100c000 - 0x3123fffb +com.soundtoys.rtas.Decapitator (4.1.1 - 4.1.1) <EC810B12-0DDC-F1BF-8E93-009CBDBDE51B> /Library/Application Support/Digidesign/*/Decapitator 0x31726000 - 0x31980feb +com.soundtoys.rtas.EchoBoy (4.1.1 - 4.1.1) <CC00E2E1-7F9B-B159-D677-3B02C05F3B55> /Library/Application Support/Digidesign/*/EchoBoy 0x31b54000 - 0x31d6bff3 +com.soundtoys.rtas.FilterFreak (4.1.1 - 4.1.1) <FAF83055-83B7-9E8C-9709-92548D3ADC50> /Library/Application Support/Digidesign/*/FilterFreak 0x31f40000 - 0x32163fe7 +com.soundtoys.rtas.PanMan (4.1.1 - 4.1.1) <8A4BDE2F-560C-82DD-5542-250B16DF2571> /Library/Application Support/Digidesign/*/PanMan 0x3233c000 - 0x32551ff3 +com.soundtoys.rtas.PhaseMistress (4.1.1 - 4.1.1) <B939DAE8-8572-6650-6E2F-4189FA2FAE2D> /Library/Application Support/Digidesign/*/PhaseMistress 0x32723000 - 0x3291dfff +com.soundtoys.rtas.Tremolator (4.1.1 - 4.1.1) <01A8C000-0718-A1E0-1A6F-5303A25F6E51> /Library/Application Support/Digidesign/*/Tremolator 0x32c04000 - 0x32eb3fff +libcom-api.dylib (0) <C889CB9E-ED03-2162-4844-E1901911E35F> /Applications/Avid/*/Pro Tools.app/Contents/Frameworks/libcom-api.dylib 0x3436c000 - 0x344daff7 +com.digidesign.personality.DCommand (10.3.9.462 - 10.3.9f462) <CC23DAF7-7DF5-4CEA-5321-E12C4F3A1AB6> /Applications/Avid/*/D-Command.bundle/Contents/MacOS/D-Command 0x34509000 - 0x346e0fe7 +com.digidesign.personality.DControl (10.3.9.462 - 10.3.9f462) <3DC8EE12-77F6-3ADA-2696-067A0B21C780> /Applications/Avid/*/D-Control.bundle/Contents/MacOS/D-Control 0x3471a000 - 0x3482effb +com.digidesign.personality.EuCon (10.3.9.462 - 10.3.9f462) <7717794C-590A-9895-352F-7A1B8FEB3887> /Applications/Avid/*/EuCon.bundle/Contents/MacOS/EUCON 0x34857000 - 0x34a63ff7 +libEuCon2.dylib (1) <3190D2F0-EC9C-3CD1-8325-23A101A0C055> /usr/local/lib/libEuCon2.dylib 0x36e3c000 - 0x36e3dff3 +com.Universal Audio.fxshared (1.0 - 1.0) <D66B88BB-F405-0B4F-ACCC-40A7AC5C65A0> /Library/Application Support/Universal Audio/com.Universal Audio.fxshared.bundle/Contents/MacOS/com.Universal Audio.fxshared 0x36e46000 - 0x36e4aff3 +GenericMacIntel.dylib (0) <86DFB5F8-7B16-8B15-F736-3C38C285DA7C> /Applications/Waves/*/SuperTap.bundle/Contents/MacOS/GenericMacIntel.dylib 0x36e4f000 - 0x36e50ffd com.apple.textencoding.unicode (2.5 - 2.5) <4E2ABBEB-1F0D-3C06-BA0C-C3CEDDF17BD2> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings 0x36e57000 - 0x36e58ffb +GenericMacIntel.dylib (0) <43E3AC50-FAF3-7398-92C4-5D96E4B4C00D> /Applications/Waves/*/1163284300.bundle/Contents/MacOS/GenericMacIntel.dylib 0x37125000 - 0x371b7fff unorm8_bgra.dylib (2.2.16) <1298D118-0B14-3F3D-B2CA-348A1C67183E> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra.dylib 0x371c9000 - 0x3725bfff unorm8_argb.dylib (2.2.16) <1834DE22-065D-395E-8E00-1A131B3FD30B> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_argb.dylib 0x37fc3000 - 0x37fedfff +GenericMacIntel.dylib (0) <1284CC11-F601-AA7D-FF1C-45768A0C56FA> /Applications/Waves/*/Maserati B72.bundle/Contents/MacOS/GenericMacIntel.dylib 0x37ff5000 - 0x37ff7fff +GenericMacIntel.dylib (0) <CDF57C18-748F-AF3F-E271-E40DB46DB012> /Applications/Waves/*/1398031948.bundle/Contents/MacOS/GenericMacIntel.dylib 0x37ffa000 - 0x37ffcffb +GenericMacIntel.dylib (0) <88F38B20-95AF-5FD5-22B7-DC053BB22E10> /Applications/Waves/*/1398031187.bundle/Contents/MacOS/GenericMacIntel.dylib 0x39800000 - 0x398a7ff7 +com.WavesAudio.Maserati B72.9.2.70 (9.2.70 - 9.2.704) <EAB0FF13-8BB4-D6BC-7606-18926B7FEEE1> /Applications/Waves/*/Maserati B72.bundle/Contents/MacOS/Maserati B72 0x39927000 - 0x39aebff7 +com.WavesAudio.WavesLib_9.1.9.1.60 (9.1.60 - 9.1.602) <17B75D29-4C9B-9415-FFF9-A964BFE90BC1> /Applications/Waves/*/WavesLib_9.1.framework/Versions/A/WavesLib 0x39c5c000 - 0x39d07fff libcrypto.0.9.7.dylib (106) <041B3399-5033-3395-9A71-6693F3A33D94> /usr/lib/libcrypto.0.9.7.dylib 0x39d4b000 - 0x39f59fe7 +com.WavesAudio.1447251280.9.1.0 (9.1.0 - 9.1.09) <5DCC138C-3D67-60E8-32C3-B35913E65064> /Applications/Waves/*/1447251280.bundle/Contents/MacOS/1447251280 0x39fea000 - 0x3a050ffb +com.WavesAudio.1448169780.9.1.0 (9.1.0 - 9.1.09) <85E147DE-E1FE-6621-2E9E-7C2FEC71CBB6> /Applications/Waves/*/1448169780.bundle/Contents/MacOS/1448169780 0x3a076000 - 0x3a08cff3 +com.WavesAudio.1398031697.9.1.0 (9.1.0 - 9.1.09) <C7D75DAF-228A-162E-C696-7AD532CDA0CE> /Applications/Waves/*/1398031697.bundle/Contents/MacOS/1398031697 0x3a0ae000 - 0x3a0c5fff +com.WavesAudio.1398030938.9.1.0 (9.1.0 - 9.1.09) <1571A2FF-9002-2230-8B3B-F8B5DA4BC06A> /Applications/Waves/*/1398030938.bundle/Contents/MacOS/1398030938 0x3a0e7000 - 0x3a0eaffb +GenericMacIntel.dylib (0) <88AC0BC0-F202-AC03-3A2D-89A74BC9593C> /Applications/Waves/*/1128811570.bundle/Contents/MacOS/GenericMacIntel.dylib 0x3a0ed000 - 0x3a0f0ff7 +GenericMacIntel.dylib (0) <3934F983-F506-86E0-7D39-F0710735867A> /Applications/Waves/*/1397506888.bundle/Contents/MacOS/GenericMacIntel.dylib 0x3a200000 - 0x3a218fe7 +com.WavesAudio.1398031948.9.1.0 (9.1.0 - 9.1.09) <92AED184-8F69-0A9F-E6CA-D2281F6D4F10> /Applications/Waves/*/1398031948.bundle/Contents/MacOS/1398031948 0x3a25e000 - 0x3a276ff7 +com.WavesAudio.1398031187.9.1.0 (9.1.0 - 9.1.09) <5FB3DED4-8298-44B1-C16A-1C1D2D4FF683> /Applications/Waves/*/1398031187.bundle/Contents/MacOS/1398031187 0x3a2bc000 - 0x3a2d5feb +com.WavesAudio.1128811570.9.1.0 (9.1.0 - 9.1.09) <C3A0FA2A-15EF-C4A7-526C-D60836203B3C> /Applications/Waves/*/1128811570.bundle/Contents/MacOS/1128811570 0x3a443000 - 0x3a470ff3 com.apple.audio.CoreAudioKit (1.6.5 - 1.6.5) <42BE7C8C-9EF9-3F12-8827-961B349C5B31> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit 0x3b000000 - 0x3bf45ff3 +com.slate-digital.VirtualChannel (1.5.2 - ???) <1ACE20F5-2FEF-6907-1F05-15DFCEC33F70> /Library/Application Support/Digidesign/*/Slate Digital Virtual Channel 0x3c690000 - 0x3c6bafff +GenericMacIntel.dylib (0) <B8329DC0-4265-0093-D0DE-862059767C70> /Applications/Waves/*/Maserati DRM.bundle/Contents/MacOS/GenericMacIntel.dylib 0x3c6c2000 - 0x3c6e8fe7 +com.WavesAudio.1397506888.9.1.0 (9.1.0 - 9.1.09) <51798AA8-B88D-E68E-4961-F552E28354B7> /Applications/Waves/*/1397506888.bundle/Contents/MacOS/1397506888 0x3e64a000 - 0x3e6effe7 +com.WavesAudio.Maserati DRM.9.2.70 (9.2.70 - 9.2.704) <9935C7B7-DFD2-7C84-3F7B-083E7A68C5D3> /Applications/Waves/*/Maserati DRM.bundle/Contents/MacOS/Maserati DRM 0x3fef1000 - 0x3fef6ff3 +GenericMacIntel.dylib (0) <928EC5F1-2906-9D36-4AB6-1A74ECB0F67E> /Applications/Waves/*/1448169779.bundle/Contents/MacOS/GenericMacIntel.dylib 0x3fef9000 - 0x3fefcff7 +GenericMacIntel.dylib (0) <ECA8BDA3-17A5-1CCA-F521-D775C98D557D> /Applications/Waves/*/1380205907.bundle/Contents/MacOS/GenericMacIntel.dylib 0x402f5000 - 0x402fafff +GenericMacIntel.dylib (0) <629AEF28-30CB-CF6E-02F9-B6BBB5B04F35> /Applications/Waves/*/1381388866.bundle/Contents/MacOS/GenericMacIntel.dylib 0x407e9000 - 0x407efff7 +GenericMacIntel.dylib (0) <7B045C21-A697-E1F7-6B88-6D8961CF09D2> /Applications/Waves/*/1278287904.bundle/Contents/MacOS/GenericMacIntel.dylib 0x407f5000 - 0x407faffb +GenericMacIntel.dylib (0) <D35890D4-4B9F-4DDA-C4BB-8FE6271375C7> /Applications/Waves/*/1212302412.bundle/Contents/MacOS/GenericMacIntel.dylib 0x42300000 - 0x42619fcb +com.toontrack.ezmix2 (2.0.9 - 2.0.9) <D0C09E1A-3EDF-FCE5-0663-9BF008CB64FE> /Library/Application Support/Avid/*/EZmix 0x4271b000 - 0x4271fffb +GenericMacIntel.dylib (0) <9CCEDB06-128A-BD64-E744-DFA236CDB390> /Applications/Waves/*/0825308982.bundle/Contents/MacOS/GenericMacIntel.dylib 0x42728000 - 0x42731ffb +GenericMacIntel.dylib (0) <1AF9591C-31FD-8306-3ED4-BE2713470621> /Applications/Waves/*/1464091212.bundle/Contents/MacOS/GenericMacIntel.dylib 0x43e0b000 - 0x43e99fff +com.Universal Audio.vst2rtas.UAD Cambridge (1.0x0 - 1.0) <9434D4EB-5C05-B090-AD6B-543F6C3BD40B> /Library/Application Support/Digidesign/*/UAD Cambridge 0x43f1c000 - 0x43f5effb +com.uaudio.UAD Cambridge (7.8.0 - 7.8.0) <E67081B5-EAC6-0400-B8A2-0150AE31903B> /Library/Audio/Plug-Ins/VST/Powered Plug-Ins/UAD Cambridge.vst/Contents/MacOS/UAD Cambridge 0x43fa9000 - 0x4421cff7 +com.uaudio.UAD2_GUI_Support (7.8.0 - 7.8.0) <051533B5-6E9A-47C3-AEA4-9E4A3A9A123D> /Library/Frameworks/UAD-2 GUI Support.framework/Versions/A/UAD-2 GUI Support 0x445c8000 - 0x44609fe3 +com.uaudio.UAD_GUI_Library (7.8.0 - 7.8.0) <92D60774-F431-2200-C1C9-E1A28ECF8AFE> /Library/Frameworks/UAD GUI Library.framework/Versions/A/UAD GUI Library 0x44662000 - 0x446deff7 +com.uaudio.UAD Cambridge (7.8.0 - 7.8.0) <E5D5CD36-8A60-6C21-F627-87A5201DE054> /Library/Application Support/Universal Audio/*/UAD Cambridge 0x4475f000 - 0x44793ffb +com.uaudio.UAD2_SDK_Support (7.8.0 - 7.8.0) <193A56D9-1B51-7DA8-1793-5F1183DD87AF> /Library/Frameworks/UAD-2 SDK Support.framework/Versions/A/UAD-2 SDK Support 0x447ba000 - 0x447d5ff7 +com.uaudio.UAD2_Plugin_Support (7.8.0 - 7.8.0) <7649FF66-3E20-171F-67CD-C915FE24B8FE> /Library/Frameworks/UAD-2 Plugin Support.framework/Versions/A/UAD-2 Plugin Support 0x45354000 - 0x453e2fff +com.Universal Audio.vst2rtas.UAD Teletronix LA-2 (1.0x0 - 1.0) <9434D4EB-5C05-B090-AD6B-543F6C3BD40B> /Library/Application Support/Digidesign/*/UAD Teletronix LA-2 0x45465000 - 0x454a7ffb +com.uaudio.UAD Teletronix LA-2 (7.8.0 - 7.8.0) <C9B6339A-352E-D06A-A769-7593F86E3388> /Library/Audio/Plug-Ins/VST/Powered Plug-Ins/UAD Teletronix LA-2.vst/Contents/MacOS/UAD Teletronix LA-2 0x454f1000 - 0x45553ffb +com.uaudio.UAD Teletronix LA-2 (7.8.0 - 7.8.0) <63FB1A0F-A4D6-B55A-0000-C07705C5AFFA> /Library/Application Support/Universal Audio/*/UAD Teletronix LA-2 0x480c8000 - 0x482bfff3 +com.AVID.plugin.SansAmp PSA-1 (11.1.3.325 - 11.1.3d325) <152AD53D-EA68-3BA4-A7D0-B33BE2E51E40> /Library/Application Support/Avid/*/SansAmp PSA-1 0x48a43000 - 0x48a62fe7 +com.WavesAudio.SuperTap.9.1.0 (9.1.0 - 9.1.09) <9509EB38-25AA-E92E-73FD-49F76F4C0520> /Applications/Waves/*/SuperTap.bundle/Contents/MacOS/SuperTap 0x49c5e000 - 0x49de1ff3 +com.AVID.plugin.EQIII (11.1.3.325 - 11.1.3d325) <088D7E4D-D268-3E11-AA67-1C8A7B99B457> /Library/Application Support/Avid/*/EQIII 0x4b6f9000 - 0x4b787fff +com.Universal Audio.vst2rtas.UAD CS-1 (1.0x0 - 1.0) <9434D4EB-5C05-B090-AD6B-543F6C3BD40B> /Library/Application Support/Digidesign/*/UAD CS-1 0x4b80a000 - 0x4b84cfe3 +com.uaudio.UAD CS-1 (7.8.0 - 7.8.0) <33672744-D9A7-819F-F96A-83A029D8801B> /Library/Audio/Plug-Ins/VST/Powered Plug-Ins/UAD CS-1.vst/Contents/MacOS/UAD CS-1 0x4b896000 - 0x4b905ffb +com.uaudio.UAD CS-1 (7.8.0 - 7.8.0) <07B90D67-3508-2B8D-2299-F5DDC68557EC> /Library/Application Support/Universal Audio/*/UAD CS-1 0x4da87000 - 0x4e310feb +com.bluecataudio.BC MB-7 Mixer 2 AAX(Stereo) ("2.2" - "2.2") <82E2C8BA-AC79-2C32-8260-4D04B3026392> /Library/Application Support/Avid/*/BC MB-7 Mixer 2 AAX(Stereo) 0x4f300000 - 0x4f3b9fef +com.plugin-alliance.plugins.vst.SPLDeVerb (1.6 - 1.6) <2242A04A-2CE6-B3D5-52D5-019343CA1577> /Library/Audio/Plug-Ins/VST/SPL De-Verb.vst/Contents/MacOS/SPL De-Verb 0x4fdbe000 - 0x4fe69fff +com.WavesAudio.CLA Vocals.9.2.70 (9.2.70 - 9.2.704) <DB3308F3-DBEF-8BD9-905D-CC0CA8BC4F2D> /Applications/Waves/*/CLA Vocals.bundle/Contents/MacOS/CLA Vocals |
Plugins that crash / don't crash PT 8 not on Digi's compatibility grid | alex s | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-27-2009 03:23 AM |
Crash crash crash crash crashhhhh crahshrbnjfgeviufdbldfgvjndgokhng | FuneralMusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 27 | 11-16-2009 12:02 AM |
Crash Crash Crash Live 6 Pro Tools Rewire | TimmyP | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-12-2007 11:26 AM |
Crash, Crash, Crash!! 7.2 when deleting breakpiont | Mark 66 | Pro Tools TDM Systems (Mac) | 2 | 01-28-2007 09:13 PM |
Installed 32track le version, won't run with Reaktor crash crash crash | Christian | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-02-2002 11:05 AM |
