Digi002 and Focusrite 18i20 not getting ADAT signal
I am running Pro Tools 11 with a Digi 002 and a Focusrite 18i20 connected to the 002 by optical . .. I see good levels coming into all 8 of the focusrite channels but I can not get any levels on the 8 ADAT inputs in Pro Tools. I tried adjusting the 002 Hardware settings but still nothing . .. Help?
Re: Digi002 and Focusrite 18i20 not getting ADAT signal
In the hardware settings have you set the digital to optical adat? And on the inputs selection box you set inputs say 9-16 to receive optical adat? The session is 44.1 or 48k? The Focusrite is set to receive external clock. Digital connections to and from the Focusrite Chris
Hi Gabriel Sullivan,
Have you set up the 18i20 for Standalone mode properly? You have to tell it to route it's Analog Inputs to the ADAT Outputs. Please see the guide here: http://us.focusrite.com/answerbase/h...tandalone-mode Best regards. Kat
Katherine Kaplan // Focusrite Technical Support http://www.focusrite.com/answerbase/en/ |
Focusrite 18i20 Disconnecting with Pro Tools 11 | SuperDave71 | Third Party Interfaces | 4 | 06-20-2014 06:43 AM |
Focusrite 18i20 won't power on. | Woodybear | Third Party Interfaces | 3 | 04-03-2014 04:19 PM |
Focusrite 18i20 won't detect when switching on | Kollen.col | Third Party Interfaces | 11 | 03-26-2014 02:04 PM |
Focusrite 18i20 | MEWCO | Third Party Interfaces | 17 | 03-03-2014 09:37 PM |
Pro Tools 10 disconnects my Focusrite 18I20 | Peter Warren | Pro Tools 10 | 0 | 12-13-2013 12:31 AM |
