Old 07-10-2020, 06:25 PM
midnightfluff midnightfluff is offline
Default Installing crossgrade from perp on new MacBook
Hi. I just got a new MacBook and I guess now have to crossgrade to a subscription because the perp doesn't work on Catalina.
Will my old plug-ins still work or are there compatibility issues. I've got several ex PT user buddies who switched to Logic, but I've already begun a project and don't want to change horses in midstream.
I just wanna make sure my plug ins will work, but admittedly am bummed about my perpetual not being usable. I don't use a ton of features and just make my own albums at home.
Thanks
Old 07-13-2020, 08:01 AM
Default Re: Installing crossgrade from perp on new MacBook
While Avid stopped selling reinstatements at the end of last year, many dealers still have stock. If you buy a reinstatement, you will keep your perpetual license, get a new 1 year support and upgrade plan, and be able to renew that plan before it's expiration date and 30-day grace period have expired.
Scott Gatteño
Old 07-13-2020, 08:14 AM
Yep, try that first (and remember to renew while the plan is still active).
As for plugin you use, you will need to double-check each and every one of them and likely download fresh installers.
Old 07-13-2020, 08:48 AM
thanks. I figured it out, once I discovered where the download links were.
Delete PT 8LE before installing PT 10 crossgrade? James Jett macOS 5 03-23-2015 01:45 AM
Re-installing after crossgrade. Stratomaster Windows 1 07-19-2011 08:08 PM
help installing PT 9 crossgrade -ilokked out End Over End Pro Tools 9 8 06-06-2011 10:39 AM
Installing PT9 Crossgrade on two computers? tragibigzanda Pro Tools 9 2 05-03-2011 07:10 AM
Advice for installing PT 9 crossgrade? RobRaden Pro Tools 9 5 01-26-2011 03:58 PM
