Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Win)
Old 07-24-2023, 02:26 PM
jrblackwell jrblackwell is offline
Default MBox Mini Driver for Windows10 won't download
Hi, I'm trying to download the driver for MBox mini and it always displays an error message. I'm trying 1.1.8 and it fails. I was able to download 1.1.7, but that isn't the version I need...I was just trying to see if it worked.
The reason I'm doing this is that I want to see how I can change the interface data rate setting. If you know how to do this, please let me know.
Thank you.
Old 08-14-2023, 07:11 AM
Default Re: MBox Mini Driver for Windows10 won't download
Thank you.
Some thoughts:
1-what does "data rate setting" mean? If you mean sample rate, and you are on a Windows machine, then you probably have Windows Sound Properties set to use the Mbox as the Windows playback device. This will lock Pro Tools out of changing the sample rate. Solution: set Windows to use the on-board sound card for playback(leaving the Mbox for Pro Tools' exclusive use)
2-any time you have trouble downloading anything, try a different browser
Old 08-14-2023, 01:14 PM
Bruce Paine Bruce Paine is offline
Admin Emeritus
Do you have the Mbox Mini User Guide? If not, there may be some installation and use details in it that may help.
Bruce Paine
System Details
i can`t download 1.1.7 driver mbox3 mini navid.salehi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-09-2013 10:51 PM
Issue with Mbox 2 pro... Will I need to download a driver to use it? DeenaJackman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-11-2011 06:36 AM
Mbox Pro/Pro Tools Driver DVD download jkmusic7 macOS 4 07-24-2011 11:40 PM
WHERE COULD I DOWNLOAD 7.1 DRIVER FOR MBOX pmajor2k 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-18-2007 11:24 AM
