Suddenly run out of cpu
So after(insane years of messing with these same songs) my computer started running out of cpu. Nothing has changed in these sessions except eq changes and compression changes over several years. I have been learning to mix like a pro on several songs now for several years (6). I am actually using fewer plugins now than ever before so I don't see how that could be a problem all of a sudden. Anybody got any suggestions. thanks
Windows 10 Pro Tools 2019.6 Asus g752vt 17.3" laptop i7 Quad 2.6ghz 32gig ram 500gig ssd 2T ssd win. 10 Universal Audio x8P . Focusrite Clarett Octopre(NOT AN INTERFACE) |
Re: Suddenly run out of cpu
You have to ask? The answer is always the same. Nobody here can guess what is going on you have to do standard troubleshooting.
Start by running all the standard troubleshooting steps under "Help Us Help You" up the top of every DUC web page. And double check *all* optimizations are done and have not been undone. You should sort out fast if this is behavior specific to some sessions, or if it's more widespread. And either way, as always, you are going to suspect plugins, and all installed plugins, not just the plugins you are using in a session, so be sure to try the standard remove .aaxplugin plugin tests there. And after you do that and if you still need help provide clear information... What *exact* problems/errors are you having? Provide a good description of your systems, Pro Tools versions etc. Include the expected SiSoft Sandra report since it's a PC. What interface and driver version? (since your signature lists three different ones). Give some idea of the session size/complexity, what sample rate and H/W buffer size. And what has changed? OS updates? Pro Tools updates? Plugin updates? |
When this happens to me, the first thing I do is check on what other apps may be running in the background.
Suddenly can't record | ToddSmee | Pro Tools 12 | 6 | 07-15-2018 03:05 PM |
Inputs suddenly gone. | Dodraugen | macOS | 0 | 05-09-2012 07:38 AM |
HELP please PT 10.1.1 suddenly QUITS | funkymik111 | macOS | 1 | 03-17-2012 10:51 PM |
PT LE 7.4 suddenly quits | geosel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-15-2010 05:36 PM |
...suddenly there was NO SOUND | Vinseph | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-12-2002 10:20 AM |
