Old 05-07-2023, 04:53 PM
rdpar's Avatar
rdpar rdpar is offline
Default Mastering for cd or streaming?
If I have my project ( @ 24bit 44.1) mastered for CD @ 16bit 44.1 can I convert it back to 24bit bit 44.1 in pro tools for streaming , with good enough results to submit it to streaming services?
Windows 10 Pro Tools 2019.6 Asus g752vt 17.3" laptop i7 Quad 2.6ghz 32gig ram
500gig ssd 2T ssd win. 10 Universal Audio x8P . Focusrite Clarett Octopre(NOT AN INTERFACE)
Old 05-07-2023, 05:28 PM
Will Russell's Avatar
Will Russell Will Russell is offline
Default Re: Mastering for cd or streaming?
My apologies if you know this already, but if you convert a 16bit file to 24-bit it doesn't become better quality. I'm sure there are plenty of 16/44.1 files that are submitted for streaming and they sound fine.
If it's not too late why not have it mastered at the same file format as your recording. Then you can convert it to whatever file format you need.
In theory a higher resolution the source the better the results of Lossy conversion to mp3/aac
Will Russell
Electric Wilburland Studio
https://linktr.ee/wilburland
M1MAX Mac Studio OS 14.4.1, PT2024.3, HDX, S1/Dock
M1 PRO MacBook Pro OS 14.4.1, PT2024.3, BabyFacePro FS
Old 05-09-2023, 05:44 AM
rdpar's Avatar
In theory is a higher resolution the source the better the results of Lossy conversion to mp3/aac
Thanks. Do you think Pro Tools is a good way to convert my 24 bit tracks to 16bit?
Old 05-09-2023, 07:00 AM
Yup!
Be sure to dither when/if you do!
Will Russell
Old 05-09-2023, 09:26 AM
JFreak's Avatar
JFreak JFreak is offline
If mastering for streaming is the thing, this is a killer.
Janne
Old 05-09-2023, 10:24 AM
Ben Jenssen's Avatar
A 16bit wav file imported into a PT session with the same sample rate, will become a 24bit file with 8 zeroes added to each sample to make them 24bit 'word's, and sound exactly the same. Until you process it in some way, adjust level etc, when it will use the last 8 bits.
(Edit: Sorry, the quote and my reply doesn't really make sense. My bad. My point stands, though, so I'll just let it be.)
Old 05-09-2023, 03:37 PM
rdpar's Avatar
We’ll now that’s confusing 😳😵*💫
Old 05-09-2023, 03:55 PM
I'm sorry. I didn't mean to confuse.
I tried to say that making a 16bit file 24 bit doesn't make a difference, because every sample is the same value, except it has 24 digits instead of 16. Hence the 8 zeroes at the end.
Old 05-10-2023, 06:59 AM
rdpar's Avatar
Ok thanks �� so if I have my tracks mastered for CD, 16bit 44.1 , I can convert them back to 24bit 44.1 in pro tools to submit them to streaming devices with no weird sound loss?
Old 05-10-2023, 07:17 AM
JFreak's Avatar
Yes if you import (not convert) 16bit stuff to 24bit session, all you get is bigger filesize -- quality remains the same.
Janne
Mastering: Loudness in the Age of Music Streaming Ben Jenssen Avid Pro Mixing General Discussion 2 08-30-2020 11:06 AM
Lurssen Mastering Console & Learn Mastering with the Masters Peter - IK Multimedia AAX Plug-ins 15 05-11-2017 08:45 PM
who uses the renaissance compressor in mastering?...and some other mastering stuff... djc8902 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 01-16-2003 11:14 AM
Mastering singles for radio with new Waves Mastering suite. Peter Duemmler Pro Tools TDM Systems (Mac) 14 06-21-2002 05:14 PM
Mastering singles for radio with new Waves Mastering suite. Dimension Zero Tips & Tricks 0 06-15-2002 12:32 AM
