Playback + Recorder with MTRX
Hi all.
I would be interested to hear how you manage the recorder (dubber) workflow with the MTRX. Let's assume there are two playback rigs, and one recorder. S6 with Pec/Dir panel, and 1 MTRX. Are you routing the stems to recorder, and then creating a printmaster on the recorder with the stems as the source. Or are you utilising the MTRX in any creative way to achieve the same result..? are there any pitfalls to be aware of? I'm aware this isn't a concise question, and i'm sure there will be differing opinions, but i'm curious as to how everyone is working? Thanks in advance! |
Re: Playback + Recorder with MTRX
In my setup the Playback systems and recorder all connect to the same MTRX. The playback systems feed the recorder which sends to the HTRMU via Dante. The RMU sends foldowns for temp mixes and screenings back to the Recorder.
When everything's finished, I cut a long play together and record into the RMU. For theatrical it's exactly the same but the RMU is fed via MADI. My only real advice is be sure to print 2 pops. Delay compensation can get wacky sometimes. |
MTRX Sources - >Trinnov MC16 Dante ->MTRX Out routing ??s | Jeff Schmidt | Pro Tools | MTRX & MTRX Studio | 4 | 03-18-2022 02:21 PM |
MTRX Studio+DVS playback engine | talkbacksound | Pro Tools | MTRX & MTRX Studio | 1 | 03-06-2022 05:06 AM |
MTRX Studio tuning v MTRX SQP card | Goombot | Avid Pro Mixing General Discussion | 9 | 07-15-2021 11:00 AM |
Satellite Recorder: Playback jumps when punching in / out of record | Gregor B. | Post - Surround - Video | 4 | 08-29-2020 08:27 AM |
Sync with an external recorder like a Korg D16 or Roland recorder | yoshi68 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-17-2001 08:30 AM |
