Mixing/matching Avid control desktop with Avid Control ios
I'm outta faders on my s3 and looking to get 4 S1s and want to use the ios app/tablets on two of them and the Avid control desktop on the other two. I'll also be running an ios app/tablet on the dock.
is this doable? |
Re: Mixing/matching Avid control desktop with Avid Control ios
You can only use 1 tablet running Avid Control as a master control app, with access to all of the functions and pages. The other tablets have to be tied to an S1 and only function in meter mode.
EdiT: So sorry. My brain somehow skipped over the Avid Control DESKTOP part of this. Apologies for giving incomplete info. Glad others were here to step in and get you sorted!
Scott Gatteño Last edited by originalscottyg; 11-02-2022 at 01:56 PM. |
Thanks Scott, that's helpful.
Do you know if I can use 2 tablets for 2 S1's metering and the Avid Control DESKTOP app for the other 2 S1 meters? The avid Control iso app will be locked to the dock. |
All the tablets will run the Avid Control software, but only one can be the master (not sure if that's what it's actually called). Once you add one to the My Surfaces pane, you can only add more tablets by dragging them on top of S1s and they will only run in Meter Mode. Generally if you have a Dock plus some S1s, the tablet on the Dock would run in "master mode" and the tablets on the S1s would run in "meter mode".
Scott Gatteño |
If you are running Avid Control Desktop along with 2 meter tablets on 2 S1's and 1 AC Master tablet on the Dock, you can get metering on Avid Control Desktop for the remaining two S1's. You'll need to play around with placement of the ACD but ACD will show you the meters for the 2 S1's without a tablet.
Yes you can do what you want. look on Page 9 https://resources.avid.com/SupportFi...de_v2022.4.pdf
Avid s1 with Control Desktop | azahand | Avid S1, S3, Dock and Control App | 17 | 02-09-2024 10:14 AM |
Most Waves plugins cannot be set properly from Avid control surfaces / Avid Control? | XJENSEN | Avid S1, S3, Dock and Control App | 3 | 08-11-2022 06:59 AM |
Can I use D command and avid control desktop | [email protected] | Pro Tools | 1 | 08-05-2022 03:00 PM |
After Update the Avid Control Desktop App gives a black screen... | TrackerLe | Avid S1, S3, Dock and Control App | 2 | 10-27-2021 09:48 AM |
Control Surface For Protools 10 Mackie Pro Control or Avid Artist Control | lberrios1962 | Pro Tools 10 | 18 | 05-26-2012 12:51 AM |
