Old 09-10-2017, 07:37 PM
Cal D Cal D is offline
Default Set Up/Buffers help
Hi:
I am wondering if someone can help me to determine the best settings. I keep encountering an error message when I play back my sessions. I have attached tghe following pictures:
Info about my configuration within Protools8
Info about my configuration on my M-Audio Fasttrack pro sound card
Info about my computer
A picture of the error message. When I see this message, the session stops.
Here is where all the files mentioned above are:
https://drive.google.com/drive/folde...Vk?usp=sharing
Thank-you
Old 09-10-2017, 08:01 PM
YYR123's Avatar
YYR123 YYR123 is offline
In PT8 you are supposed to put 1 less cores than you have available
Then put the CPU setting to 99%
Are you using 2 drives for recording?
Daniel
Old 09-11-2017, 05:56 AM
Default Re: Set Up/Buffers help
Thanks. I will give that a try.
Yes, I am using two drives for recording.
Thanks for the advice!
Cal
Old 09-11-2017, 07:15 AM
YYR123's Avatar
Yes so if you have an 8 core CPU then set it to 7 under this Host Processor Setting.
if you have a 4 core and PT detects the threads of the other virtual cores then you could play around with the settings and see which one gives you a more stable PT environment.
example.
1 virtual core less = 7 cores or.....
1 real core less = 3 cores.
I don't remember what I ran....seems like I had to play around with those settings and see which one was more stable but you definitely don't want to have all your CPU cores listed there.
Then there is this.....which is pretty important as well.
https://www.sweetwater.com/sweetcare...-optimization/
Daniel
Old 09-12-2017, 03:32 PM
mikeyman's Avatar
mikeyman mikeyman is offline
I was having trouble like this on PT's 10 and I checked the box on the bottom of the page says ''Optimize for streaming content'' and it works better now,.Not sure if I did the right thing cause i'm not sure what that optimize feature IS FORi THINK I WAS GETTING THAT SAME MESSAGE IN FACT
Old 09-13-2017, 12:15 PM
jeam25's Avatar
jeam25 jeam25 is offline
Originally Posted by Cal D View Post
Hi:
Thank-you
Hi friend !
Protools 8 and windows 10 ? I think thats not a good start ( not supported by Avid ) but anyway you can try by starting doing al the Win10 optimizations . Also make shure to install your latest Maudio Fast Track Drivers .
Mac M1 Studio Ultra - Sonoma Beta OS
Avid Carbon Interface
Protools Ultimate
Pro Tools 9 HW buffers joe_04_04 Pro Tools 9 2 12-21-2010 11:49 AM
Anyone able to record with BFD All and HW buffers of 128? j20056 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 09-04-2007 12:39 PM
Anyone successfully using BFD All with low buffers? j20056 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-04-2007 10:24 AM
So tell me about 8-meg HDD buffers!! Stone Knife 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 01-29-2003 12:56 AM
DAE BUFFERS PROBLEMS! pauldrum 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-02-2001 01:28 PM
