Old 11-29-2017, 03:48 PM
JGM JGM is offline
Default Re: iPad Non-Pro 9.7" 7th Gen
Originally Posted by EddieJones View Post
This is OK
Hey Eddie, thanks for your help so far.
The IPs are the same except for the last 3 digits.
So it's like: xxx.xxx.1.209 the iPad & it's xxx.xxx.1.212 for the mac
Quick question... Can I have the ethernet cable plugged into the mac at the same time while running the wifi connection?
Old 11-30-2017, 09:02 AM
EddieJones's Avatar
That may be causing some confusion. Try turning off WiFi on the Workstation and restarting everything.
Old 11-30-2017, 10:34 AM
JGM JGM is offline
I’ll try this when I get home. But I thought that both the iPad and the Mac has to be connected to the same WiFi network?
Can I have the iPad on the WiFi network and have the Mac just connected via Ethernet cable and still have the 2 machines speak to each other to facilitate Pro Tools Control Guide?
Old 11-30-2017, 10:51 AM
EddieJones's Avatar
Yes as long as they both go back to your router (which it sounds like they do)
Old 11-30-2017, 04:33 PM
JGM JGM is offline
Tried it. No go.
  #16
Old 11-30-2017, 07:16 PM
EddieJones's Avatar
Whats the make and model of the router, EUCON uses Apple Bonjour to discover surfaces and some block it by default. Can you check the EUCON prefs and make sure the right network adapter is selected on the Mac.
  #17
Old 12-02-2017, 06:11 PM
JGM JGM is offline
My router is a Verizon Fios G-1100.
What do you mean by network adapter?
  #18
Old 12-03-2017, 10:25 AM
EddieJones's Avatar
The network adapters are the wifi and ethernet ports.
I did some searching online and see a lot of users of your router having similar issues. This is advanced and you should do this at your own risk but I see that disabling this setting in your router is said to fix the communication issue between cable and wifi.
  #19
Old 12-04-2017, 05:32 PM
JGM JGM is offline
Tried this. No go. I am convinced that my particular iPad is not supported. Though I cannot verify that at the moment. My old iPad2 was recognized by Eucon Control, though I still couldn't get it connected. I can't believe this is so difficult. I feel like a prisoner of the 2 companies (Apple & Avid) I least like, but most need!
What a pickle!!!!
  #20
Old 12-04-2017, 05:50 PM
EddieJones's Avatar
If the Control App installs and runs then it should connect...I'm the Product Manager so should know ;-) It has to be a networking issue.
12.9" iPad Pro...anyone?? topaz1s Avid S1, S3, Dock and Control App 0 02-18-2017 07:39 PM
iPad Pro 9.7" VS. iPad Air 2 ? reichman Avid S1, S3, Dock and Control App 1 08-07-2016 10:46 PM
"Instrument names reappear after changing fonts on iPad Scorch" jccmusic Avid Scorch (iOS) Forum 1 12-02-2011 02:03 AM
Will the ipad?".......... barters81 General Discussion 4 04-13-2010 12:06 AM
